Alienware m17x r4 snowy screen..
 Re: Alienware m17x r4 snowy screen..
 If the IC part number is the same its ok .Comment
 What is the code on that board? Alienware is dell pretty much. LA-xxxx?
 This sounds like the LVDS translator/Controller/converter IC... not sure on the exact desc or name.... Do you have a Schematic?
 EDIT: I think this schematic is the right one, attached below.
 EDIT2: #_# ah I see that is indeed the chip(page28) mentioned from the other forum... anyways if you have another like that swap it should work just fine.Attached FilesLast edited by MJ-meo-dmt; 11-08-2018, 04:48 AM.while alive { live(toFullest=true) }Comment
 I had a similar problem on an Asus laptop. But the customer did not give me time to fix it properly. Finally, I discovered that if uninstall Both the ATI and Intel Graphics drivers, the snow will disappears. So the customer was glad of this quick fix.
 there is a Graphics option in Bios. change it from switchable to something else. It may be fixed this way.
 Then, you can try replacing the LVDS multiplexer IC. It can be desoldered from any mainboard. I hope it is not faulty.Last edited by caspian; 11-08-2018, 05:26 AM.Comment
  It was this ic PI3LVD1012BE its running fine nowWhat is the code on that board? Alienware is dell pretty much. LA-xxxx? It was this ic PI3LVD1012BE its running fine nowWhat is the code on that board? Alienware is dell pretty much. LA-xxxx?
 EDIT2: #_# ah I see that is indeed the chip(page28) mentioned from the other forum... anyways if you have another like that swap it should work just fine.Comment
			by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
			by kain0007Hi Masters.
 I have an Alienware x15R2 laptop that went black after updating Windows.
 Could someone help me repair my bin?
 Alienware X15R2
 ST: 1CJY6M3
 Thank you very much for your support....-
							Channel: BIOS Requests ONLY!
			by jagiro84Hi there I hope someone can help me with fixing this issiue
 Symptoms
 My Alienware x15 r2 stopped working, which is around 2years old.
  power light and keyboard turns on, power lights give 2red and 3 blue lights,
 screen stays black
 From dell error codes it says this is error2,3 No memory or Random-Access Memory (RAM) detected
 after disassembling and removing battery removing any electricity left with power button on without psu connected,...6 Photos
			by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
 It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM
			by smic717394Hi,
- Loading...
