PU401, MOTHERBOARD DA0G3DMBCE0 REV:E
  • klynstronic
    • Jun 2022
    • 45
    • españa
    Hi Click image for larger version
ID:	3547552 Click image for larger version
Name:	Sin título.jpg
ID:	3547553 Click image for larger version
    Can you help me? The boardview of the DA0G3DMBCE0 REV:E motherboard says that the PU401 IC is a MP86903C...however this is a TQFN21. The PU401 is a TQFN13 and the MP86901-AGQT-Z IC is TQFN13.
    Am I correct? Or is it a different IC?
    I would appreciate an answer.
    Regards.
    Starts
    01-12-2025
    Ends
    01-13-2025
  • mon2
    • 14724
    Do you have the original part from this motherboard? Post clear pics of the PCB where this part was originally mounted.
    My bv file also reports the part to be MP86903C. If you have the original part, post top and bottom side clear pics of the part for a review.
    • klynstronic
      • Jun 2022
      • 45
      • españa
      Hi.
      Thank you for your reply.
      The chip is quite damaged although some letters and numbers can be seen. I think it indicates AMVJ 944.​
      • mon2
        • 14724
        Good catch! The boardview is wrong.
        The part on your board is indeed MP86901-AGQT-Z​. The topside markings on the replacement should also bear the same first 3 markings of ‘AMV’.
          • 22112
          No datasheet available but the chip is in the Clevo NL50CU NL51CU Service manual schematic https://www.badcaps.net/forum/troubl...nual-schematic ,and in the Monolithic Power Solutions for Powering
          Intel and AMD SoCs Apr 22,2020
          pdf https://www.badcaps.net/filedata/fetch?id=2104075
          • klynstronic
            • Jun 2022
            • 45
            • españa
            Hi.
            Okay, thanks.
            Regards.
