DELL 3521 - Problem with start. KB9012 question.
  • bumper1
    • Jul 2014
    • 77
    • Poland
    DELL 3521, LA-9101P
    Laptop always starts like this: First turn on without screen (also no vga, hdmi). Then I hold power switch 4s - turn off. Then turn on - it start with no screen, then reset itself, and start with screen (working ok). I tried 3 different bios +ec pack, on new IC- always same procedure to start it (I tried about 30 times). I cleaned ME Region on oryginal dump - same thing. I disconnected PJP800 (to turn off AMD GPU) same procedure to turn on - so it is not GPU problem. I also changed RAM, and power supply.
    I think it maybe KBC KB9012 A3 problem- but I know it's programmable.
    My question - if i solder NEW (never used) KBC - it will program itself from bios with first use or I have to program it? I had this self programming once, but i don't rememeber what model of KBC that was. I haven't got KBC programmer.
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: DELL 3521 - Problem with start. KB9012 question.
    Originally posted by bumper1
    DELL 3521, LA-9101P
    First you need check plug in speaker and check how many beep.When idea what problem.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Check Cmos battery voltage
      • bumper1
        • Jul 2014
        • 77
        • Poland
        I have 5 beeps ("Real Time Clock (RTC) power fail" ??? )
        But battery has 3V, and +RTCVCC i about 2,9V (measured on pin:1 DH1) (without main battery and power supply). With different battery, or without rtc battery behavior is the same as above.
        • imranromi
          • Jan 2015
          • 1288
          • Pakistan
          Cmos problem when first time laptop turn on press power button hold 20 sec and press again wait for display.
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            wtf???? i read this.. had the same problem... 5 beeps, programmed bios and still the same
            so i did what imranromi said... laptop turned on. Thank you very much... this method is fox for 5x beeps...
            Im Back... sort of...
            • dj_ricoh
              • 2073
              make a picture of the motherboard!
              PICTURE and schematic
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                motherboard was VAW00 LA-9104P dell inspiron 3521 uma intel
                5x beeps... turn on to hear beeps, press power button and hold 20 sec. laptop turn off, the press button to turn on. it does some funky things (turn on and off, fan spin and stop few times) and then display picture.... crazy stuff. big thanks for "hack"
                • repairs_free_for_elderly
                  • Feb 2018
                  With that all said, it didnt work for me.... BUT,...
                  what is going on that the procedure given by imranromi works? I am curious I guess "how" that works or why it does.
                  Is it resetting something to do with BIOS, EC, or KB?
                  I had my 3521 working by applying Vcc to CS on UH2 and turning it on. REplaced the CMOS also. But after ot plugging in and not charging for severl months in the closet, it is doing the same thing again (no beeps, no post, no screen, powers on, no HDD activity and the UH2 trick I mentioned isnt working anymore).
                  Sorry if this is considered hijacking a thread.
                  • caspian
                    • Oct 2015
                    • 1591
                    • Laptop
                    what is the theory behind pressing power-button for a while?
                    what component does get defective inside or outside CPU/PCH that causes electricity to trap in some section of mainboard?
                    • toti24
                      (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                      by toti24
                      dell precision m4600 laptop
                      i7 2760qm
                      8gb ram 750gb HDD
                      intel hd 3000 integraded and nvidia quadro 2000m
                      pleasea bear with me english isnt my language and ill try to be as clear as possible
                      note i live in mexico in a very small town..
                      thank you.
                      laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                      the brick happened when i was installing win 10 using usb.
                      used rufus and officia microsoft.iso
                      it finished copying files from usb...
                      03-06-2022, 08:39 PM
                    • SDNarcia
                      Dell 15R-5521 keyboard problem (KBC?)
                      by SDNarcia
                      Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                      As additional information,...
                      07-20-2024, 10:47 PM
                    • Achille15
                      Dell N5110 problem
                      by Achille15
                      so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
                      03-29-2025, 04:41 PM
                    • masoksian
                      Dell latitude e7470 not turn on .power buton on off and Run Power problem
                      by masoksian
                      I am dealing with the problem of turning on and off my Dell e7470 notebook.
                      The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                      The system does not turn on, there is no post.
                      I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                      The problem continues in the same way.
                      I tried to turn on the Fn key, nothing came to the screen....
                      02-15-2025, 12:08 PM
                    • MahmoudNasser
                      Dell 7480 problem with freezing during the Windows loading process
                      by MahmoudNasser
                      Hello everyone, I wish you a happy day.
                      I have a Dell Latitude 7480 laptop that has a problem with freezing during the Windows loading process. If it manages to boot up, it becomes very slow and doesn't load anything from the desktop.
                      Device Data
                      Model Dell Latitude 7480
                      CPU:i7-7600U
                      SN:7T58PL2
                      MP PartNumper:CAZ20 LA-E131P Rev:1.0 A00
                      Bios Chips:W25Q128BV
                      The attempts that have been made to solve the problem have not yielded any results.
                      1. Changing the M.2 and M.2 Nvme hard drives.
                      2. Trying...
                      07-09-2023, 05:04 AM
