burn track in dell i 7
  • hazim
    • Mar 2016
    • 62
    • egypt
    The problem I encountered at Dell Laptop core I 7
    La- 9981p (vbwoo)
    In picture ic 5-3 tps 51225cr is fails and pin 12 (vin) track burnt
    How to soldering a wire in the track under the legs of small ic – 5 3 to work a bridge to connect electricity to this ic and install new ic
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: burn track in dell i 7
    It is on your experience and practice I have done many times ..take a very thin wire solder it and trace the damaged line connect the wire to that component and the other side place under the ic in the burnt area and past with flux and adjust with other line of the ic equally adjust with needle and then place the ic with care and give heat.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • ktmmotocross
      Dell G15 5511 LA-K455P - new gpu fan burn SIO pwm sig. in SIO MEC1515
      by ktmmotocross
      Hello. Have this Dell G15 5511 la-k455p that new gpu fan burn and left pwm sig from sio with 10 ohms.
      I read that this sio MEC1515 must be programmed, but someone says dont. My Vertyanov seems dont have this model in it.
      Laptop works and can be tricked by split pwm, but i dont want to do this stuff this way.
      So anyone really knows if it must be programmed?
      09-16-2025, 07:11 AM
    • kalemaroni
      Dell DC Brown wire
      by kalemaroni
      There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
      08-26-2025, 10:10 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
