"#" symbol on sch.
  • brew99
    • Jan 2019
    • 132
    "#" symbol on sch.
    What does this "#" symbol usually at the end of a signal name/function mean on a schematic?
    Sorry just starting out looking at laptops for fun, and can't find this info
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: "#" symbol on sch.
    Most at times it indicates a low signal, a signal to send another signal low e.g SUSP=3.3v but you need SUSP#=3.3V to make SUSP to be 0v
    • BlueMidnight
      • Jan 2015
      • 489
      Logic signals (as opposed to power rails or data lines) communicate answers to simple questions. For example, SLP_S3# answers the question "Are we in an S3 or lower sleep/power state?
      There are two possible answers (true/false). And to represent these it uses 2 possible voltages (often 0V/3V). But which voltage means "true" and which means "false"? That's what the '#' character tells you.
      Plain signal name: 3V = True, 0V = False
      Signal with a '#': 0V = True, 3V = False
      Technically, the former is referred to as an "active high" signal, and the latter as an "active low" one. This is because the first one uses a high voltage to represent a true condition, while the second uses a low voltage to indicate the same thing.
      Sometimes a different character is used rather than "#" (e.g. an "_L" suffix). But it shouldn't be too hard to figure out the method by just glancing around whichever schematic you are reading and using some common sense.
      • brew99
        • Jan 2019
        • 132
        Thanks for that detailed explanation. That really helps
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Thanks for the technical explanation
          • Techtiger
            • Oct 2014
            • 1602
            • france
            • Gibon378
              What caused the BSOD?
              by Gibon378
              Hello there!
              I was doing some usual stuff, browsing the internet, listening to music, coding, etc. and my computer froze. It looked like the website couldn't process the request (logging into the account, there was the loading symbol) and it took a few seconds, then my computer totally froze except for the mouse cursor. It lasted for about a minute and I got the BSOD. It happened yesterday and today (just now).
              I managed to get the MEMORY.DMP content, but I don't really understand it. Could somebody help me?
              Code:
              ************* Preparing the environment for Debugger
              06-23-2023, 06:20 AM
            • AstutePauciloquent
              Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
              by AstutePauciloquent
              Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
              I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
              11-23-2023, 11:02 PM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • JayPoorJay
              Converting +/- 5v to a Usable Hz Signal
              by JayPoorJay
              Good morning.
              I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
              This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
              The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
              08-07-2022, 08:35 AM
            • Scruit
              What is a normal composite signal range for a C64?
              by Scruit
              Hello all,
              Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
              More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
              https://imgur.com/gallery/PpqcqPY
              My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
              More detail:
              Symptoms are that that I get...
              04-28-2022, 05:33 AM
