la-9104p MB 7 Beeps error and no display
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: la-9104p MB 7 Beeps error and no display
    Techtiger , maybe the solution is to to dump the 9012chip !
    take a look : https://www.youtube.com/watch?v=mgNwI4CrnL4
    • Techtiger
      • Oct 2014
      • 1602
      • france
      Interesting do you have the crystal checker if not change the YH2
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Originally posted by lapfix
        For DRAMRST# , i think it must be active low ! i find 0.049v at pin 30 of ram slot.
        Any other place to check !!
        It has to be 1.35V. Dramrst#-dont get confused. Just compare Lidsw#. Is that not 3.3V to work.?? Check PG signals of each and every Ic as this mb is typical where PG of one ic becomes EN of another IC. Look at schematic carefully
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          Hello folks
          Techtiger : i change it before but stil same issue
          mcplslg : yes ou are right and this is the new reading with compare it ones from a good board .
          UC3 :
          Pin 2 = PLT_RST# = 0V ( 3.41V on goodboard )
          Pin 4 = BUFO_CPU_RST# = 0.74V ( 1.073V On goodboard )
          Pin 5 = VCC = +3VALW ( OK)
          UH3 :
          Pin 1 = IN1 = 3.36V ( Ok)
          pin 2 = IN2 = 0.011V ( 3.42V goodboard )
          Pin 4 = SYS_PWROK = 0.005V ( 3.42V goodboard)
          Pin 5 = VCC = 3.42V ( Ok)
          UC2 :
          Pin 1 = 3.38 ( ok)
          Pin 2 = DRAM_PWRGD = 0.532V ( 3.39V goodboard )
          Pin 4 = VDDPWRGOOD = 0.25V ( 1.5V goodboard )
          Pin 5 = VCC = 3.40V ( Ok)
          Pin 30 = DDR3_DRAMRST# = 0.049v ( 1.5V goodboard)
          Lid-sw = 3.40V
          So ,many voltages didn't exist ..try to find why...if you have any other suggestion or demand , please ask it
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Check QZ3/4/8/10. Pl400 Voltage present??PU500 Pin1 Voltage?? PR501 voltage on both sides??
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              #26
              QZ3 is ok :
              D = 3.41v
              G =14.69v
              S = 3.39v
              PU 400 = 1.825v
              PR 501 = 3.40v---3.07v
              PU 500 = pin 1 = 3.07v
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                QZ3 is ok :
                D = 3.41v
                G =14.69v
                S = 3.39v
                PU 400 = 1.825v
                All is fine here. Is there any missing Rails??
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  Cpu is getting +1.35V Supply?? This is a must for Dramrst#
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    #29
                    Voltage present on PL600??
                    • lapfix
                      • Mar 2020
                      • 2764
                      • my workshop
                      #30
                      I will take measurements after.
                      have another one , comes today ..same issue of 7beeps..PL500 =0v....PR501 = 3.3v from 1side/ 0v from the PU500. ( 91KOHM)...i change it and still not got the Voltage !
                      On this second board , the ampere start from 0.240 and increase with fan speed too
                      • lapfix
                        • Mar 2020
                        • 2764
                        • my workshop
                        #31
                        This is the measurements For PU500 From working Motherboard, maybe it help other for diagnostic.
                        PU 500 :
                        PL500 = 1.078v
                        Pin1 = 3.70v
                        Pin2 = 0.540v
                        Pin3 = 3.200v
                        Pin4 = 0.719v
                        Pin5 = 0v
                        Pin6 = 4.68v
                        Pin7 = 5.00v
                        Pin8 = 1.056v
                        Pin9 = 1.314v
                        Pin10 = 5.60v
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #32
                          That means you dont have +V1.05S_VCCP_PWRGOOD signal. This is PG for PU500 and EN for PU600 to generate VCCSAP. If PR501 is ok, either PU500 or PU600 is likely to be bad. Try replacing them.
                          • lapfix
                            • Mar 2020
                            • 2764
                            • my workshop
                            #33
                            That's crazy !!
                            For the first one , power on :
                            PL 500 = 1.056v
                            PL 600 = 0.950v
                            PL 701 = 1.137v !!!
                            7 beeps still and current consumption = 0.240amp
                            Power off , try again , no volt on PL 701 with 7 beeps too , current consumption 0.140Amp
                            PL 500 = 1.056v
                            PL 600 = 0.950v
                            PL 701 = 0v
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #34
                              Thats really crazy but still check pin27 of PU700 for IMVP_PWRGD. Btw, you flashed both main & EC bios?? Cmos battery is not below 3V??
                              • lapfix
                                • Mar 2020
                                • 2764
                                • my workshop
                                #35
                                Hello again
                                Yes strange thing , yes i flashed UH6/UH2 with a know dump.
                                Cmos bat = 3.07v
                                pu700
                                pin 27 = 0v
                                pin 21/22 = 5vs
                                pin 2 =3.39
                                pin13=3.38
                                • Spider1211
                                  • Oct 2019
                                  • 532
                                  • Mauritius
                                  #36
                                  Hello, do you have activity on both BIOS? Check pin 1 with an oscilloscope (measure while turning laptop ON). I have a similar issue (7 beeps) with a LA-9101P but no activity on BIOS.
                                  Everything else seem to check out, am starting to lean towards a bad PCH at this point.
                                  • lapfix
                                    • Mar 2020
                                    • 2764
                                    • my workshop
                                    #37
                                    Hello spider and thank you
                                    unfortunately i don 't have oscilloscope..maybe a PCH but try to confirm ...
                                    i solve another customer 3521 same issue..that's why i still believe tha's not a PCH r a CPU issue.
                                    BTW , i change PU700 same beep
                                    • Spider1211
                                      • Oct 2019
                                      • 532
                                      • Mauritius
                                      #38
                                      It's quite rare that it is an actual CPU issue. I did have a PCH issue in the past but ofcourse the PCH is the last I would blame.
                                      Which part/IC was the problem?
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        #39
                                        I've faced actual cpu failure on dell 3521 but only once and replacing the cpu did solved the problem. Most of the time if cpu fails, caps in ram area will show low rating . So @lapfix, do compare rating of caps in ram area between good board and defective one.
                                        • Spider1211
                                          • Oct 2019
                                          • 532
                                          • Mauritius
                                          #40
                                          I may have spoken too early as I might have a bad CPU afterall. I went back and rechecked the LA-9101P and how would you know...+VCC_GFXCORE_AXG is missing (no idea how I missed that). PU700 is ok and +VCC_Core is also present.
                                          With PU700 off the board (although It should not matter) I have a short on VSS_AXG_SENSE and VCC_AXG_SENSE. These 2 signal go directly to the CPU. I already checked any components on those line and they seem OK.
                                          My readings (resistance to ground):
                                          >PL700 - 1.68ohms (I was expecting this to be low, but that low?)
                                          >FBG - 2.601KOhms
                                          >RTNG - 0.21Ohms
                                          >+VCC_GFXCORE_AXG and FBG - 2.601KOhms
                                          >IMVP_PWRGD (pin 85 of KB9012) is jumping all over the place and is 0V on PU700 side.
                                          Per schematic, I would have expected VSS_AXG_SENSE (RTNG to ground) to be around 100 Ohms and VCC_AXG_SENSE (+VCC_GFXCORE_AXG to FBG) to be around 2.701 KOhms.
                                          @Lapfix, can you please share reading of PU700(resistance to ground) from your known good board for the following:
                                          - PL700
                                          - FBG (pin 29)
                                          - RTNG (pin 30)
                                          - Resistance between +VCC_GFXCORE_AXG and FBG(pin 29)
                                          - IMVP_PWRGD voltage on pin85 of KB9012 and on pin 27 of PU700
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • lanovey
                                            SF314-41 BIOS without internal display
                                            by lanovey
                                            Hello there,
                                            I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
                                            I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
                                            06-13-2025, 02:38 AM
                                          • AustinCER
                                            HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
                                            by AustinCER
                                            I currently have an HP ENVY Desktop TE01-1214
                                            S/N -
                                            2MO22342GX
                                            Motherboard - L75365-001
                                            BIOS Chip - W25Q128JVSQ
                                            Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
                                            Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
                                            04-25-2025, 05:56 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • ikelectro
                                            After bios recovery by pen drive HP15s eq0007AU display flashing a light for short time.
                                            by ikelectro
                                            Schematic : DAOP5EMB6E0 REV:E​
                                            I have tried manually flashed the bios, also tried hp bios recovery tools to recover the bios. But no luck. Display is not coming, 3 to 4 times recovery display is coming if I tried to recover by pen drive[win+ B]. But after restarts it goes to dark screen and a light is flashing after a certain time in the display + fan speeds increasing and decreasing. I have tried almost every bios for this motherboard avaiable in the internet.
                                            Any help or guide to proceed?...
                                            03-19-2025, 08:17 PM
