KORG Piano Keyboard: Low Phones/Line Out help
  • chinhang899
    • Jan 2019
    • 5
    • Hong Kong
    Hey everyone!
    My KORG iS50 has a volume issue where the internal speakers are only acceptable above ~50% on the master slider. What's worse is that the headphone (phones out) and line outputs are extremely quiet, even at max volume. Both left and right channels are equally affected.
    Here's what I've checked:
    Voltages: Vcc to DAC section measures ~5V, MUSB (mute pin on the DAC) measures ~4.xxv, and the 2 op-amps show ~9V
    Master Volume Slider: Resistance ranges from single-digit Ω to ~11kΩ (seems functional).
    Visual Inspection: Capacitors on the main/speaker boards look intact, no obvious damage.
    Since the signal to the speaker amp taps from the headphone output circuit, I suspect the issue lies on the mainboard before this split?
    Question:
    What specific measurements or components should I check next to isolate the fault?
    Any guidance on this would be greatly appreciated!
    Thanks!
    Attached: pic near the output area on the mainboard, speaker amp board and the schematic.​
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Hmm… can you elaborate a bit more on how this happened? Did you loose volume slowly over time or was it an all of a sudden type deal? Are the left and right channels equally in volume? What happens if you feed audio into the input channel?
    As for tools, I suggest you borrow an oscilloscope from a friend and then work you way backwards trough the amplifying stages.
    All the left and right audio starts at IC30. I guess I would first establish if all voltages from various power rails are present and correct voltage reaches each IC involved in that audio chain. I see that each amplifier IC has each a series capacitor for their left and right channels. Now if these in series electrolytic capacitors go bad (high ESR) they will cut the volume down over time and you end up in low volume too.
    • lotas
      • Jan 2016
      • 4900
      • Russia
      Также проверьте, что происходит с сигналом «MUTE», возможно, транзистор протекает...
        • 31296
        c151 opamp damper,
        or Q7 master MUTE control transistor are good places to start
        • chinhang899
          • Jan 2019
          • 5
          • Hong Kong
          Originally posted by stj
          c151 opamp damper,
          Thanks for the input! I picked up this keyboard at a flea market, so I'm not sure how or when this issue came up. This model (iS50) doesn't have an audio input—only the iS40 does—so those dotted lines in the schematic don't really apply to me. And yeah, both the left and right channels are definitely the same volume. I'll check the voltages again while I'm waiting for my ESR meter to arrive.
          As for Q7 and the mute circuit: when I tested that transistor, it showed some weird values compared to Q1-Q6 (which are NPN), so I took it out to see what would happen. But the problem still happened, even without the mute circuit. I tested Q7 out of circuit and found it was normal (as PNP).
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            With an oscilloscope problems should be easy to find, as you can see where it is amplifying or loosing gain.
            • karthur
              Vizio D65x-G4 Volume changes on its own
              by karthur
              On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
              It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
              06-05-2025, 08:13 AM
            • freethink
              Kenwood KR-A70 Receiver Balance changes with volume controls?
              by freethink
              I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
              11-23-2025, 07:53 PM
            • crackedprint
              Sony HCD-HX80R Amplifier Volume Control Problem
              by crackedprint
              I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
              I have tried a Cold Reset as per the service manual.
              I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
              I have looked all the way through the service manual and tried many online...
              01-21-2025, 12:18 PM
            • cubytus
              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
              by cubytus
              Hi to all,
              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
              01-10-2024, 01:26 AM
            • BigOof
              Marantz SR5007 popping on volume change and mute in Direct Mode
              by BigOof
              I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
              12-12-2024, 06:15 AM
