MSI EX460 FAN at full speed and shuts off a minute
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this MSI EX460 with core 2 duo and ati hd4430 graphics,at first the problem is no display, so i replaced the nectoken with tantalum caps now there is display but the problem is the fan at full speed and after a minute it shuts off. anyone can help on this
    • 21869
    Re: MSI EX460 FAN at full speed and shuts off a minute
    Clean the ME .
    • String2016
      • Nov 2015
      • 2238
      • philippines
      here is my original bios file @smdlead can you please clean na me region for this. thanks in advance
      • age80
        • Jun 2013
        • 55
        • Greece
        ME region on core2duo PC???
        why dont you try from MSI direct????
        https://www.msi.com/Laptop/support/EX460#down-bios
        • piernov
          • Jan 2016
          • 4439
          • France
          Sounds like overheating issue.
          • String2016
            • Nov 2015
            • 2238
            • philippines
            i think this is not a overheating issue because fan spinning and thermal paste already done replaced
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Ati graphics issue??
              • String2016
                • Nov 2015
                • 2238
                • philippines
                problem solved. reflashed the bios from the site still the same issue. I decided to reflow the ATI chip now problem solved
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  No, its not solved. It will come back to you within few days. Either reball it or replace the chip.
                  • SimonSempai
                    Legion 5 (15ACH6H) comes on, full fan speed, shuts off after 64 seconds
                    by SimonSempai
                    Hi everyone!
                    I got this laptop from a friend who claims after he accidentally poured water on the laptop, board seems that it has survived it. There are signs of someone opening it and even taking out the board but screws where at the correct places. Laptop comes on, no issues, boots into windows and everything checks out as far as voltages go but somehow the thing doesn't wanna stay on. I have checked Electronics repair school's video about this (he had the same legion 5 with the same issue) and noticed in the comments that there could be issues with US1. Thinking the IC may be faulty...
                    09-30-2025, 03:42 AM
                  • hoarderteks_kyriakos
                    Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                    by hoarderteks_kyriakos
                    Hello.
                    Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                    Here is what happened:
                    At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                    10-08-2025, 07:33 AM
                  • doejohn11
                    Lenovo Legion 5 17ach6h shuts off after 70 seconds.
                    by doejohn11
                    Hello guys. I have a legion 5 17ach6h with Ryzen 7 5600h and RTX3060.
                    It was working perfectly fine but the cpu was overheating so i decided to replace thermal paste. I bought one from local hardware store and replcaed. it looked fine then the fan started to spin at the full speed after about 1 minute and then immediately shut off after 10 seconds. Then I though if i have done something wrong, so i cleaned up everything with IPA and put new thermal paste. but the issue was still there. After that, I came across this article where he had similar issue and he was able to solve it by replacing...
                    04-19-2025, 07:38 AM
                  • Babbar
                    1980s Holz Her 2420 belt sander - Only works when speed control at maximum
                    by Babbar
                    My fathers belt sander from the 80s which i very much would like to continue using has an issue with the speed control. The machine works fine on maximum speed but will not turn or give any sign of life when on any other setting. The speed control is a dial going from 1-6 although implemented as a potentiometer without distinct steps. I took the machine apart and measured each component individually, all components and measurements have been captioned in the attached pictures. The Triac did not get identified correctly using my cheapo component tester, i don't know if this is user error, if the...
                    11-13-2024, 01:54 AM
                  • brav1ez
                    ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
                    by brav1ez
                    I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
                    I’ve tried:
                    - CMOS reset
                    - Removing the SSD/HDD
                    - Reseating RAM (removing each stick individually stops boot completely)
                    - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
                    With...
                    09-07-2025, 10:47 AM
