Asus k55 Cpu V-core short with cpu in and not without it
  • Kiop
    • Nov 2018
    • 28
    • France
    Hello
    I've got that strange issue the laptop boot for a few second and turn off , i checked the power rail and Cpu V-core wasn't there i removed the cpu and i tried again and i got Cpu V-core rail but i'm guessing without the cpu the laptop is not going to work not happening right ?
    So it could be a short cap , but i can be also something else wich is connected to the cpu but not near the cpu area ...
    As there is a lot of pin and trace connecting the cpu to the rest of the mobo .
    So what can be the problem and how to check it .
    This is not a obvious short to ground ...
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Asus k55 Cpu V-core short with cpu in and not without it
    Originally posted by Kiop
    Hello
    Without the CPU will not work when you say boot up does it go’s to BIOS
    With out the CPU V CORE coil voltage?
    • Kiop
      • Nov 2018
      • 28
      • France
      Hello
      No is not going to the bios ,
      Yes no cpu on the socket , i got Cpu V-core on the coil and no short to ground .
      And with cpu on the socket no Cpu V-core on the coil and i got short to ground and if
      press the power buttun the laptop start a few second and stop .
      • brew99
        • Jan 2019
        • 132
        Sounds like a short internal to the CPU if there is no short without the CPU in socket. I'm assuming you do not have another CPU to try?
        • Techtiger
          • Oct 2014
          • 1602
          • france
          You should try with a another working CPU like Brew99 say internal short might be the cause
          • Kiop
            • Nov 2018
            • 28
            • France
            Yes i tried it but the Cpu is fine , working on a other mobo , tried also with another cpu same case ...
            My guees is some other part on the mobo wich is connected to the cpu wich become short to ground with the Cpu ...
            But i really don't know .
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Hello
              With cpu in socket you are supposed to get zero resistance on coil-so thats not a indication of short. Without cpu , it should not show short but a preety low reading is likely on vcore coils and thats fine.
              • Kiop
                • Nov 2018
                • 28
                • France
                So may be i wasn't clear if i tried to power up the mobo with a cpu in the socket i got no voltages after the coil of the cpu v-core just 0 volts the mobo tried to start but stop after a few seconds .
                But without a cpu in the socket i got 0.9 volts after the coil of the cpu v-core and the mobo don't stop .
                It's why i think there a short somewhere taking the voltage of th cpu v-core .
                But i really don't know ...
                • Kiop
                  • Nov 2018
                  • 28
                  • France
                  Nodody has encountered the same case because have got also a asus A55 with same symptoms ...
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3607
                    • slovakia
                    it is normal if u have something bad on board. power up process stop before processor voltage is activated
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      nop not yet uplode a pic of the Mob there is a way to test CPU socket one buy one
                      if you have titanium caps in V CORE line change them to give a try
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3607
                        • slovakia
                        titanium caps?
                        • Duranitron
                          • Jul 2014
                          • 544
                          • Philippines
                          just a suggestion do first the basics. bare mobo with memory and lcd screen, replace memory with known good one. if you said there is no cpu v core. look around the cpu power ic section and check around it. it will probably heat up if there is a short.
                          Never stop LEARNING because life never stops TEACHING!
                          • nagkiller
                            Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                            by nagkiller
                            Hello everyone!
                            This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                            After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                            Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                            The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                            I would like some...
                            05-10-2025, 09:19 AM
                          • Victor Moreira Silva
                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                            by Victor Moreira Silva
                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                            Well, my decice specs are the following:
                            Model: Acer Nitro 5 AN517-54-55T5
                            CPU: Intel Core i5-11400H
                            GPU: NVIDIA GeForce GTX 1650
                            Motherboard: GH51G LA-L181P Rev:1c
                            The symptom:
                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                            05-26-2025, 10:49 AM
                          • grimacelord
                            Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                            by grimacelord
                            Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                            After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                            I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                            10-24-2024, 12:31 PM
                          • ktmmotocross
                            Asus UX433FAC - batery dead after short on VIN rail
                            by ktmmotocross
                            Hello.
                            Have this Asus UX433FAC that came with shorted mosfet on main power rail. After replace laptop works ok, but battery is dead. Laptop show charging but voltage on battery is 0.2V. when remove battery voltage on battery connector goes to 8.5V, but when connect battery again it goes down to 0.2V.
                            can that short shorted battery? batmon show that battery is full at 80%
                            12-29-2022, 12:06 PM
                          • joshAU
                            Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                            by joshAU
                            Hi all.
                            This notebook was showing no signs of life.
                            I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                            However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                            If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                            I tried replacing the MOSFET with a new one, but again no voltage on the...
                            05-29-2024, 12:33 AM
