Macbook 820-3115 The keys "ASDFGHJKL" do not work
  • mattpd
    • Oct 2012
    • 301
    Macbook was originally stepped on and bent. Case and KB was replaced, but ASDFGHJKL keys do not work. I tried another brand new KB and I have the same problem.
    I assume a broken trace or solder joint since it was stepped on.
    But every pin on the KB connector has continuity to U5701. Triple checked.
    Is there anything else other than KB connector and U5701 I should be looking at?
  • mielta
    • Apr 2015
    • 368
    Re: Macbook 820-3115 The keys "ASDFGHJKL" do not work
    Hi
    I Think U5701 is defect
    • mattpd
      • Oct 2012
      • 301
      Originally posted by mielta
      Hi
      Ok thanks. I will try to swap.
      • astroboypaul
        Macbook A1932 Some Keys Not Working
        by astroboypaul
        Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
        Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
        06-10-2024, 05:32 AM
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • obelix24
        A2941 Macbook air 15” - 5V 0a
        by obelix24
        I’m working on one macbook air 15” m2 that was water damaged.
        keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
        i’ve put macbook in shelf and order new screen so i can fully repair it.
        Now i got the screen and macbook stays at 5v 0a.
        i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
        i don’t have schematics so i don’t know where to start can someone help me?...
        03-27-2025, 01:19 PM
      • TheJeanox
        HP x360 14-CD Laptop 3 keys not working (G/H/ESC/) Help please!!
        by TheJeanox
        The laptop suffered a liquid spill which caused the keyboard to be damaged (the liquid did not reach the motherboard).
        I bought the replacement part, when I tested it before assembling it I realized that the aforementioned keys do not work but the keyboard is fine, it was tested on another computer and indeed all the keys work.
        On pin #32 of the keyboard connector there is a voltage of 3v, when pressing the keys that do not work the voltage drops to 1.3v~1.5v but if I press any of the keys that do work the voltage does not drop, at this point I can no longer understand...
        11-07-2024, 12:40 PM
