Alienware m17x r4 snowy screen..
  • appie1206
    • Oct 2016
    • 116
    • netherlands
    Hello guys,
    I have a problem with the alienware I thought it was the videocard i tested 2 other cards and still the same problem !!!! other things i tried : Switched memory,bios update,other screen nothing helped still the same problem!!i tested On a external monitor its fine! Does someone know what is the issue?
    Ive uploaded pictures how the screen looks so you guys can see it yourself....
    I hope someone can help me...
    Thanks in advance
  • mielta
    • Apr 2015
    • 368
    Re: Alienware m17x r4 snowy screen..
    Hi
    i Think its LCD Cable
    • appie1206
      • Oct 2016
      • 116
      • netherlands
      Originally posted by mielta
      Hi
      On hdmi also weird screen.... Only on vga the screen is normal. Is it maby the intel hd graphics?
        • 20665
        http://forum.notebookreview.com/thre...-issue.803411/
        • lorins_core
          BlackSmith
          • Dec 2012
          • 551
          • Philippines
          Originally posted by appie1206
          Hello guys,
          Thanks in advance
          as you said...
          Question. can you try to change A Screen Panel?
          • String2016
            • Nov 2015
            • 2229
            • philippines
            try to replace the screen at see if still the same
            • caspian
              • Oct 2015
              • 1589
              • Laptop
              change the screen resolution to check whether the snow disappears or not.
              • appie1206
                • Oct 2016
                • 116
                • netherlands
                I Tried also another screen still the same problem!... I think the connector on it its fine because i was bending it while it was on too see if some collor changed but still the same..
                • appie1206
                  • Oct 2016
                  • 116
                  • netherlands
                  Originally posted by lorins_core
                  as you said...
                  I already did that.. Just removed the backcover clicked a other screen on the connector stil the same. i think something on the motherboard is causing it.
                  • appie1206
                    • Oct 2016
                    • 116
                    • netherlands
                    Tried that one also still the same...
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      what panel u have ? 60 or 120hrz ? what vga u have ? how is bios set up ?
                      if u have tried 3d screen only, then it could be a bad mxm vga as intel vga is disabled when using 120hrz screen.
                      if u have 60hrz screen and fullhd resolution monitor, try enter the bios and setup bios to only sg (single graphics) to see it it works with intel vga, then try to setup to peg only with intel vga disabled.
                      if pc start giving 8 beep and u cant get out of it, remove power and battery and keep pressed power botton for 10 seconds, if still 8 beep , do the same but also remove cmos battery.
                      when powering on again, if u get 5 beep, just power off and then power on again.
                      it could be bad intel vga, bad mxm , bad lcd cable or bad panel.
                      on my m17x r4 that i use as my only pc, i got some blurry effect on the center of the screen and was a bad 120hrz panel.
                      • appie1206
                        • Oct 2016
                        • 116
                        • netherlands
                        What i just did i removed the nvidiacard... and just started only with the intel hd grapics... and still the problem ....maby it is a faulty processor with the intgrated intel hd grapics.
                        • appie1206
                          • Oct 2016
                          • 116
                          • netherlands
                          I cant disable in the bios the intel... i dont see that option. I changed the processor with intel graphics still the same problem. The weird thing is if it is the lvds cable why it doesnt function on hdmi? It should work ok then on hdmi... ur causes the cable a malfunction on hdmi also?
                          • dellxps15
                            • Feb 2014
                            • 1588
                            • italy
                            hdmi was ok. still dunno if u have a 3d or 60hrz screen and what vga u have.
                            and the orange color should be red.
                            if u have 3d screen then probably screen is gone bad, but with 3d screen u cant use intel graphics, so if u have removed the mxm and pc boot then u have 60hrz screen, unless u plug a hdmi cable , then it will work.
                            • appie1206
                              • Oct 2016
                              • 116
                              • netherlands
                              Its the Lvds cable that is messed up... What i did is this i pulled the lcd cable out while i was on windows and than i plugged in the hdmi cable in and the screen is perfect . i orderd a new one...
                              Thank you very much everyone!!!!
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                I expected this from the get go. Snow on picture is almost always a LVDS cable or connector problem. Glad you found it.
                                A working TV? How boring!
                                • appie1206
                                  • Oct 2016
                                  • 116
                                  • netherlands
                                  Orderd a new cable guess what... still the same problem!!!
                                  I dont get it anymore.
                                    • 20665
                                    Did you read the post on notebookreview, its a possible fix if you change those IC`s .
                                    • appie1206
                                      • Oct 2016
                                      • 116
                                      • netherlands
                                      Hi I didnt fully understand what they talking about.... My englisch is bad when it comes too tecnical terms
                                      PI3LVD1012BE so i must replace this ic?
                                        • 20665
                                        Thats the suggestion at the last post in that forum,although he never posted again to say if replacing those IC`s fixed the problem or not . You know its not the cable or screen.
                                        Edit: http://*******/viewtopic.php?f=41&t=38172&p=456225
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • jagiro84
                                          Alienware x15 r2 black screen
                                          by jagiro84
                                          Hi there I hope someone can help me with fixing this issiue
                                          ​​​​​​Symptoms
                                          My Alienware x15 r2 stopped working, which is around 2years old.
                                          ​​​​​​ power light and keyboard turns on, power lights give 2red and 3 blue lights,
                                          screen stays black
                                          From dell error codes it says this is error
                                          2,3 No memory or Random-Access Memory (RAM) detected
                                          after disassembling and removing battery removing any electricity left with power button on without psu connected,...
                                          11-25-2023, 03:44 AM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                          Alienware M17x Gaming Laptop Schematic
                                          Alienware M17x Gaming Laptop Schematic...
                                          11-01-2024, 04:56 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
