What caused the BSOD?
  • Gibon378
    Gibon378
    • Nov 2022
    • 13
    • Poland
    Hello there!
    I was doing some usual stuff, browsing the internet, listening to music, coding, etc. and my computer froze. It looked like the website couldn't process the request (logging into the account, there was the loading symbol) and it took a few seconds, then my computer totally froze except for the mouse cursor. It lasted for about a minute and I got the BSOD. It happened yesterday and today (just now).
    I managed to get the MEMORY.DMP content, but I don't really understand it. Could somebody help me?
    Code:
    ************* Preparing the environment for Debugger Extensions Gallery repositories **************
      ExtensionRepository : Implicit
      UseExperimentalFeatureForNugetShare : false
      AllowNugetExeUpdate : false
      AllowNugetMSCredentialProviderInstall : false
      AllowParallelInitializationOfLocalRepositories : true
      -- Configuring repositories
       ----> Repository : LocalInstalled, Enabled: true
       ----> Repository : UserExtensions, Enabled: true
    >>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
    ************* Waiting for Debugger Extensions Gallery to Initialize **************
    >>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.031 seconds
      ----> Repository : UserExtensions, Enabled: true, Packages count: 0
      ----> Repository : LocalInstalled, Enabled: true, Packages count: 36
    Microsoft (R) Windows Debugger Version 10.0.25877.1004 AMD64
    Copyright (c) Microsoft Corporation. All rights reserved.
    Loading Dump File [C:\Users\gibek\Desktop\MEMORY.DMP]
    Kernel Bitmap Dump File: Kernel address space is available, User address space may not be available.
    Symbol search path is: srv*
    Executable search path is:
    Windows 10 Kernel Version 19041 MP (12 procs) Free x64
    Product: WinNt, suite: TerminalServer SingleUserTS
    Edition build lab: 19041.1.amd64fre.vb_release.191206-1406
    Kernel base = 0xfffff801`0f400000 PsLoadedModuleList = 0xfffff801`1002a2d0
    Debug session time: Fri Jun 23 13:43:07.580 2023 (UTC + 2:00)
    System Uptime: 1 days 0:56:08.524
    Loading Kernel Symbols
    Loading User Symbols
    PEB address is NULL !
    Loading unloaded module list
    For analysis of this file, run !analyze -v
    nt!KeBugCheckEx:
    fffff801`0f7fc030 48894c2408   mov   qword ptr [rsp+8],rcx ss:fffffd85`8aec8c80=000000000000003b
    11: kd> !analyze -v
    *            Bugcheck Analysis                  *
    SYSTEM_SERVICE_EXCEPTION (3b)
    An exception happened while executing a system service routine.
    Arguments:
    Arg1: 00000000c0000006, Exception code that caused the BugCheck
    Arg2: fffff8010fa9f3c2, Address of the instruction which caused the BugCheck
    Arg3: fffffd858aec9580, Address of the context record for the exception that caused the BugCheck
    Arg4: 0000000000000000, zero.
    Debugging Details:
    ***  Either you specified an unqualified symbol, or your debugger  ***
    ***  doesn't have full symbol information. Unqualified symbol   ***
    ***  resolution is turned off by default. Please either specify a  ***
    ***  fully qualified symbol module!symbolname, or enable resolution ***
    ***  of unqualified symbols by typing ".symopt- 100". Note that   ***
    ***  enabling unqualified symbol resolution with network symbol   ***
    ***  server shares in the symbol path may cause the debugger to   ***
    ***  appear to hang for long periods of time when an incorrect   ***
    ***  symbol name is typed or the network symbol server is down.   ***
    ***  For some commands to work properly, your symbol path      ***
    ***  must point to .pdb files that have full type information.   ***
    ***  Certain .pdb files (such as the public OS symbols) do not   ***
    ***  contain the required information. Contact the group that   ***
    ***  provided you with these symbols if you need this command to  ***
    ***  work.                             ***
    ***  Type referenced: ExceptionRecord                ***
    ***  (The same message as the one above)  ***
    ***  Type referenced: ContextRecord                 ***
    KEY_VALUES_STRING: 1
      Key : Analysis.CPU.mSec
      Value: 4921
      Key : Analysis.Elapsed.mSec
      Value: 4928
      Key : Analysis.IO.Other.Mb
      Value: 12
      Key : Analysis.IO.Read.Mb
      Value: 2
      Key : Analysis.IO.Write.Mb
      Value: 18
      Key : Analysis.Init.CPU.mSec
      Value: 811
      Key : Analysis.Init.Elapsed.mSec
      Value: 91073
      Key : Analysis.Memory.CommitPeak.Mb
      Value: 133
      Key : Bugcheck.Code.KiBugCheckData
      Value: 0x3b
      Key : Bugcheck.Code.LegacyAPI
      Value: 0x3b
      Key : Failure.Bucket
      Value: 0x3B_C0000006_nt!HvpGetCellPaged
      Key : Failure.Hash
      Value: {68f3db38-ae8e-4bae-c37a-85819946495f}
      Key : Hypervisor.Enlightenments.Value
      Value: 0
      Key : Hypervisor.Enlightenments.ValueHex
      Value: 0
      Key : Hypervisor.Flags.AnyHypervisorPresent
      Value: 0
      Key : Hypervisor.Flags.ApicEnlightened
      Value: 0
      Key : Hypervisor.Flags.ApicVirtualizationAvailable
      Value: 1
      Key : Hypervisor.Flags.AsyncMemoryHint
      Value: 0
      Key : Hypervisor.Flags.CoreSchedulerRequested
      Value: 0
      Key : Hypervisor.Flags.CpuManager
      Value: 0
      Key : Hypervisor.Flags.DeprecateAutoEoi
      Value: 0
      Key : Hypervisor.Flags.DynamicCpuDisabled
      Value: 0
      Key : Hypervisor.Flags.Epf
      Value: 0
      Key : Hypervisor.Flags.ExtendedProcessorMasks
      Value: 0
      Key : Hypervisor.Flags.HardwareMbecAvailable
      Value: 0
      Key : Hypervisor.Flags.MaxBankNumber
      Value: 0
      Key : Hypervisor.Flags.MemoryZeroingControl
      Value: 0
      Key : Hypervisor.Flags.NoExtendedRangeFlush
      Value: 0
      Key : Hypervisor.Flags.NoNonArchCoreSharing
      Value: 0
      Key : Hypervisor.Flags.Phase0InitDone
      Value: 0
      Key : Hypervisor.Flags.PowerSchedulerQos
      Value: 0
      Key : Hypervisor.Flags.RootScheduler
      Value: 0
      Key : Hypervisor.Flags.SynicAvailable
      Value: 0
      Key : Hypervisor.Flags.UseQpcBias
      Value: 0
      Key : Hypervisor.Flags.Value
      Value: 16777216
      Key : Hypervisor.Flags.ValueHex
      Value: 1000000
      Key : Hypervisor.Flags.VpAssistPage
      Value: 0
      Key : Hypervisor.Flags.VsmAvailable
      Value: 0
      Key : Hypervisor.RootFlags.AccessStats
      Value: 0
      Key : Hypervisor.RootFlags.CrashdumpEnlightened
      Value: 0
      Key : Hypervisor.RootFlags.CreateVirtualProcessor
      Value: 0
      Key : Hypervisor.RootFlags.DisableHyperthreading
      Value: 0
      Key : Hypervisor.RootFlags.HostTimelineSync
      Value: 0
      Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
      Value: 0
      Key : Hypervisor.RootFlags.IsHyperV
      Value: 0
      Key : Hypervisor.RootFlags.LivedumpEnlightened
      Value: 0
      Key : Hypervisor.RootFlags.MapDeviceInterrupt
      Value: 0
      Key : Hypervisor.RootFlags.MceEnlightened
      Value: 0
      Key : Hypervisor.RootFlags.Nested
      Value: 0
      Key : Hypervisor.RootFlags.StartLogicalProcessor
      Value: 0
      Key : Hypervisor.RootFlags.Value
      Value: 0
      Key : Hypervisor.RootFlags.ValueHex
      Value: 0
      Key : SecureKernel.HalpHvciEnabled
      Value: 0
      Key : WER.OS.Branch
      Value: vb_release
      Key : WER.OS.Version
      Value: 10.0.19041.1
    BUGCHECK_CODE: 3b
    BUGCHECK_P1: c0000006
    BUGCHECK_P2: fffff8010fa9f3c2
    BUGCHECK_P3: fffffd858aec9580
    BUGCHECK_P4: 0
    FILE_IN_CAB: MEMORY.DMP
    CONTEXT: fffffd858aec9580 -- (.cxr 0xfffffd858aec9580)
    rax=0000000000000000 rbx=fffffd858aec9fd0 rcx=0000000000000007
    rdx=00000000008533f0 rsi=ffffc206944c6730 rdi=ffffb204a18de000
    rip=fffff8010fa9f3c2 rsp=fffffd858aec9f88 rbp=fffffd858aeca089
     r8=000000000000001c r9=ffffc206945e7540 r10=00000268f3ee43f0
    r11=00000000000003f0 r12=0000000000010275 r13=fffffd858aeca230
    r14=0000000000000080 r15=00000268f3ed6afc
    iopl=0     nv up ei pl nz na po nc
    cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b       efl=00050206
    nt!HvpGetCellPaged+0xa2:
    fffff801`0fa9f3c2 418b02     mov   eax,dword ptr [r10] ds:002b:00000268`f3ee43f0=????????
    Resetting default scope
    BLACKBOXBSD: 1 (!blackboxbsd)
    BLACKBOXNTFS: 1 (!blackboxntfs)
    BLACKBOXPNP: 1 (!blackboxpnp)
    BLACKBOXWINLOGON: 1
    PROCESS_NAME: Registry
    STACK_TEXT:
    fffffd85`8aec9f88 fffff801`0fa7229f   : 00000000`00000000 ffffb204`a18de000 fffffd85`8aeca940 00000000`00000000 : nt!HvpGetCellPaged+0xa2
    fffffd85`8aec9f90 fffff801`0fa79ae0   : 00000001`ffffffff 00000000`fa176dee 00000000`00000080 00000000`00000000 : nt!CmpDoCompareKeyName+0x3f
    fffffd85`8aec9fd0 fffff801`0fa1a709   : ffffb204`ac7bb060 00000000`0000000b fffffd85`8aeca1d0 fffffd85`8aeca250 : nt!CmpWalkOneLevel+0x700
    fffffd85`8aeca0d0 fffff801`0fa19c23   : 00000000`0000001c fffffd85`8aeca420 fffffd85`8aeca3d8 ffffc206`98d5a4a0 : nt!CmpDoParseKey+0x849
    fffffd85`8aeca370 fffff801`0fa152ee   : fffff801`0fa19901 00000000`00000000 ffffc206`98d5a4a0 00000000`6d4e6201 : nt!CmpParseKey+0x2c3
    fffffd85`8aeca510 fffff801`0fa0cfba   : ffffc206`98d5a400 fffffd85`8aeca778 00000000`00000040 ffffc206`8b3030c0 : nt!ObpLookupObjectName+0x3fe
    fffffd85`8aeca6e0 fffff801`0fa0cd9c   : 00000000`00000000 00000000`00000000 00000000`00000000 ffffc206`8b3030c0 : nt!ObOpenObjectByNameEx+0x1fa
    fffffd85`8aeca810 fffff801`0fa0c8b1   : 00000000`02abe828 fffffd85`8aecab80 00000000`00000001 fffff801`0f6211fe : nt!ObOpenObjectByName+0x5c
    fffffd85`8aeca860 fffff801`0fa0c5df   : 00000000`02abeca8 00000000`02abecb8 00000000`00000000 00000000`00000001 : nt!CmOpenKey+0x2c1
    fffffd85`8aecaac0 fffff801`0f80f7f8   : 00000000`00000000 fffffd85`8aecab80 fffffd85`8aecab80 00000000`02abecb8 : nt!NtOpenKeyEx+0xf
    fffffd85`8aecab00 00007fff`d784f4c4   : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
    00000000`02abe7c8 00000000`00000000   : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007fff`d784f4c4
    SYMBOL_NAME: nt!HvpGetCellPaged+a2
    MODULE_NAME: nt
    IMAGE_NAME: ntkrnlmp.exe
    STACK_COMMAND: .cxr 0xfffffd858aec9580 ; kb
    BUCKET_ID_FUNC_OFFSET: a2
    FAILURE_BUCKET_ID: 0x3B_C0000006_nt!HvpGetCellPaged
    OS_VERSION: 10.0.19041.1
    BUILDLAB_STR: vb_release
    OSPLATFORM_TYPE: x64
    OSNAME: Windows 10
    FAILURE_ID_HASH: {68f3db38-ae8e-4bae-c37a-85819946495f}
    Followup:   MachineOwner
  • Per Hansson
    • Jul 2005
    • 5897
    • Sweden
    Re: What caused the BSOD?
    You should setup a symbol search path to get more useful information.
    • stormanimal83
      • May 2014
      • 74
      often bsod is caused by faulty hardware as processor or ram but in your case here i think its a driver problem cause your computer doesn´t freeze complete as u got a mouse visible...
      check your drivers, do windows updates and u can also try to install language pack seperately again. could be that it has to do something with this...
      • Gibon378
        Gibon378
        • Nov 2022
        • 13
        • Poland
        My Windows is up to date (22H2) - in fact, I had an update a few days ago.
        Maybe it caused some driver issues.
        When I had the BSOD, the error code was 0xc000000e and the file was \Windows\system32\winload.exe.
        I think I will do as you wrote and check if there are any chipset updates.
        • guyandpit
          Asus tuf fa507r BSOD
          by guyandpit
          Hi there! Need help! its been 2 months finding the cause of BSOD ntoskrnl and other error, this has water damaged before no power, i replaced sio and pwm control for gpu and cpu. It will boot 3 times in BSOD before succesfully boot in windows. I done stress on cpu, gpu and ram no errors found. Any opinion guys with same exprience? Thank you see attached bsod error
          05-09-2025, 11:46 PM
        • alleotechno
          HP Omen RTX2060 BSOD while nothing presure on CPU
          by alleotechno
          Details:
          Model : Omen HP Laptop 15-DH0038TX
          Serial Num : CND93433LW
          Product ID : 7LJ89PA#UUF
          Bios Version : AMI F.53 4/24/2024 (8600)
          Laptop Input Voltage : 19.5Vdc | 10.3a
          My Adapter Charger : Original HP 200Watt 19.5V | 10.3a
          My laptop keep on blue screen after 10 second successfully windows loaded, BSOD while installing new windows and cannot windows update, if update ask me to perform to restart and the laptop will BSOD while installing the update.
          The blue screen comes after nothing stress/pressures my CPU not GPU. I need to use...
          02-04-2025, 10:37 PM
        • alambrose
          LG GRAM random bsod SOLVED
          by alambrose
          LG Gram 15Z980 picked up on Ebay for $200 (was sold as parts because no M2 drive and bios pw locked), but otherwise intact and working.
          Threw a 500gb M2 in, and was able to install Windows. On Gram, Win activation is stored in the bios, so Windows was automatically activated. I still kept getting random bsod's. Also bought a pw and unlocked the bios.
          Upgraded Windows to 11, still didn't solve the random & frequent bsod's. Cleaned & reseated all cables, RAM, etc... still getting frequent bsod's. Bought & installed a new stick of RAM, still getting frequent...
          02-12-2023, 06:12 PM
        • the Benninger
          Vostro 14 3468 w BSOD KernelPower aleatory
          by the Benninger
          HI Folks, I have a problem randomly a BSOD screen appears in the event viewer indicates KernelPower failure, discard the source/memory and SSD, only the battery is in bad condition, it will be possible that the battery is causing this BSOD event , I mention it because the times he gave BSOD he happened to have the battery installed, and last Friday it ran all day without the battery installed and didn't generate any events
          At the moment I am checking the mosfets and voltges in general everything seems to be perfect on the main board
          Vostro 14 3468
          CPU: Core...
          04-29-2024, 08:54 AM
        • Fejroo
          PC gets BSOD when Secure Boot is on
          by Fejroo
          When I switch Secure Boot on in BIOS settings PC gets crashed with BSOD "kmode exception not handled 0x1e" after ~5 minutes of working.
          Specs:
          ASROCK H110M-HDV
          i5-6500
          GTX 1060 6GB
          16GB(2x8GB).
          With secure boot turned off everything working fine.
          Any ideas?...
          10-11-2026, 01:17 AM
