acer es1-711 problem..... white screen and now black screen
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    hi, got this laptop one month ago with a freezing problem. it has only one bga for nb sb and cpu. its cpu is n2840.
    i ordered stencil for reballing the chip from goldenchipset, but when i melted the 0.35mm bals, when lifting the stencil some pad ripped off and other balls didnt melt on bga. i looked and investigate the situation and found that balls holes on stencil were not the right dimention. i asked gc and they would send me a new stencil, but as far some pads were ripped off i got a refurbished bga too with already leaded balls on it.
    when bga arrived, i soldered properly, but got a white screen.
    i gived then another reflow and now this time i have black screen.
    what could be the cause ?
    i removed bios, its a winbond 25q64fv, but when i put on my programmer it tell me chip is different.... and im not able to program it.
    now i will put some other bios with a dump i got from internet and ggive it a try, but would like to know if someone got already in the same situation and why white screen and then after a reflow black screen ?
    edit: tried 2 bios dump ive found on internet, but with that bioses pc wont even start.
    • 21917
    Re: acer es1-711 problem..... white screen and now black screen
    What bios programmer do you have. The dumps you got ,did they have a clean ME area .
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      I feel it has something to do with bga reball/replacement as lvds lines all originate from there only. Bios issue-I dont beleive it.
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        here is a dump of original bios even if it told me chip mismatch. my programmer is a sofi sp8-a and it read well similar bioses.
        u think bga is soldered bad or bga is defective ?
        original = my bios
        the other 2 1 is without me i think and one with, but both dont make notebook start.
        other is tool to save bios from windows...
        on coils, all voltages are present. so all volts comes, but no picture
          • 21917
          I feel it is most likely the bga/reball too. You can`t rule out the bios though,i`ve had similar problems after a reball,booting to white screen first then blank .
            • 21917
            The 25q64fv is in the sofi supported bios list.Do you have the latest software
              • 21917
              Your original bios has a ME area , the other bios (Acer E 17 ES1-711-C7ZU V1.04 ME LOCKED.bin) doesn`t
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                i have programmed a 25q64fv without problem, just this acer bios give me problem...
                and as i sayd original make pc start with black screen, while the other bioses make pc like dead
                  • 21917
                  Have you programmed the EC or just bios
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    just bios.... dont have ec file and light are ok when powering on
                      • 21917
                      The EC file is the 4MB one , the bios is 8MB . For what its worth i`ve added clean ME firmware to your original bios, and added ME firmware to the other (locked) bios. Flash the original cleaned bios first and try it. If you try the other bios,flash the EC bios as well ,back it up first if you do .
                      • caspian
                        • Oct 2015
                        • 1591
                        • Laptop
                        according to what you said, it would be better to keep the original bios and start troubleshooting, until you find a missing signal or voltage. then, you can tell what is faulty. probably, it leads to a bad reflow or a bad bga chip.
                        • dellxps15
                          • Feb 2014
                          • 1598
                          • italy
                          today i treied both original bios with me removed and the bios found on internet with me added. none of them make notebook light to come up, like notebook is totally dead.
                            • 21917
                            Try flashing your original bios back or the one with clean ME at post #11 . What part number is the motherboard,including rev number.
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              what voltage rails are missing by using the original bios?
                              • dellxps15
                                • Feb 2014
                                • 1598
                                • italy
                                ok this notebook is making me crazy...... before doing all test, i tested ram in another pc with memtest and all was ok. after i got bad bga, my customer told me to fix pc asap and anycost, so i picked up on ebay a second hand mainboard for 140€ .......
                                arrived today, and guess what ? pc freeze same as before removing bga. i removed keyboard, touchpad, wifi, but pc freeze....
                                bad second hand mainboard or what ?
                                originally notebook got windows 8, but now i have windows 10. what could be the problem ? bad memory ? :|
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Freezing very likely on 2-3 points-
                                  01. bad memory
                                  02. Bad graphics chip(in this case cpu+pch)
                                  03. Drivers issue or os issue
                                  04. Overheating.
                                  You are aware of all the points l;isted above. Now just rule out one by one and see where it heads.......
                                  • dellxps15
                                    • Feb 2014
                                    • 1598
                                    • italy
                                    im going to install another windows 10 version today. lets see if it will works.
                                    • caspian
                                      • Oct 2015
                                      • 1591
                                      • Laptop
                                      Sometimes, laptops act very strangely. This makes our lives difficult to afford.
                                      How long does it take to freeze from starting up?
                                      Does it freeze in safe mode or in Bios setup?
                                      I think you really need the Universal Boot CD now to test various parts of the laptop.
                                      RAM sticks may act really tricky. For example, a while ago, I had a RAM stick that passed the POST testing very good, but it leaded to freezing after some minutes of working fine in Windows.
                                      I think the failure symptoms of the laptop will give us better clues.
                                      • dellxps15
                                        • Feb 2014
                                        • 1598
                                        • italy
                                        im buyng new ram. windows install went fine, but when doing first reboot pc freeze. doing a memtest today gived me a freeze too, so lets change that ram bank and see if we can get out of this crappy notebook
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • EazyBone
                                          Sharp LC-65Q620U White Screen
                                          by EazyBone
                                          Another TV topic!!
                                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                          08-21-2024, 12:56 PM
                                        • hcinne
                                          Dell G15 ryzen edition black screen 2 amber 1 white
                                          by hcinne
                                          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                          07-23-2024, 07:56 AM
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
