dell n4010 power led on and off .
  • mo000
    • Nov 2017
    • 285
    • algeria
    when i plug in the adapter the power led on and off
    i have 3.3v and 5v and 5v on pwr switch
    1.05v pch is missing which coming from PU4
    pu4 enabled by run on signal which coming from SIO ITE8502
    but this signal is missing on pin 123 in SIO
    is that mean i should replace it ? .
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: dell n4010 power led on and off .
    First Flash bios save the old Dump RUN ON missing DC to DC will not convert you have to check EC RST RSMRST RTCVCC
    • mo000
      • Nov 2017
      • 285
      • algeria
      I already flash the bios .
      can you help me i can't find RTCVCC and EC RST.
      • mo000
        • Nov 2017
        • 285
        • algeria
        Rsmrst=3.3v .
        • Techtiger
          • Oct 2014
          • 1602
          • france
          You have to check if the
          RSMRST goes 3.3V to 0V when pressing the PWR Button
          WRST# pin14 3.3V to 0V when pressing the PWR Button
          Pm_pwrbtn pin81 3.3V to 0V when pressing the PWR Button
          RTC CELL pin 3 for 3.3V
          • mo000
            • Nov 2017
            • 285
            • algeria
            RSMRST still 3.3v after pres the PWR btn .
            WRST# still 3.3v after pres the PWR btn .
            Pm_pwrbtn pin81 =0v missing 3.3v
            RTC CELL =3.3V .
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Check if the SYS PWR SW goes high low on SIO and Voltage on Bios all pins
              • mo000
                • Nov 2017
                • 285
                • algeria
                SYS PWR SW still 3.3v
                no voltage on main bios the voltage on ec bios .
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Check for connectivity,corrosion neat pu4 ic. If things look good, try replacing pu4 first. Voltage on main bios will appear after poweron. Try also removing the pch pwr coil and again resoldering it. Sometimes pch pwr appear with this trick.
