Is my Laptops Hard Drive on it's Way Out? (4 Year Old Samsung ST1000LM024)
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Is my Laptops Hard Drive on it's Way Out? (4 Year Old Samsung ST1000LM024)
    Copy/paste the whole SMART report. Dunno how you get that on Windows, but on Linux you get the full report with `smartctl -a /dev/sda`. Gives you all the drive info (model, capacity, firmware, etc…), all the SMART values, the SMART error log, and the previous tests ran on the drive. Easy to spot if something is wrong with all that.
    Also good to run a hard drive speed test on the whole drive to know if the drive has any issue reading some regions. (I think HD Tune is good for that)
    • RJARRRPCGP
      • Jul 2004
      • 6301
      Originally posted by ruky con
      I only use under 1/3 of the 1TB.
      Then you can shrink the partition and thus have lower random seek latency, in ms.
      Every spinner hard drive pro shall know that random-seeking the whole shebang of a 7K'er or similar of today, would usually be at best, 12 ms, maybe down to 11 ms, if very lucky!
      That's why spinner hard drive pros who RAID-0, are known to use tiny partitions. Especially for the OS and the most frequently used game, if all the game data can fit along with the OS.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • RukyCon
        A Fake Rubycon
        • Jan 2017
        • 816
        Re: Is my Laptops Hard Drive on it's Way Out? (5 Year Old Samsung ST1000LM024)
        So i know it's been about a year since i last posted in this thread, mostly because i had convinced myself that it was not about to fail and that i was a for thinking it would (among other things).
        However, a few things happened recently that had led me back to here. I'll spare the details as i imagine i'm likely overthinking things again (something i'm very good at) so if i'm wrong, i won't waste everyone's time.
        I hope this is all people need to tell me that i'm wrong (which i probably am).
        I'm not a expert, I'm just doing my best.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3553
          • slovakia
          who r using standard discs for system this time?
          I throw to bin all of it. SSD are so cheap this time and it is so fast
          • TechGeek
            Computer Geek
            • Jan 2015
            • 2254
            296 failed calibration attempts? That's a sure sign that it's not long from failing. Backup, wipe it, and use it as target practice. Or run it into the ground.
            Permanently Retired Systems:
            Kooky and Kool Systems
            sigpic
            • RukyCon
              A Fake Rubycon
              • Jan 2017
              • 816
              I'm surprised i did not notice that (though i probably shouldn't be), as i was researching every parameter that seemed "off" to see if i was overthinking things again (maybe i was too focused on the Raw Read Error Rate, which i heard was also a sign of near failure).
              Anyway, i ordered a new SSD yesterday 'just in case', but it looks like i might be needing it sooner than later.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8665
                Dang I'm still using a hard drive that has lots of sector reallocates, and still using it.
                Give your old HDD to me, I'll happily use it!
                • RJARRRPCGP
                  • Jul 2004
                  • 6301
                  Seagates usually display raw values for the "Raw Read Error Rate" attribute! Even brand new Seagate HDDs that aren't bad!
                  Arc A770 16 GB
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1865
                    • Romania
                    #29
                    "ST"-> Probably a Seagate with the Samsung name slapped on it! And Seagate 2.5-inch HDDs, apparently have major issues! With extreme slowness probably being common.
                    Just like Maxtor earlier, where their name was slapped on Seagate HDDs, probably at or roughly 5 years before Samsung had the same kind of fate!
                    WD suffers from this also. I have three failed 2.5" WD drives with the same issue. One is a 320GB Black, the other two are both Blue, one 500GB and one 640GB.
                    Main rig:
                    Gigabyte B75M-D3H
                    Core i5-3470 3.60GHz
                    16GB DDR3-1600
                    Samsung SH-224AB DVD-RW
                    Delux MG760 case
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      So now i have my new SSD on hand, ready to install, but the SeaSung (or SamGate?) HDD is playing good drive again, however i'm going to replace it anyway as next time it pulls something stupid off, it might be fatal, and my PC has been acting slow lately after the initial freak out.
                      But instead of killing it, i may just turn it into a backup drive and let it live out the rest of its days as one until it dies, then replace it with something better.
                      I did a drive test with Seatools (Seagate's proprietary drive testing software) and it tells me the HDD is OK, but i still don't know if i fully trust it, thought i'd point that out.
                      • elrefaey_mahmoud
                        • Mar 2013
                        • 14
                        • egypt
                        #31
                        SSD disks are now more useful than HDD
                        • TechGeek
                          Computer Geek
                          • Jan 2015
                          • 2254
                          Running slow? Yep, it's on it's way out. It's likely accumulating bad sectors and massive amounts of read errors. It's already got a high number of write errors. Retire the drive from service permanently and do not trust it with important data.
                          sigpic
                          • RukyCon
                            A Fake Rubycon
                            • Jan 2017
                            • 816
                            Out of Service 5 Year Old Samsung ST1000LM024
                            So i was logging some S.M.A.R.T attributes to see if i could spot any immediate degradation, however, some logs got corrupted when my PC randomly crashed for no real reason.
                            Not that those matter anymore because...
                            The hard drive has been taken out of service, and it will most likely not be going back into service anytime soon.
                            • TechGeek
                              Computer Geek
                              • Jan 2015
                              • 2254
                              That is 115% a Seagate drive. It's not even a half-decent drive. It's an infamously bad Momentus series drive. Had one of those catastrophically fail before the 2 year mark.
                              Know why it's called Momentus? Because it only lasts a moment!
                              sigpic
                              • RukyCon
                                A Fake Rubycon
                                • Jan 2017
                                • 816
                                The fact that it has the Seagate name listed a couple of times seems like a dead giveaway to who made it.
                                I guess my drive really wanted to keep me on my toes for a nasty "surprise" given how long it lasted. But it took too long and now it won't be able to pull off anything stupid as it has been taken out of service.
                                But now i wonder if i should even use it as a backup drive, given how clumsy it was with my data (like files getting corrupted or lost randomly), my guess would likely be a big NO.
                                • TechGeek
                                  Computer Geek
                                  • Jan 2015
                                  • 2254
                                  Don't use it with anything important for the rest of it's life. My personal policy with failing HDDs is that once they start accumulating read and write errors, it's queued for immediate replacement, the system or drive in question is immediately backed up and the failing drive is wiped and permanently retired from service. As someone who's lost data twice to drive failure, I've come to recognize the signs of a drive in trouble. So the moment a drive starts accumulating R/W errors, condemn it and replace it.
                                  sigpic
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    #37
                                    If you're waiting until the drive starts accumulating errors before backing it up, you're doing it wrong.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8665
                                      I use until they die... of course backups are paramount and only error read rate determines replacement...
                                      That is, only out of warranty drives. If under warranty, then they get replaced right away...
                                      • TechGeek
                                        Computer Geek
                                        • Jan 2015
                                        • 2254
                                        I back 'em up regardless of failure status. Usually once a week with full encrypted disk images, which protects against total disk failure, catastrophic FS or LUKS container damage, or total loss of the contents of the disk. Most of the machines that I get in for service that leave with new HDDs were systems with drives that were accumulating bad sectors and massive amounts of I/O errors.
                                        sigpic
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                        • tmcw
                                          PC case - Hard drive rails
                                          by tmcw
                                          A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                                          So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                                          I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                                          Now, the case is a CiT Gaming Case, and...
                                          05-22-2022, 12:04 PM
                                        • madura2010
                                          DAY11AM6E0 hard disk drive and optical disk drive not detected
                                          by madura2010
                                          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                          i checked the connectivity of ribbon=good communication with hard and motherboard
                                          changed hard disk and checked=3f0 error persist
                                          sata power=+5v available
                                          Then checked data capacitors=all good
                                          Then checked data lines path connectivity to pch=all good
                                          reflashed...
                                          03-12-2023, 09:09 AM
                                        • ash91
                                          Hp pavilion 15 not detect hard drive
                                          by ash91
                                          Hello gentelmen .... this is my first post and sorry for my bad english,
                                          so my proplem is my laptop keep losing hard drive even if i but the
                                          hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                          when i turn the laptop on the massage that said no boot media found pop on
                                          the hard disk is fine and to be sure i try another hard
                                          i also update my bios to the last update
                                          the 5 volt is present on the hard connector on the motherboard
                                          the dvd rom work fine when i but a windows dvd in it
                                          also when i boot from flash...
                                          06-07-2023, 01:45 PM
                                        • reformatt
                                          Intel iMacs, 3rd party SSD failures and Fusion setups
                                          by reformatt
                                          I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                          As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                          So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                          12-18-2024, 10:34 PM
