Lenovo G40-50 Aclu5/aclu6 wont turn on
  • maurovalero
    • Sep 2018
    • 69
    • colombia
    I was working well with him, one day he turned off he did not turn on, checking it I found that the pu401 heats up when the charger is connected, I already replaced it but the fault persists remove the capacitor that is close to the pj401 and did not cause the short.
    the pu401 SY8206BQNC, is short but when removing the pad pj401 disappears the short but the pu401 is the source of 3v.
    pl401 pl402 no voltaje, capacitors near of pu402 whit voltaje 20, 3.2 5.6
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Lenovo G40-50 Aclu5/aclu6 wont turn on
    PJ401 which side is short to GND , test all pins of PU402 except pin 9 for Voltage
    • maurovalero
      • Sep 2018
      • 69
      • colombia
      Thx for reply
      1- no voltaje
      2- no voltaje
      3- no voltaje
      4- no voltaje
      5- 3.2v
      6 - 2.8v
      7- 5v
      8- 20v
      thats values is whit open pad pj401, short to ground is in top
      pu401 inicially pu401 was warming but now the source don have consum
      pu401
      1- no voltaje
      2- no voltaje
      3- no voltaje
      4- no voltaje
      5- 2.1
      6 - 2.1v
      7-
      8- 20v
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Remove the jumper PJ402 PJ406 check the resistance to GND both side of PJ402 pj406
        After test pin 85 of UE1 SIO chip EC ON 3.3V page 44, PU401 IC pin 1is connected with 2 resisters 1 cap and a Diode test for any shorts on those components
        PU402 pin 1 connected with 2 resisters 1 cap and a Diode test for any shorts on those components
        This chip is getting 19+ LDO is ok but no +3VALW +5VALW you need EC ON to enable this chip
        • maurovalero
          • Sep 2018
          • 69
          • colombia
          Thanks for answering, none of the components were short, you have any other suggestions.
          I did the tests with pj402 pj406 pj401 pj402 open
          When I close PJ402, the indicated capacitor is bridged to the ground on both ends, I remain attentive.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            but you didnt mentioned reistance of both pads of PJ402-one of the pads is likely to be short.
            • maurovalero
              • Sep 2018
              • 69
              • colombia
              srry i did wrong pad is pj403 in short to ground
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                If you have lab supply, then inject 1V with high amps on the shorted side of PJ403 and see what becomes hot.
                • Jane
                  Lenovo IdeaPad - mainboard ACLU5 ACLU6 NM-A281 Rev. 1.0
                  by Jane
                  The laptop is dead. I can meaure only 19V rail.
                  Mosfets volatges: PQ6: Drain 19V, Source 19V, Gate 19V
                  PQ7 : Drain 0V, Source 19V, Gate 19V
                  Charging IC BQ24737:
                  Vcc 19V
                  ACOK 5.9V
                  ACDET 2.5V
                  REGN 6V
                  Do you think BQ24737 is faulty?
                  What should I check?
                  I enclosed a schematic.
                  Thank you for help...
                  11-07-2024, 09:36 AM
                • klynstronic
                  PU401, MOTHERBOARD DA0G3DMBCE0 REV:E
                  by klynstronic
                  Hi Hi.
                  Can you help me? The boardview of the DA0G3DMBCE0 REV:E motherboard says that the PU401 IC is a MP86903C...however this is a TQFN21. The PU401 is a TQFN13 and the MP86901-AGQT-Z IC is TQFN13.
                  Am I correct? Or is it a different IC?
                  I would appreciate an answer.
                  Regards.
                  Starts
                  01-12-2025
                  Ends
                  01-13-2025
                  01-13-2025, 06:42 AM
                • AppleLover123
                  Acer E1 572G no power (dead)
                  by AppleLover123
                  i have this laptop it is completely dead.
                  V5WE2 LA-9531P
                  No 3.3 or 5v
                  VCC is ok 19v
                  PU401 blew up rails to coil and jumper PJ401
                  tried to replace IC but it has a burned pin underneath making IC unusuable
                  Short on PJ401
                  all other pins from the IC area seem ok
                  PJ401 = 2 oms
                  bought a buck converter from ebay
                  when soldering out + from buck converter to PJ401 and powering up :
                  The Coil from the buck converter is getting crazy hot and the CPU is getting slightly warm.
                  I cant check the...
                  03-15-2024, 01:49 PM
                • Fidel Martinez
                  PU401 gets extremely hot on Motherboard la-9532p_r1.0
                  by Fidel Martinez
                  Problem:
                  - Doesn't react to power button and doesn't charge battery
                  - The PU401 SY8208BQNC_QFN10_3X3 gets extremely hot when connecting
                  the power adapter.
                  Compal circuits show:
                  a SY8208DQNC_QFN10_3X3 on page 38 (PU601)
                  (an adjustable step-down switchmode converter with a feedback reference voltage of 0.6V)
                  and
                  a SY8208BQNC_QFN10_3X3 on page 35 (PU401)
                  (appears to be a fixed 3V converter)
                  I have replaced the PU401 IC and the problem...
                  01-09-2021, 08:15 PM
                • AppleLover123
                  Acer aspire e1 572g dead
                  by AppleLover123
                  Hey Forum,
                  I have a dead Acer Laptop from a friend. Find out that its a Mobo fault because Screen is working on other mobo and there are 19V on Power Jack that are going over the two Mosfets into the Mobo. So its actually charging too but no matter what i Do the leds wont come on. So i went over to the 5v and 3v Section and there is nothing at both. The 5v Rail is okay so no short but at the 3v Rail theres a short at PJ401 and on both sides from the Coil PL402 but on the capacitors there is no short. So i found a 19V 3.42Amps Charger (it works) plugged it into the Mobo and the Step...
                  12-28-2023, 12:25 PM
