No Power ON with battery ONLY
    I want to thank everyone for all the support .. So I have this asus laptop that does not power on with battery ONLY.
    Works fine if adapter is present.
    Shows proper battery charging indication
    If you plug out the charger while the pc is running then also it works fine. Backup is around 3 hours
    But I try to start the laptop without the adapter plugged in it just does not start at all.
    Also I am unable to find the schematic for the same.
    Re: No Power ON with battery ONLY
    Wait a while.
    I grab my crystall ball and tell u exactly what board u have and what is the problem
      Originally posted by ktmmotocross View Post
      Wait a while.
      He forgot to mention the Mob XXXX
        Sorry its a NH4CZ0X Rev 1.0 motherboard used in ACER ONE 14-Z422
        Also the laptop restarts everytime I prefer to shutdown using windows option.
          First you be sure its acer or asus??
            Its Acer
              Anybody please tell me what to check ?
                as first check all pins of charging ic in failure state
                  Thanks by failure state do you mean Ac Adapter not plugged in but the battery is still connected ?
                    it it is your problem than yes
                      discharge fet is ok??
