Chuwi Lapbook 14
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    Chuwi Lapbook 14
    I have this notebook with this problem - laptop start , but without picture, only Black screen also on hdmi output. I can't found any schematic for this chines laptop.
    But I don't have voltage on one coil. There Is a driver chip 208 - smd code. Know someone this IC? Thanks
    • 21922
    Re: Chuwi Lapbook 14
    Check the keyboard ribbon cable,and connector, it looks like it may have some damage.
    • DeniS182
      • Jun 2014
      • 328
      • Slovakia
      Ribbon cable is ok , power Button is on keyboard and works fine. But connector is broken little bit I fix it with hot glue.. also lock on connector for lvds cable is missing , but problem is not here.
      • DeniS182
        • Jun 2014
        • 328
        • Slovakia
        up
        • chth96
          How can I test coil whether it is really broken or not?
          by chth96
          I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
          I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
          I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
          I want to replace this round black fuse and unidentified coil if it got broken.
          02-20-2024, 01:07 AM
        • waterchill
          What part is this coil from a MacBook A2681 ?
          by waterchill
          Hi everyone
          I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
          So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
          IAny ideas? It is from a MacBook A2681
          Thank you...
          08-08-2024, 01:46 AM
        • kalemaroni
          Chuwi MiniBook X N150 SU_DNN20_MB_V21_20231024A Missing component ID
          by kalemaroni
          This component (red rectangle) I was trying to build a trace to completely disintegrated. It looked just like the one in the green rectangle (dark top, white underside) which is a 100k resistor. Does anyone recognise this circuitry layout and can give a clue as to what component I should put there?
          Thanks in advance.
          10-14-2025, 10:49 AM
        • Gjackson
          ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
          by Gjackson
          Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
          01-13-2024, 10:34 AM
        • chth96
          How Can I identify IFT coil?
          by chth96
          I have a CD unit which is came from saturn game console.
          It always perceived Any retail CD or CD-R as Audio-CD.
          Of course I changed laser head and adjust pot of laser head nearby, but It always failed to perceive as saturn game CD.
          I think that this problem probably begins When I tighten IFT coil too hard with small screw driver and suddenly I heard some kind of snap or cracking sound
          I desoldered this IFT coil and It is 7pin IFT coil and written "4120 009 62VK" on the surface.
          Is there any way to identify its frequency in order...
          11-11-2022, 05:31 AM
