Hp 250 g6 csl50 la-e791p
  • cacascacas
    • May 2017
    • 8
    • espain
    I have a hp 250
    when power the computer blink
    Caps lock blink 5 slow 3 fast
    I write the bios with dump and ene chip , but the same problem
    any suggestions
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Hp 250 g6 csl50 la-e791p
    Originally posted by cacascacas
    I have a hp 250
    any suggestions
    Hp 5 blink System bord Failure +19V 3/5V must be ok the Schematic is not available , what is the SIO chip check all pins EC Bios for Voltage test all colis Diode mode Ohms
    • cacascacas
      • May 2017
      • 8
      • espain
      Hello
      The SIO chip is ene kb9022q
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Hello
        Cannot find the data sheet for KB9022Q
        • cacascacas
          • May 2017
          • 8
          • espain
          Hello
          I find the pdf of kb9022q.
          can you help me
          • Techtiger
            • Oct 2014
            • 1601
            • france
            Check all this pins on SIO be careful not to short pins , when you get this sine # it’s high low depending on the platform MB +3V volts when you press the power button will go to 0V and come back or 0V will rise to +3V volts check all pins one by one
            125 VCC
            37 EC RST#
            6 SLP S3#
            19 AC PRESENT
            123 SLP S4#
            122 PWTN OUT#
            110 AC IN
            112 EC ON
            114 ON/OFF BTN#
            115 LID SW#
            116 SUSP#
            100 RSMRST #
            101 EC LID OUT#
            • mazloum
              • Sep 2012
              • 499
              • Lebanon
              hello , did any one find the solution of this :
                • 20794
                Check all ram pins under a microscope
                • cloo
                  Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                  by cloo
                  I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                  It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                  So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                  After doing a factory reset this problem was gone and the picture was back to...
                  01-06-2025, 06:02 AM
                • c00lman
                  Sharp LC-90LE745U 3 slow and 1 fast Blink
                  by c00lman
                  hi, new member her and apologize if this has been discussed.. tried to search and most of the result are for LC-xxLe6xx series and not sure if it's applicable to the 745U.
                  the TV stopped turning on and after the V logo stayed solid for a minute or 2, it gives the 3 slow and 1 fast blinks which from what I researched are internal communication error.
                  did some voltage measurement on the power supply out.
                  Pin 1 and 2 = 0V --> PNL 12V
                  Pin 3 and 4 = 0 V --> GND
                  Pin 5 to 8 = 13V --> UR 13V
                  Pin 9 to 12 = 0 V --> GND
                  PIN 13...
                  06-21-2021, 05:18 PM
                • yihuilin
                  HP 15-dy0013dx doesn't Power On, Power LED Bilinking, needs help for trouble shooting
                  by yihuilin
                  Hello Every Genuis
                  I have a laptop from my friend, model is "HP 15-dy0013dx" , Logic Board model is DA00P5MB6D0 REV MODEL: 0P5
                  this Laptop come with a BIOS Warning issue, the Keyboard CAPS LED Blinking 3 times slow, 2 times fast , don't remember exactly, someting like this, has a Meaning , also Fan will run
                  but I googled, people says this Meaning EC have a issue to read BIOS, so I use CHA314A programmer to read and write (wrote the same content file read from BIOS), after I flashed the BIOS, the CAPS LED doesn't blink anymore
                  02-08-2025, 08:27 AM
                • Vebririon
                  panasonic TX-P50V10E 6 blink led problem
                  by Vebririon
                  I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                  Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                  I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                  05-17-2025, 10:16 AM
                • ChaosLegionnaire
                  bug of the month: write caching setting for the hard drive in device manager
                  by ChaosLegionnaire
                  i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                  so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                  10-06-2019, 01:39 PM
