Resistor, first color band balck!!.
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Hello.
    two blown resistor (in parallel) connecting source of mosfet to transformer in SMPS with 5 band colors
    the problem is that they start with black color band in first Place as below
    Black-Brown-grey-silver-Brown
    black-red-violet-silver-Brown
    As of the size it seems 2-3 w resistors at least.
    Any help with values
    BR
    i think one is 0.18 ohms and the other is 0.27 if i got it right, comfirmation?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: Resistor, first color band balck!!.
    chceck online resistor calculator
    • tibd
      • Oct 2014
      • 189
      • Sweden
      WOW what a smart answer!!!
      • diif
        • Feb 2014
        • 6978
        • England
        Yes, 1% tolerance resistors.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3610
          • slovakia
          what else u need?
          • tibd
            • Oct 2014
            • 189
            • Sweden
            thanks,
            • JaroTech
              • Mar 2015
              • 351
              what else u need?
              If you don't have the specific answer to the question, you don't need to waste your time to answer.
              • Askic
                Reading resistor value by color band
                by Askic
                attached is a picture with two resistors. I wonder what values are based on color of the band.
                I have used this as a reference:
                https://www.electronics-tutorials.ws...tor/res_2.html
                Since there are 5 bands, the question is from where to start counting (what is the first band).
                Based on this info, I can conclude that thick band is the last one.
                Therefore the values are:
                Left resistor - red(2) yellow(4) black(0) black (x1) brown (1% tol) = 240 ohm, 1% tolerance
                Right resistor - brown(1) black(0) black(0) gold(x0.1)...
                02-10-2022, 12:26 AM
              • JenneDezaeger
                5-band resistor starting with black?
                by JenneDezaeger
                Can anyone tell me how it's possible for a 5-band resistor to start with black?
                If it really was a zero-ohm resistor it probably wouldn't have burned.
                So if there are any ideas on the value of this resistor and how to read it, please let me know.
                Greetings,
                Jenne...
                12-06-2022, 06:16 AM
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
              • MidnightRoller
                Can a resistor lose resistance after hot air?
                by MidnightRoller
                I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                02-02-2022, 11:46 PM
              • magneh
                Is this some kind of fuse resistor ?
                by magneh
                Hello guys
                Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                Seem to me like some kind of fuse resistor?
                After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                The red band is larger than the 4 others, but I dont have much experience with these components.
                Also one of the orange...
                02-10-2025, 07:54 AM
