Dell Latitude 120L (WISTRON DK1 MB) - no battery detected
  • cruiser_
    • Nov 2019
    • 124
    • Ireland
    Hello there!
    I have a problem with and old laptop I got hold of.
    It charges the battery and works off of it, but the battery itself is not detected in BIOS (no battery installed) or OS. It is a genuine DELL one.
    The AC adapter is recognized as 60W.
    The voltages on the battery connector (with AC on, no battery)
    2 - 3.3 (PBAT_PRES)
    4 - 3.3 (BT_SCL_R)
    5 - 3.3 (BT_SDA_R)
    6 - 15.8 (and goes down)
    With AC adapter on + battery
    2 - 0 (PBAT_PRES)
    4 - 3.0 (BT_SCL_R)
    5 - 3.0 (BT_SDA_R)
    6 - 12.2 (and grows)
    I am working on the diagram from
    https://drive.google.com/file/d/1-DL...RbuZ9j1Kt/view
    I checked R525, R526, R524, R189, R190
    diodes D2/D3/D16
    capacitors EC59, C270.
    Still no joy :|
    What else can I check guys?
  • KvnTM
    • May 2018
    • 434
    Re: Dell Latitude 120L (WISTRON DK1 MB) - no battery detected
    Take a look at the I2C Bus (SDA, SCL) with an oscilloscope if you have one.
    I'd bet that battery is dead.
    It is not detected but it still works off it? What does HWINFO say about it?
    • diif
      • Feb 2014
      • 6978
      • England
      Have you checked BCC1 ?
      • cruiser_
        • Nov 2019
        • 124
        • Ireland
        When is I2C comm supposed to happen? I looked with a mini osc at SDA & SCL while connecting the battery (no charger) - no activity. When should the BIOS talk to it?
        The laptop is disassembled now so I cannot boot it to the OS, but from the Linux kernel message I remember acpi system reporting 'battery absent' during boot.
        I couldn't find BCC1. No boardview here
        But I do remember from the measurements, that between 'after' the R524/525/526 and GND there was steady 0.6kohm and capacity of 186nF with R524/525 and only 4nF with R526. Hope you know what I mean Can this rule out busted capacitor on these lines?
        • cruiser_
          • Nov 2019
          • 124
          • Ireland
          With charger connected, there's loads of activity on SDA&SCL pins. Will yet have to hook up logic analyser to see what the messages sent are. Still scratching my head as to why BIOS would not see the battery...
          • cruiser_
            • Nov 2019
            • 124
            • Ireland
            I hooked up the battery to my arduino and ran SBMInfo. It seems the battery operates fine on the logic level:
            START D:\downloads\tmp\SBMInfo\SBMInfo.ino
            Version 3.1 from Nov 22 2019
            Found attached I2C device at 0xB
            *** STATIC INFO ***
            Chemistry: LION
            Manufacturer Name: SMP-SDI2.6
            Manufacturer Data: 4 20 20 20 20 7 20 20 20 20 20 20 20 1D 1 6 C FB 0 0 A 64 1 F4 10 9A 10 86
            Device Name: DELL YD12068B
            Serial Number: 1355
            Manufacture Date (YYYY-MM-DD): 2006-8-11
            Design Capacity: 5200 mAh
            Design Voltage: 11.100 volt
            Charging Current: 3500 mA
            Charging Voltage: 12.975 volt
            Specification Info: 33
            Cycle Count: 136
            Max Error of charge calculation (%): 100
            RemainingTimeAlarm: 10 min
            Remaining Capacity Alarm: 520 mAh
            Battery Mode (BIN): 0b110000110000001
            - Internal Charge Controller Supported
            - Battery OK
            - Charge Controller Enabled
            - Disable AlarmWarning broadcast to Host and Smart Battery Charger
            - Disable broadcasts of ChargingVoltage and ChargingCurrent to Smart Battery Charger
            Pack Status (BIN): 0b1110001000100000
            *** MANUFACTURER INFO ***
            Device Type: 57888 / 0xE220
            *** RATE TEST INFO ***
            Setting AT rate to 100 mA
            TimeToFull at rate: 38726 min
            Setting AT rate to -100 mA
            TimeToEmpty at rate: 570 min
            Can be delivered for 10 seconds at rate: 1
            *** DYNAMIC INFO ***
            Full Charge Capacity: 65494 mAh
            Remaining Capacity: 950 mAh
            Relative Charge: 1 %
            Absolute Charge(%): 18
            Minutes remaining until empty: Battery not beeing (dis)charged
            Average minutes remaining until empty: Battery not beeing (dis)charged
            Minutes remaining for full charge: Battery not beeing (dis)charged
            Battery Status (BIN): 0b11010111
            - Initialized
            - Discharging
            - Fully Discharged
            Voltage: 11.920 volt
            Current: 0 mA
            Average Current of last minute: 0 mA
            Temperature: 21.45 C
            *** DYNAMIC NON STANDARD INFO ***
            Cell 1 Voltage: 3.970 volt
            Cell 2 Voltage: 3.974 volt
            Cell 3 Voltage: 3.978 volt
            Cell 4 Voltage: 0.000 volt
            State of Health: 0
            *** CHANGED VALUES ***
            • mrkmpn
              Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
              by mrkmpn
              Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
              This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
              03-13-2024, 01:54 PM
            • mkdj
              by mkdj
              Mark and model: ASUS X571
              Tests already made:
              - I have removed...
              07-14-2025, 09:16 AM
            • grimacelord
              A2338 820-02020-A | Battery Not Detected/Random Reboots
              by grimacelord
              I have a A2338 MacBook Pro here that came to me because the battery wasn't being detected. The owner tried to replace the battery themselves thinking that the battery was the problem but the behavior continues even with their new aftermarket battery. They also accidentally ripped off the black plastic clasp to the battery flex cable connector @ J5151, but I pulled that off of a donor board and replaced that for them already. I did quickly check to see if that was simply the problem, but it's not.
              First thing I checked was I2C_SMC_PWR_3V3_SCL and I2C_SMC_PWR_3V...
              Today, 09:11 AM
            • techfreak9356
              Vostro 3400 (LA-K033P) won't charge battery, everything else ok
              by techfreak9356
              09-14-2023, 11:10 PM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
