Charging Section - Some basic Questions
  • IamPritesh
    • Aug 2017
    • 354
    • India
    So I have more than a couple of Laptops that have this strange charging issue.. When I plug in the adpater, it starts to charge for like 20-30 seconds( Shows animation of battery filling up on the extreme right taskbar). But then the animation of charging the the battery stops . Now when you click on the battery icon , it says plugged in and charging. But the percentage does not increase at all.
    So my question is , what is the safest method to troubleshoot the charging section ..
    For example 1. Check battery connector 2.Bios 3. Check Voltage on X pin of charging IC or Check voltage on XYZ mosfet
    I understand everyone is busy , but your expertise can be really helpful to many of us.
  • classicandy
    • Apr 2018
    • 308
    • Nigeria
    Re: Charging Section - Some basic Questions
    The name & model of the laptops in question would also help in prescribing a solution for you.
    • piernov
      • Jan 2016
      • 4435
      • France
      Usually that would be a bad battery rather than a motherboard problem.
      • brew99
        • Jan 2019
        • 132
        I had this exact same symptom when I was trying to replace the charging IC on an Asus. It ended up being that it wasn't completely soldered correctly on all pins. Might want to replace the charging IC if the battery proves OK
        • kodox
          • Jul 2017
          • 322
          • Indonesia
          i always use HWMonitor from cpuid.com, it contains battery information. you can download it here https://www.cpuid.com/downloads/hwmo...nitor_1.40.exe
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • Scoff
            HP Probook 470 G4 - Power and Charging Problem
            by Scoff
            Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
            Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
            07-03-2023, 09:28 AM
          • SluggerB
            Help with trying to fix phone that is not charging (Pics inside)
            by SluggerB
            I have two TCL A30 phones.
            Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
            New Phone: Works fine, bought as a donor board to try and repair Old Phone
            My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
            08-12-2024, 08:11 AM
          • CPUFiddler
            Acer Nitro 5 AN515-45 not charging
            by CPUFiddler
            Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
            This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
            I've downloaded...
            03-19-2025, 07:44 AM
          • Julian Bailey
            HP ProBook 445 G8 Battery not charging
            by Julian Bailey
            Hi all
            We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
            The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
            I have gone around the board with a MM and cant find anything
            Windows shows the battery fine,...
            10-11-2024, 10:34 AM
