MSI EX460 FAN at full speed and shuts off a minute
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this MSI EX460 with core 2 duo and ati hd4430 graphics,at first the problem is no display, so i replaced the nectoken with tantalum caps now there is display but the problem is the fan at full speed and after a minute it shuts off. anyone can help on this
    • 20898
    Re: MSI EX460 FAN at full speed and shuts off a minute
    Clean the ME .
    • String2016
      • Nov 2015
      • 2238
      • philippines
      here is my original bios file @smdlead can you please clean na me region for this. thanks in advance
      • age80
        • Jun 2013
        • 55
        • Greece
        ME region on core2duo PC???
        why dont you try from MSI direct????
        https://www.msi.com/Laptop/support/EX460#down-bios
        • piernov
          • Jan 2016
          • 4435
          • France
          Sounds like overheating issue.
          • String2016
            • Nov 2015
            • 2238
            • philippines
            i think this is not a overheating issue because fan spinning and thermal paste already done replaced
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Ati graphics issue??
              • String2016
                • Nov 2015
                • 2238
                • philippines
                problem solved. reflashed the bios from the site still the same issue. I decided to reflow the ATI chip now problem solved
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  No, its not solved. It will come back to you within few days. Either reball it or replace the chip.
                  • doejohn11
                    Lenovo Legion 5 17ach6h shuts off after 70 seconds.
                    by doejohn11
                    Hello guys. I have a legion 5 17ach6h with Ryzen 7 5600h and RTX3060.
                    It was working perfectly fine but the cpu was overheating so i decided to replace thermal paste. I bought one from local hardware store and replcaed. it looked fine then the fan started to spin at the full speed after about 1 minute and then immediately shut off after 10 seconds. Then I though if i have done something wrong, so i cleaned up everything with IPA and put new thermal paste. but the issue was still there. After that, I came across this article where he had similar issue and he was able to solve it by replacing...
                    04-19-2025, 07:38 AM
                  • Babbar
                    1980s Holz Her 2420 belt sander - Only works when speed control at maximum
                    by Babbar
                    My fathers belt sander from the 80s which i very much would like to continue using has an issue with the speed control. The machine works fine on maximum speed but will not turn or give any sign of life when on any other setting. The speed control is a dial going from 1-6 although implemented as a potentiometer without distinct steps. I took the machine apart and measured each component individually, all components and measurements have been captioned in the attached pictures. The Triac did not get identified correctly using my cheapo component tester, i don't know if this is user error, if the...
                    11-13-2024, 01:54 AM
                  • eccerr0r
                    old X58 triple channel board... memtest86 memory speed?
                    by eccerr0r
                    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                    06-28-2025, 09:06 AM
                  • chaos-theory
                    Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                    by chaos-theory
                    I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                    Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                    03-14-2025, 05:37 PM
                  • japlytic
                    Maximum speed should be marked on network ports
                    by japlytic
                    I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                    One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                    12-19-2024, 05:04 PM
