LA-B921P Yoga 3 11 - No power
  • magneh
    • Apr 2014
    • 588
    • Portugal
    Hi
    I have a Yoga3 11 inches with no power.
    I managed to find the schematics, here in att.
    I have no voltages in any of the main coils, and no shorts.
    When charger connected I get 5V as you can see on the image here.
    But 0V at VIN, diode mode to ground 2.33V there, seems too high...
    Resistance to ground 256kohm
    What would be the approach here?
    Are the 5V normal on these ? and then they boost to 20v?
    Kinda confused with this particular one, and I see the charger is rated to 5V and 20V.
    Board had no liquid damaged. One burned component,U52 . Removed it , its USB 3.0 port related, and no shorts in any pins,
    Any guidance is appreciated! thank you
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3586
    • slovakia
    Re: LA-B921P Yoga 3 11 - No power
    JDCIN looks like a normal usb connector, with data lines and id line, so 5V is normal
    but on other page VIN is regular 19V with bq charger ic.
    it is really weird
    • brew99
      • Jan 2019
      • 132
      I think you need to concentrate on the VIN section (page 27), and ensure you get your 19V rail. Not exactly sure what that JDCIN1 section is, but it's not boosting, just enabling 5Vusb power.
      • khaahk
        • Dec 2013
        • 763
        • Estonia
        check esd protection diode, pd105.
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Mita99
          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
          by Mita99
          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
          04-27-2025, 07:20 PM
          by sam_sam_sam
          03-31-2024, 02:12 PM
