What do you do with a downloaded BIOS dump?
  • brew99
    • Jan 2019
    • 132
    As an example, I want to flash a BIOS dump that was obtained here, or elsewhere, onto a mobo to see if it fixes an issue. Do you guys normally go through the process of clearing the ME region before flashing, or just flash it straight away? Or do you go a step further, and update the bump with the correct DMI info on the board you are working on, then ME clean and finally flash?
    I imagine that a straight flash would atleast give you the idea if it fixes the issue, but then you would normally need to insure all the DMI info is correct and clear the ME region also before giving back to customer/friend, etc.
    What is your normal process?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: What do you do with a downloaded BIOS dump?
    flashing straight away to see if it changes something, or repair the failure
    after that u can clenning, injecting product keys ordo other stuff that needs to be done to work normally.
    • kingiii
      downloaded bios is smaller than the original bios dump
      by kingiii
      Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
      Thank you very much
      06-07-2025, 04:21 PM
    • bestrafer
      Lenovo L460 LAN issue after BIOS dump flash
      by bestrafer
      Hello everyone.
      I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
      BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
      But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
      Could someone point on a direction...
      01-31-2023, 01:14 PM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • grimacelord
      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
      by grimacelord
      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
      Motherboard model number: DA0PAMB46A1 REV: A
      Secondary motherboard model number: 0PAB
      SKU: 685K4UA
      Serial number is: 5CD3223BJP
      Recently reflashed this laptop with latest BIOS and once...
      05-07-2024, 08:06 AM
