Samsung NP300E5C bios dump needed
  • tomodachi
    • Apr 2012
    • 607
    • Turkey
    I m looking for a BIOS dump file for NP300E5C,
    thanks in advance
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: Samsung NP300E5C bios dump needed
    Here
    • tomodachi
      • Apr 2012
      • 607
      • Turkey
      you guys are great ! thank you so much
      • kukasIII
        • Aug 2012
        • 11
        • lisboa
        Originally posted by cyberhack
        Here
        thanks i will test, my machine have that famous bios brick from this machines.
        stuck in bios logo loop.
        • kukasIII
          • Aug 2012
          • 11
          • lisboa
          update ----
          this bios is for np300e5x and not for np300e5c, there are some difference, missing secure boot. i will post the correct one.
          the machine still work and post with this one, but i prefer to load the correct one.
          Marca -samsung
          Modelo -NP300E5C
          Board -Scala3-15/17CRV
          Bios -P03RAQ
          https://www.badcaps.net/forum/attach...1&d=1405354294
          • iskenderus
            • Sep 2014
            • 1
            • turkey
            thank you so much for bios file
            • zkirac
              • Dec 2014
              • 5
              • turkey
              Here
              Thank you so much its worked well
              • saifi
                • Feb 2015
                • 4
                • india
                thank you very much very helpful
                • Leonidas87
                  • Feb 2015
                  • 2
                  How do we install/update the bios using the file provided?
                  I would like to do the bios update using a USB stick as I can not boot into windows.
                  Any help would be greatly appreciated.
                  • Leonidas87
                    • Feb 2015
                    • 2
                    My np300e5c will not recognize my hard drive and I tested the drive in another computer and it is good. The hard drive is not detected by the laptop properly and i think this may be the solution.
                    • djsly08
                      F.O.F
                      • Mar 2015
                      • 2
                      Originally posted by kukasIII
                      update ----
                      Marca -samsung
                      Modelo -NP300E5C
                      Bios -P03RAQ
                      How to flash?? anyone???
                      FatherOf~5ive
                      • mahfooz
                        • Jul 2014
                        • 8
                        • india
                        thanks
                        • serenatci
                          • Apr 2015
                          • 1
                          • Turkey
                          Here
                          thank you very much
                          • zenithmx
                            • Sep 2015
                            • 1
                            • jersey
                            thx dud!
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              hey mate , welcome to the forum , don't forget to real our rules for the best of the forum.
                              About flashing , you will require a Flasher , for EX MINIPRO TL866CS
                              with this device , you simple need to remove the rom file of your board , and insert it on this device , further than you must get rom files to update your bios .
                              usually to find rom files , or you can chek it here or online on google , or you can get them at the regular laptop brand , toshiba , hp etc etc , but usually they are more hard to use , since they need to be cut , etc etc .
                              Well but stick around , and you'll see how things work around here.
                              best of luck
                              • ledro
                                • Aug 2012
                                • 46
                                • romania
                                thank you !
                                • zaidap
                                  • Nov 2015
                                  • 1
                                  • Argentina
                                  Hi...
                                  Thank you very much very helpful
                                  I program the bios with this dump. And work finee...
                                  • Alienvalien
                                    • Jan 2016
                                    • 1
                                    Here
                                    i used it my self, 100% workig
                                    • snegurochka
                                      • 2
                                      10q! Burn it and work like a charm!
                                      10x again!
                                      JJ
                                      • canali
                                        • Oct 2014
                                        • 192
                                        • turkey
                                        thank you !
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                          by DynaxSC
                                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          Hi everyone,
                                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
