My motherboard was working just fine yesterday. Today when I went to turn it on it would not post and will stay in QCode 00. I am new to electronics, so if someone could help me to troubleshoot the board I will really appreciate it. Where I live it is impossible to have it repaired for an expert
Asus x99 A2 motherboard won't turn on and stays at QCode 00
by glovecapsHello,
The reason for wanting to do this is that the keyboard isn't working as it should, and I think this... -
by dhenionI'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
The original board was:
ASUS X510UNR REV 3.0 A
The replacement board is:
ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...1 Photo -
by momakaHere’s another motherboard that needed a full recap: an ASUS P5GC-MX.
This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
So here is what the motherboard looked like with its original caps:
CPU VRM area up close…... -
by Ross KohlerDetails contained in these two reddit posts: https://www.reddit.com/r/Electronics...rboard_repair/ and https://www.reddit.com/r/Electronics..._super_io_chip
I've been attempting a repair of an Asus TUF H370 Gaming Motherboard. It fails to react to the power button being pressed, there's a debug light which confirms that there's standby power to the board but after any attempt to power on the components there's no sign of life. I've started my diagnosis and I know that the power-on... -
by lezsimplyHello Everyone and Good Day,
I've got an issue with this desktop motherboard. It does not power on, Asus Prime H310M-A R2.0. I tested 33ohms reading on 3v line on the ATX connector. It beeps on continuity mode. I tried injecting voltage from 0.9v at 1.5amps and no current being drawn. I raised the voltage to 3v @ 4amps and now I only get 22mA on current. I checked with thermal camera and there is no part heating up. I'm afraid of going further the safe voltage. What could possibly causing the line to be shorted. 5vsb has no short. I get 0.9v on positive pin of power switch. There's... - Loading...
