Chuwi MiniBook X N150 SU_DNN20_MB_V21_20231024A Missing component ID
  • kalemaroni
    • Jun 2016
    • 189
    This component (red rectangle) I was trying to build a trace to completely disintegrated. It looked just like the one in the green rectangle (dark top, white underside) which is a 100k resistor. Does anyone recognise this circuitry layout and can give a clue as to what component I should put there?
    Thanks in advance.
    Click image for larger version  Name:	chuwi.jpg Views:	0 Size:	578.9 KB ID:	3744919
  • kalemaroni
    • Jun 2016
    • 189
    I used the same 100k resistor that was next to it and it worked.
    • kalemaroni
      by kalemaroni
      Looking for schematics/boardview for this board. Many thanks in advance
      10-13-2025, 09:17 PM
      Samsung P-N150-JP05UK Netbook Specification for Upgrade or Repair
      This specification for the Samsung P-N150-JP05UK Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P-N150-JP05UK boardview and P-N150-JP05UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
      09-06-2024, 05:27 AM
    • salawayon
      CHUWI MiniBook X BIOS
      by salawayon
      TYPE: CWI558
      SN: ZMINBXHY4H240500100
      Board: SU_DNN20A_MB_V10_20231018A
      backup attached with no display issue. maybe someone could repair the attached file. thanks...
      06-22-2025, 09:55 PM
    • ugamazing
      820-02020 PPBUS_AON missing
      by ugamazing
      Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
      Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
      02-05-2025, 04:21 PM
    • gurj1979
      Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
      by gurj1979
      Hey guys.
      Need help with this one.
      Fan not spinning due to missing PWN Fan signal.
      Also 5 seconds from powering up it freezes, unless in BIOS.
      But as soon as Windows starts to load, it will freeze.
      CPU is COLD / Room temp when it freezes.
      I've replaced the CPU, same problem.
      Replaced SIO/KBC IT8987e and reprogrammed - same problem.
      Replaced fan - same problem.
      Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
      Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
      08-19-2024, 05:22 PM
