DORO phones
    • 31255
    DORO phones
    any opinions - they look overpriced for the spec.
  • petehall347
    • Jan 2015
    • 4442
    Re: DORO phones
    looks not bad for 28 quid .. https://www.doro.co.uk/doro-1360.html
      • 31255
      Re: DORO phones
      i was talking about the smartphones.
      8035 / 8040
      £179-200
      • chinhang899
        KORG Piano Keyboard: Low Phones/Line Out help
        by chinhang899
        Hey everyone!
        My KORG iS50 has a volume issue where the internal speakers are only acceptable above ~50% on the master slider. What's worse is that the headphone (phones out) and line outputs are extremely quiet, even at max volume. Both left and right channels are equally affected.
        Here's what I've checked:
        Voltages: Vcc to DAC section measures ~5V, MUSB (mute pin on the DAC) measures ~4.xxv, and the 2 op-amps show ~9V
        Master Volume Slider: Resistance ranges from single-digit Ω to ~11kΩ (seems functional).
        Visual Inspection: Capacitors on the main/speaker...
        04-23-2025, 12:25 PM
      • Dreigas
        Laptop, Bios and some phones schematic database
        by Dreigas
        About a year ago, I was struggling to find schematics whenever I needed them. As a programmer, I saw an opportunity and wrote a few scripts to automatically gather a large database of them. Today, I've decided to share it with everyone, because good things should be accessible to all.
        What's included? Over 14,000 laptop schematics, as well as some BIOS files, and about 1,000 phone schematics.
        Everything is compressed in a RAR format and is over 140 GB. (Since it's such a large file, your browser might show a warning.)
        I plan to host the...
        08-20-2025, 09:58 AM
      • kalemaroni
        Opinions on particular soldering iron tip maintenance product
        by kalemaroni
        Has anybody tested this product? Posting this question on a Facebook tech group I'm in got a few responses like "that kind of thing corrodes the tips" and "just using normal solder paste is much better" so I'm not looking for generic responses like that, but rather, does anybody know for certain whether this exact product is good or bad for soldering iron tips?
        04-12-2024, 03:52 AM
      • RetroComputingGrotto
        Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
        by RetroComputingGrotto
        I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
        As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
        What is your advice/opinion on whether or not on old(er)...
        04-03-2024, 08:30 AM
      • CapLeaker
        Poly VVX-250 VOIP POE problem not booting fix
        by CapLeaker
        I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
        Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
        11-25-2023, 10:46 AM
