hp 2000 -2d11sx white screen problem
  • Romy2018
    • Sep 2018
    • 174
    • japan
    ohayo gozaimas, I am new to this forum and need help to fix this laptop model HP 2000-2D11SX board id:6050A2493101-MB-A02.the proble is laptop boots fine then a second it turns white screen, I test the screen panel and its working fine on the other laptop.I connect external display the laptop display fine, but when connected to internal display it shows white screen but the screen is fine.Anyone can help me guide to fix this please i dont have schematic for this model.please help me
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: hp 2000 -2d11sx white screen problem
    have you tested the LVDS cable separately?
    • Romy2018
      • Sep 2018
      • 174
      • japan
      yes i tested with different screen using the same lvds but still the same issue sometimes it boots ok without showing the white screen but after shutting down and turn on again it becomes white screen again.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        I meant testing the LVDS cable using another mainboard or testing the current mainboard using another LVDS cable.
        • Romy2018
          • Sep 2018
          • 174
          • japan
          thanks for the response caspian.i did not tried it because i dont have same board to test and no other lvds cable.I only tried test using different screen using same lvds cable but on the other screen there is no problem.
          • Romy2018
            • Sep 2018
            • 174
            • japan
            Is it possible that this white screen cause of lvds cable?
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              yes, the most probable suspect is a bad LVDS cable or the LVDS cable is not plugged in properly. But, it is also possible that the LVDS cable be healthy and the mainboard has problems.
              • Romy2018
                • Sep 2018
                • 174
                • japan
                @capian i confirmed its mainboard issue because i replaced new lvds cable i got from a working laptop with the same model replaced it still the same issue.could you help me please find the fault
                • Romy2018
                  • Sep 2018
                  • 174
                  • japan
                  i dont have schematic on this board i compared the voltages on the good and working board to this defective board. i check on lvds connector pin1 on the working board it has 3.3v but on defective board there is 0v.and the capacitor connected to lvds pin 1 chip marked 5244 5pin chip on the working board pin3 has 3.3v and on the defective board pin3 0v.the same as ceramic caps connected C572 on working board other side have 3.3v and on defective board both sides 0v. can anyone help me guide to fix this please
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    That 5 pin IC you are talking about is U501 and PIN 3 is PCH LCDVDD EN signal which should be 3.3v. This signal comes from PCH. So you need to check if there is anything inbetween which is rotten/burnt or simply bad. You are supposed to have 3.3v on all pins except pin2(GND) of U501. You can do the following two things to solve:
                    01. Remove U501 ic from mainboard and power it on wiyhout lvds cable and measure voltage again on U501 Pins. You will probably have the same voltage on all pins which were there prior to removing this IC- still missing 3v on pin3 will be there. YOU can just jumper with a very thin wire between pin 4 and PIn3 and then switch mb again and measure voltage on PIn3 of U501. This time you are likely to have 3v on pin3. Now turn off and connect lvds cable with screen and probably, your problem will be solved. This happens on Dell N5110 mb also.
                    02. Alternate method : You cut the PIN1 of LVDS cable and then apply 3v drwan from any other souce from mb directly to this cable. Your case will be resolved.
                    In fact, Only U501 is more likely to be defective . So The best bet is to replace this IC if you have the same. Else you can try either of the two methods-both method will solve your problem.
                    Post result.
                    • Romy2018
                      • Sep 2018
                      • 174
                      • japan
                      arigatou gozaimaz mcplslg123 i measured again without removing the chip pin 5 and pin3 no 3.3v on that chip have 0 volt, i removed the chip and measured again same results pin 3 and pin 5 and pin 3 have 0volt.should i continue to jump a wire from pin4 to pin3?because pin5 of the chip also no 3.3v?
                      • Romy2018
                        • Sep 2018
                        • 174
                        • japan
                        need help please
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          No dont jumper pin4 and pin3 in that case as pin 5 is input of that ic. Put the ic back. Check C599 for short(connected to pin5)
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Here is the schematic. Check page 38
                            • Romy2018
                              • Sep 2018
                              • 174
                              • japan
                              @mcplg123 sorry my mistake so stupid due to no schematics now i see your schematic ive measured b4 wrong pin,now here is the correct measured pin1 and pin4 have 0v and pin3 and pin5 have 3.3v.and now i have one problem the chip i pulled up is broken.
                              • Romy2018
                                • Sep 2018
                                • 174
                                • japan
                                need help please
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Dont worry friend for that broken chip(you can safely bypass that chip). So you have EN(PIN3) 3.3v and PIN5(IN) 3.3v. So you are having no output on PIN1. Just jumper between PIN5 & PIN1. Hopefully it will work.
                                  • Romy2018
                                    • Sep 2018
                                    • 174
                                    • japan
                                    thank you mcplslg123 i followed your advise i jumper pin 5 to pin 1 now whitescreen not coming back i will observe for a couple of hours and see.thank you again
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Glad to help
                                      • ahmarzo
                                        Asus la-7322p white screen problem
                                        by ahmarzo
                                        My asus laptop motherboard la-7322p has white screen. Have tried new screen but same problem.lcd vdd is 1.8v when i removed the mosfet an short 3vs with lcdvdd white screen is solved but no data on screen...
                                        07-15-2022, 07:52 AM
                                      • domu
                                        Viewsonic VS16217 strange problem - white flickering screen on power up
                                        by domu
                                        As per subject, on power up display shows no image, but white
                                        flickering screen. Strangely, it only happen after power was lost
                                        when it was on. After power returns - white screen only, but if
                                        disconnect power for 12-24 hrs, and connect then again monitor
                                        works normally.
                                        Any clues how to go about it would be greatly appreciated.
                                        07-18-2023, 04:57 AM
                                      • mmccomputer
                                        problem with replacing lcd screen
                                        by mmccomputer
                                        I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                        otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                        If anyone has any information on the subject...
                                        12-15-2024, 03:44 PM
                                      • Ryan.man
                                        by Ryan.man
                                        02-04-2025, 12:23 PM
                                      • EazyBone
                                        Sharp LC-65Q620U White Screen
                                        by EazyBone
                                        Another TV topic!!
                                        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                        08-21-2024, 12:56 PM
