NP300e5c Killing input FET after some time.
  • CidiRome
    • Jan 2015
    • 49
    • Portugal
    Hi there.
    I'm wrapping my head around this Samsung that keeps killing Q10 (the first FET in the 19V power line) after a few minutes at least 15 (this last time I was not close to it when it went down).
    I've seen some youtube videos where they just short this FET, but I don't like this kind of approach: if the FET is there it is for some reason that I may or may not even understand.
    As I didn't find the same exact model FET to replace, I've scavenged other boards for FETs with similar values, but they keep failing.
    There must be something down the line that is killing the FET after a while.
    Note that the FET doesn't get burned, it just stops working and sometimes it even work for a few seconds and stops after.
    Does any of you that are experienced in this things can point me to the reason of the FET being killed?
    Cheers.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: NP300e5c Killing input FET after some time.
    check what is current draw from psu and replace that mosfet with some with higher amperage
    • piernov
      • Jan 2016
      • 4439
      • France
      What do you mean by "stops working"? Is it shorted or not? Usually the failure mode of the DC in MOSFET is short between source and drain. If it's not shorted the issue is probably something else, such as the charger IC not triggering the gate.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Neither you mentioned the original fet used on the mobo nor you mentioned the replacement fets used. So how do anyone know, whether they were compatible or not??
        • CidiRome
          • Jan 2015
          • 49
          • Portugal
          Hi.
          I will try to answer all questions, so hopefully you can help me.
          - I've replaced it again and while working it was drawing up to about 1.5A with the battery out and up to about 2.7A with the battery in (charging).
          - Stops working: they do no short, after what I consider failing they sometimes allow the notebook to turn on, but mostly the greed led turn on and off again. It is worse with the battery in (at least discharged like it is now).
          - I've tried a few FETs that I didn't give much attention to the Amps because I knew that this notebook is low end/power.
          The original FET was a 7200, the first replacement was B20N03, the one after I don't remember, and the last one was a different package type that I manage to install for tests is a 7170.
          With this last one I hooked the notebook to my bench power supply and it was working for hours (and charged the battery) and I left over night and today it don't work anymore.
          The strange thing is that the schematic seems to indicate different references for the FETs: the one that I replaced was originally a 7200, but the schematic says it is a 7403 that is even a different type of FET...
          Please see the attached pictures.
          Any Ideas?
          Cheers.
          • anshad
            • Nov 2010
            • 249
            ''- Stops working: they do no short, after what I consider failing they sometimes allow the notebook to turn on, but mostly the greed led turn on and off again. It is worse with the battery in (at least discharged like it is now).''
            Based on your explanation, i don't think that the MOSFET is failing/faulty. It looks like the MOSFET driving circuitry sometime is failing to drive the MOSFET. In other words, the MOSFET is not receiving proper gate drive voltage sometimes. What you should do is measure the gate voltage when the MOSFET is passing the voltage and also when it is not passing the voltage. Then you will be easily able to determine the exact root cause.
            Btw, what is the board part no ?. Usually Samsung boards are identified by ''BA41-XXXXA'' format.
            • CidiRome
              • Jan 2015
              • 49
              • Portugal
              Hi.
              The Board P/N is BA41-01978A (second Picture of my last post).
              I will try to measure the gate voltage and will get back to you.
              Cheers.
              • CidiRome
                • Jan 2015
                • 49
                • Portugal
                Hi.
                I had a few seconds to measure the voltage before it went off (with the same FET) and it is about 25V relative to ground, that would be about 6V relative to Drain.
                I remember measuring the voltage Gate to Drain and it was about 5V.
                When it goes off the voltage is absolute zero (to Ground) or -17V to Drain.
                I thought that it shutting down would be because something ordered it to, but the gate circuitry seems to be very passive... The thing is that I don't know where it is on the board and the also the schematic has P-Channel FETs while there are N-Channel FETs on the board.
                Any ideas?
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  I can't find the schematics for this board so maybe you got a different one.
                  25V to ground is indeed perfectly fine for N-Channel MOSFET.
                  0V means the charger IC stopped generating the gate signal. The charger IC is what controls the gate of the DC-in MOSFETs. So if voltage is straight up 0, it can be an issue around the charging circuit in general.
                  First you have to identify what kind of charger IC you have on the board.
                  • CidiRome
                    • Jan 2015
                    • 49
                    • Portugal
                    Hi.
                    The schematic I have is the one that I'm attaching and I downloaded it from this forum. Based on the P/N BA41-#####A written on it, it matches BA41-01978A written on the board itself.
                    Anyway, if this FET is controlled by the charger IC, it doesn't match with the schematic that has a simple passive circuit for this FET's gate (considering it could be a bit different for a N-Channel FET present in this board).
                    And is there any reason for this notebook to work flawlessly for a few hours when I replace the FET and stop working after that? This is why I would think that something is wrong with the FET itself and not with other circuitry, at least to the level of something making the FET stop working instead of something stop driving the FET...
                    I'm also attaching pictures of the power/charging circuitry.
                    Cheers.
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      Schematics is for an AMD platform called Petronas-15, I think your board is an Intel platform called Scala3-15.
                      Your charging circuit is different. You have a bq24735 charger IC. The gate of the MOSFET is driven by the ACDRV pin of this charging IC. It has an internal charge pump to get the gate voltage 6V higher than source voltage, so about 25V.
                      If the MOSFETs are not shorted drain to source it's unlikely they are the culprit. Not that they don't have other failure mode, but it would be very unusual in this circuit, especially multiple times. Maybe heat is doing something.
                      • CidiRome
                        • Jan 2015
                        • 49
                        • Portugal
                        Hi.
                        This is the second time I come across a board with this BQ735 and the previous case I couldn't find a dooner board in my stock where I could get this chip from (I found BQ725, but not one 735).
                        This time I was not pointing to this chip, but it would be nice to know it is the culprit before ordering a new one.
                        I'm not inclined to do the universal repair of shorting the FET SOURCE-DRAIN pads with a wire like I've seen doing in a few youtube videos for this notebook model...
                        If there are some more ideas, please feel free to tell what you (plural, any of you) think.
                        Cheers.
                          • 21932
                          scala3-14 schematic ,same BQ735 .
                          BA41-02093A(HST) BA41-02092A(GCE) BA41-02094A(PTC) BA41-02098A(GBM)
                          • anshad
                            • Nov 2010
                            • 249
                            ''And is there any reason for this notebook to work flawlessly for a few hours when I replace the FET and stop working after that? ''
                            When you replace a SMD component, you have to apply fair amount of heat using SMD rework station. This heat can have an effect on nearby components and it is very common for some intermittently failing component to either break total or work fine for sometimes when heat is applied. For decades, electronic technicians are using heat and cooling spray to find intermittently failing components.
                            Refer page 40 of the above schematic for a matching charging circuit using BQ24735. Measure voltages of all pins.
                            • anshad
                              • Nov 2010
                              • 249
                              ''I'm not inclined to do the universal repair of shorting the FET SOURCE-DRAIN pads with a wire like I've seen doing in a few youtube videos for this notebook model...''
                              Go for this route only as a last resort. If you bypass the VIN protection MOSFETs, some boards may refuse to charge the battery pack. In fact most of the boards i have checked so far behaves like that. Yours might be different but only way to know is actually trying.
                              • petehall347
                                • Jan 2015
                                • 4442
                                • United Kingdom
                                get the fet to switch on like its supposed to . why cheat and chance destroying something else ? ok if low value unit i suppose and looking for a new one anyway .
                                • CidiRome
                                  • Jan 2015
                                  • 49
                                  • Portugal
                                  Hi.
                                  With the correct schematic I was able to diagnose a bit more.
                                  The two resistors (marked in the picture I'm attaching) compose a voltage divider to sense then input DC in. What I noticed was the the bigger (in ohms) resistor resistance was floating, normally going down in resistance along with the temperature going down.
                                  If this resistor resistance goes down causes the voltage to go up and what I believe happens is that the IC detects that the input voltage is climbing and shuts down the FET.
                                  I don't know if I'm 100% correct, but I replaced the resistor with one of similar value and the notebook has been working flawlessly since then.
                                  Thank you for your help.
                                  Cheers.
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3628
                                    • slovakia
                                    ic needs to have voltage from resistor divider to ACDET pin in some level/around 2.7V/ if it is more or lover than this level, it shuts down fets./see datasheet/
                                    on battery work normal
                                    • anshad
                                      • Nov 2010
                                      • 249
                                      Originally posted by CidiRome
                                      Hi.
                                      Cheers.
                                      Good job and a proper repair work. Imagine what will happen if you used the jumper bypass short cut instead. The adapter volt will pass but as far as the charging IC thinks that the AC input voltage is insufficient, it will refuse to charge the battery. The laptop may essentially works like a portable desktop PC without battery backup. Don't blindly swallow everything see on YouTube.
                                      • REpairAT
                                        • Nov 2020
                                        • 143
                                        • Austria
                                        I just had this particular notebook here for repair, finally fixed (For everyone else having the same- or similar fault).
                                        In my case it was a BIOS issue (or more likely EC FW, that comes with the update).
                                        Symptoms were, that the notebook only ran on batty, gate voltage was too low on input MOSFETs.
                                        so what I did:
                                        • Bridge gate to enable input MOSFETs and charge the battery
                                        • Update BIOS to latest version (attached, original from Samsung Update)
                                        • Remove bridge
                                        suddenly, gate voltage is correct and notebook runs on AC and Battery again.
                                        Bios - https://www.badcaps.net/forum/showthread.php?t=37276
                                        Hope I could help. Cheers!
                                        • titomno2
                                          Gaming Laptop Zephyrus S17 TFT not detected every time !
                                          by titomno2
                                          Hi guys,
                                          I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                                          So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                                          On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                                          Then the screen won't work for a long period of time.
                                          If I wait 1 or 2 hours it work again most of the time.
                                          When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                                          01-19-2025, 08:27 AM
                                        • flat-earther
                                          Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                          by flat-earther
                                          I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                          To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                          I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                          The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                          So I need to connect another battery in...
                                          06-08-2025, 02:00 AM
                                        • OscarAV
                                          HP Pavilion dm4-1065dx long time to get the power led on
                                          by OscarAV
                                          I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
                                          I have made a quick search for my laptop but I have not seen anything similar.
                                          I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
                                          09-23-2024, 05:53 PM
                                        • BigOof
                                          Pioneer RM-07 Active monitors cutting out from time to time
                                          by BigOof
                                          I have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
                                          12-18-2024, 04:35 AM
                                        • nieljosiah
                                          HP Notebook - 15-ba017ax (LA-D711P Motherboard) turns off randomly after some time
                                          by nieljosiah
                                          I've had this laptop for 8-9 years, and about a week back, it started malfunctioning. When I press the power button, the power LED comes on for about 5secs and turns off. The fan also doesn't spin at all during this time. But, if I press the power button, and then manually spin the fan, the laptop boots up and the fan starts spinning on its own. Even if I do this, and the laptop boots up, it turns off (hard shutdown) after some time between 10secs and 1hour randomly. I've tried checking the fan voltage and it's at zero volts when I press the power button without spinning it, but when I spin the...
                                          08-17-2024, 02:19 AM
