Macbook A1932 Some Keys Not Working
  • astroboypaul
    • Jan 2023
    • 5
    Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
    Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left arrow, down arrow, (right) option, fn
    I'm suspecting some more liquid damage exists that I missed. Could damage to a single trace on the keyboard affect all the above keys at once?
  • mon2
    • 16564
    Yes. Keyboard scanning works in scanning rows & columns of contacts so if a single trace is broken then a group of keys can fail.
    Suggest to replace the keyboard. Plan B is to trace where this mystery component ends up by scraping off the component edge glue / protective sealer with a low heat. Then perform point to point (diode mode should be ok) tracing between the pad and the I2C expander IC that is nearby.
    The datasheet for the IC is available:
    PCAL6416A - Low-voltage translating 16-bit I2C-bus/SMBus I/O expander with (nxp.com)
    • bouch
      unlock macbook air A1932 2019
      by bouch
      hi
      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
      I need help or information?
      Does anyone have the minat2 activator 1.4 software?
      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
      Thank yo...
      03-12-2025, 10:14 AM
    • Boardview and Schematic Bot
      Apple MacBook Pro 13 M1 820-02020-A 820-02020 Boardview and Schematic
      Apple MacBook Pro 13 M1 820-02020-A boardview 820-02020 V1.0 Boardview
      Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB
      Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Physical scanning image
      Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Location map...
      06-20-2026, 10:11 AM
    • bystry326
      MacBook Air 2019 A1932
      by bystry326
      Hi guys need some help on this Macbook
      History of the fault :
      There has been a some sort of power spike or short on one of those rails PP5V_G3S or PP5V_MAIN_ALSCAM_F . They are connected together via L8570 Inductor with was completely blown away from the board as well as small amount of trace.
      I replaced the inductor and repair the track turned the MacBook on and noticed stray away it was warm . Camera still didn't work at this point so back with multimeter and found the LCD flex cable had a short . Replace with new one and the camera came back to live...
      01-12-2026, 09:43 AM
    • thuygsm
      Macbook A1932 cpu very hot
      by thuygsm
      Hello everyone!
      I have a MacBook A1932, powered on with 20V, 0.60A, 12.33W (no battery, only the motherboard).
      1. The Caps Lock does not light up, and the trackpad does not respond.
      2. When plugged in, there is a sound.
      3. The CPU gradually heats up to about 100°C.
      4. After about 2 minutes, the CPU's temperature decreases gradually, with 20V, 0A, 0W....
      07-02-2026, 08:31 AM
    • nikolayu
      MacBook Air A1932 internet recovery loop
      by nikolayu
      I have A1932 that is going to internet recovery every time.
      i tried nvram and smc reset but it looks that MacBook is not reacting to that.
      i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
      keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
      also won’t open option to boot from usb device.
      and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
      07-22-2025, 02:55 AM
