DABLIDMB8E0 REV E won't turn on
  • angel611
    • Jun 2018
    • 7
    • sardegna
    have the same trouble with 2 motherboard, led white without battery and red light with battery but the notebook won't turn on and i check the motherboard i noticed the same caps on 2 motherboard burn, without this cap no led and after replace, same issue white led or red led whit battery, any help?
  • on/off
    • Oct 2016
    • 333
    • Indonesia
    Re: DABLIDMB8E0 REV E won't turn on
    It wasn't a Caps but Resistor marked by label R391 with value 0 ohm. The shape indeed make us confuse (maybe small ferrite coil). I believe it connected to 3V_S5 rails, but the question is could be those rails goes to the load for SoC (CPU+CHIPSET). we don't know yet. Possibly the SoC have shorted.
    The first time I face with this mobo, R391 not totally burn but found it abnormal heat. at least got few data maybe can help for future.
    +5VPCU
    PQ11 D
    PQ8 D
    +3VPCU
    PQ10 D
    PQ9 D
    PQ9 S 3V
    PQ10 S 3V_S5
    PQ8 S 5V
    PQ11 S 5V_5
    PQ11 G pin3 ao6402
    PQ10 G pin3 ao6402
    PQ2 D
    PQ2 G ===== D PQ1
    PQ1 GATE S5_ON
    PQ8 G ===== D PQ3
    PQ9 G ===== D PQ3
    pin8 RT6575
    pin19 KBC
    1256 PQ10 ao6402
    pin18 RT6575
    1256 PQ11 ao6402
    Jumper pad (RTC_RST# AND SRTC_RST#)
    G1 ===== R142
    G3 ===== R150 ?
    Q11 G (AO3413) ===== Q10 D
    R122=100K
    PQ10 S ===== R391
    R391 (0) ===== R394 (10K)===== DNBSWON
    check this link:
    http://*******/viewtopic.php?f=54&t=44108
    https://www.elvikom.pl/toshiba-l50-b...ja-t45158.html
    • angel611
      • Jun 2018
      • 7
      • sardegna
      sorry for my ignorance, but what is KBC in this motherboard?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        kbc in this mobo id 128pin chip marked NUVOTON.
        • mirjana
          • Jun 2015
          • 26
          • Serbia
          I have the same problem. Any solutions?
          • balobi
            • Jan 2015
            • 88
            • phillippines
            i have same issue here with white light but when you press power button it won't turn on.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3628
              • slovakia
              check this link:
              http://********/viewtopic.php?f=54&t=44108
              Yes it was resistor and he replaced it with capacitor
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3628
                • slovakia
                check all coils for short, voltage and voltage when start
                • Am0rPHiA
                  • Nov 2011
                  • 31
                  • Greece
                  same problem here, any ideas?
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    plugging this coil into the touch socket of the HP socket causes the processor to burn out.
                    I'm not happy to be so strong. because it's not humanly
                    • Nen_11
                      • Jun 2021
                      • Sri Lanka
                      did you solve it?
                      • Vspeed
                        • May 2022
                        • 53
                        • Portugal
                        I had the same board with the same issue. I can also say how it's caused, I caused it to a perfectly perfect working computer.
                        The problem is caused by plugging the speaker connector in a nearby socket (cn18) that has the same pin count as the speaker one but it's actually for plugging the screen backlight connector for maybe a different model screen. Toshiba left this connector on the board but without anything connected.
                        When connecting the speakers to it, you will burn the CPU integrated intel graphics card and also that resistor and maybe something more. I'm now trying to figure that out.
                        Here is what I did till now.
                        Replaced that resistor with a new one.
                        Replaced the original CPU i7-4500u with a i7-4510u (not sure if I need to edit the bios somehow for it to boot with the new CPU)
                        The PC now powers up and stays on, it has fan spin for 5s, but there is no picture. Not in the laptop screen and also nothing via HDMI.
                        Any hints»
                        • Stevedb
                          Stevedb
                          • Feb 2018
                          • 624
                          • Belgium
                          Does the capslock react on external keyboard?
                          • Vspeed
                            • May 2022
                            • 53
                            • Portugal
                            Can't test it now
                            Just lost one component last night to the 5th dimention. Took it out to check if it was bad or not, and just lost it. I know it's responsible to convert 12v to 3v or 3.3v... It's not turning on now.
                            It's PQ10
                            Anyone knows it's reference?
                            if not, I just ordered another broken board to have some components to replace
                            edit: just found it's a ao6402. it's actually some posts above and the schematics that are not exactly for this model, point to the same component
                            • reformatt
                              • Feb 2020
                              • 1519
                              How is no display “perfectly perfect”?
                              • Vspeed
                                • May 2022
                                • 53
                                • Portugal
                                Maybe I was not clear.
                                The laptop was working fine. I took it apart to replace the hinges and though of taking the board out to give it a clean. The problem was caused by me when assembling it back as I plugged the speakers in the connector for the LCD backlight. The laptop had no power after this and the CPU/intergrated GPU was in short. Also the resistor marked R391 responsible to provide 3V to the CPU and maybe something else was burned.
                                Replaced the resistor and the CPU with i7-4510u
                                Anyway, I found the AO6402A that was in the 5th dimension and
                                just executed the ME cleaup procedure and have the same behavior
                                5s fan spin
                                it stays on until I keep the power button pressed for some seconds
                                The CPU and dedicated GPU heat up
                                edit: the fan just kicked in after 1m. so, it's at least detecting it's getting hot.
                                could the dedicated GPU be dead somehow and this is what is causing no picture? I don't measure any short in it and it's getting 1V
                                • Vspeed
                                  • May 2022
                                  • 53
                                  • Portugal
                                  just to update this topic.
                                  The laptop is again working fine after replacing the CPU i7-4500U with i7-4510U, replacing PQ10 (AO6402A) and the R391 (0ohm) and doing ME cleaning (https://www.badcaps.net/forum/showpo...41&postcount=3)
                                  My mistake was I was using a DDR3 memory module instead of a DDR3L. The laptop is booting fine and maybe it was even without cleaning the ME.
