laptop hp dv6-3132 dead, no lights at all
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: laptop hp dv6-3132 dead, no lights at all
    First you will have to remove them one at a time to see which one is shorted.
    I can't find anything with those markings so they might be actually different.
    The schematics list some Renesas parts (RJK03B9DPA and RJK03D3DPA) so you could replace all the MOSFETs onboard with the Renesas parts. It is recommended to replace all of them and not just 1 in order to keep the phases balanced. Also it is recommended to replace the controller (PU1) too in case it may have died.
    Also if one of the high-side MOSFET is dead, the CPU might be dead too. Btw that's why you have to disconnect everything from the board when injecting voltage: if a high-side MOSFET is dead, the voltage you're injecting on the +VIN line goes directly to the CPU.
    • starling22
      • Feb 2017
      • 29
      As I find it odd that those 8 chips should go. Of course at this stage I do not know if more components are dead. These eight did get hot when about 10W power or more was applied.
      You have me a bit concerned about the cpu I should have dismantled this earlier as well. I understand that if I had applied external power to the location where PD23 is, say on a good motherboard, with my method the cpu might be damaged.
      In my case the lowest voltage setting I would have applied is 2.7V both for my 'low power' supply and 'high power' supply. What I was thinking when I had located a shorting condition was following:
      With 2.7V and current limit this would be safe start as the voltage would not rise very much on the board. The experiment seem to support the thinking as even with 0.9 A going in hardly only fraction of a volt developed.
      However with the high power supply the situation is not soo good, in my mind I was thinking it was safe under 3.3V but that is only because I have just been working on small microprocessor using 3.3V.
      Looks like I may well be learning the hard way.
      • starling22
        • Feb 2017
        • 29
        Been slightly sidetracked fixing up lighting and making room in my workshop in preparation for attempting SMC work. I had an old Intel motherboard about 10 years old I guess. Starting practicing removing components.
        First go removing a small 8 pin device, I had too fast air stream as I blew away a small component when the chip came away. I may have shaken my hand when grabbing the chip with my tweezers. Removing components I will be able to do. Soldering them back again will take me some time to practice as I notice that my hands shake a bit much for comfort.
        A good friend and very good electrical/electronics engineer did not take long to identify the MOSfets as being Fairchild after I sent him a couple of pictures I took last night doing my best effort to get markings visible. What I thought was the chip name appears to have nothing to do with the name. I got Fairchild correct. I made a big mistake not attaching a couple of poor visibility but very close up pictures to an earlier post as I am sure somebody would have put me right. I am learning in my old age.
        Message from my friend:
        Fairchild Mosfet in a DFN8 package.
        You have the wrong part numbers!
        First one probably is FDMS0310
        Second one - FDMS7692
        I have looked on the internet and got the data sheets, also they can be purchased easily enough, not exactly cheap. I will obtain 5 of each after I have rechecked my pictures.
        Following is a reminder to myself, when I read the archived thread in the future, to use my now working hp 6284A power supply which can supply 20V/4A and fully variable 0V to 20V (with over run to 24V) current limit can be set from 40 mA to 4 A. I resurrected it today.
        By the way I have spent some time identifying the electrolytic capacitors on an ASUS P5P41D motherboard, I think I counted 19 and of those at least 4 has bulging top and the board gave up the ghost a couple of years ago. I have 5 replacement caps but reading on this Forum I think they all should be replaced if I think of getting it back to work again.
        • piernov
          • Jan 2016
          • 4439
          • France
          In that case you can replace all the MOSFET at once, and then before powering up the board check resistance between +VIN line and VCore, and between VCore and ground, *without CPU*. It should be at least 10kohms I think.
          Those kind of PSU are great but I often find 4A not to be enough. I've got a DPS5015 DC-DC converter which can do up to 50V/15A, and I feed it with a 48V/8A PSU. I often go up to 8A current limit on low-voltage high-power lines.
          For desktop motherboard, I never replace all the caps, only the ones that are physically damaged and their friends (ie. caps with the same specs and on the same line as the dead ones). Works for me in most cases. Also it depends on the brand/series of the caps, some are known to fail. (just went replacing 4 KZG and 4 KZJ on a Dell MB, every other caps were fine) Also I don't really bother matching the caps, I only make sure the voltage is high enough and the capacitance is around the same or higher, and obviously that the caps fit in. I do use low-ESR/high ripple current caps when needed though. Well… Do what is the easiest and what works for you.
          • starling22
            • Feb 2017
            • 29
            RS here in Australia carry the FDMS7692 MOSFET but not the FDMS0310 but they do have another FDMS037N08B which in most respects seems more rugged. I am tempted to buy that. Buying from RS is good insurance against getting low quality from internet.
            Capacitance and min Vgs (Gate-Source) voltage is approx 1V higher I do wonder if that is important enough to dismiss it. I will attach data for both.
            • piernov
              • Jan 2016
              • 4439
              • France
              #26
              Capacitance is an important factor because it will greatly affect the time the transistor takes to switch between one state to another. The timings are described in "Switching Characteristics" section. You often want to have similar or lower timings here.
              That's what happen when you have a "beefy" MOSFET, since it has to be "bigger" to be able to handle the voltage and the current, you get a greater gate capacitance, so it is slower.
              This MOSFET won't do. I will roughly explain how you can see this, this is probably the wrong way to do it but well…ask a real electronics engineering if you really want to understand how this works.
              Let's say this buck converter works at 300kHz. With a 50% duty cycle (half time on, half time off), this means that we have roughly 1.5µs of "on state" and 1.5µs of "off state". A 50% duty cycle would also mean that the output voltage is roughly 50% of the input voltage, ie. from 19V to 9.5V. However our CPU can work as low as 0.9V, which is around 5% of the input voltage, so we need a 5% duty cycle, ie. 0.165µs of "on state" and 3.135µs of "off state".
              If the MOSFET already takes 0.130µs (max td(on)+tr) to fully turn on, that's no good, even if the controller should compensate for the latency.
              Well… that's a bad explanation but you should get the idea why those timings are important.
              And since the turn-off time is higher than the turn-on time on MOSFETS, for low-side MOSFET (which more or less has the reverse behaviour than the high-side MOSFET) the timings must be even better.
              About the gate treshold voltage, it has its importance too. The MOSFET drivers inside the buck controller work at 5V, so the gate threshold voltage of the MOSFET must be lower than that, and the lower the better. If the margin is too tight, the MOSFET may be noticeably slower. Remember that the datasheet lists timings at a gate voltage of 10V, but here it will be driven at 5V so it will be slower.
              • starling22
                • Feb 2017
                • 29
                Ok, I understand perfectly. The risk is too high that something will go wrong and it will be wasted effort. I will have enough trouble trying to solder in the ICs, this exercise will do as far as creating problems this time.
                I will buy one set off the internet and the other from RS-Australia.
                If I stumble over a website(s) that look at these things in depth I will listen in out of curiosity.
                • starling22
                  • Feb 2017
                  • 29
                  While waiting on replacement MOSfets I wondered about on the net and took an interest in trying to see if I could locate a "boardview" for the hp dv6-3132 laptop.
                  It seemed harder than expected. I have downloaded "Openboardview" and a random boardview. Playing around with this.
                  Yesterday I believe I got very close to finding a boardview, I made a note too somewhere but failed to find it again today.
                  google: "QUANTA LX6-LX7 DA0LX6MB6H1 HP liverpool boardview"
                  The term above does give some promises in that:
                  http://laptopserviz.bg/enview/boardview.html?p=2
                  Failed to find a boardview as the search system seemed to fail me.
                  • SuperAman
                    PS5 dead no beeps, no lights
                    by SuperAman
                    Got a PS5 with no power. I can read some voltages on the back side of the board with PS connected. I do believe I have 12v coming in and I have found 3.3v, 5v on the board. I do have 12V on + terminal of all the electrolytic caps pictured. I believe I have a short on the vcore / apu supply? All the APU 1V small coils all 6 on both sides of the board are reading around 0.6 ohms on both terminals. I believe console may be dead due to a shorted usb port which I was able to unbend the pins. Do I have a shorted mosfet or possibly bad ceramic small cap or a dead apu? The usb ports are connected directly...
                    11-29-2023, 06:34 PM
                  • Audeze
                    Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                    by Audeze
                    I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                    Does...
                    10-06-2024, 08:54 PM
                  • Spent5
                    ASUS GA401QM dead no lights
                    by Spent5
                    i have this asus laptop. This laptop was bought not working.
                    Initially I found corrosion in the 2 attached photo's and after cleaning that with ipa boom it worked
                    then it just stopped again.
                    here is what i have discovered so far.
                    i checked the first 2 mosfets by dc in jack no voltage is passing from drain to source on the first mosfet.
                    see circled components on other 2 photo's the circled mosfet has a gate shorted to ground and the other photo that component is shorted to ground
                    I'm really not sure where to go...
                    06-10-2025, 11:38 AM
                  • jacobtc
                    Asus GA401QM dead, no lights.
                    by jacobtc
                    Yes, I know I had a similar laptop I fixed a while ago, don't blame me for picking up a new (dead) one
                    This one shows no life with AC or USB-C charging. Reset CMOS, removed battery, and tried again, nothing. No lights, and no response when power on button is pressed.
                    Measured DC In mosfets as good, and the board seemingly seems to supply 20V, 5V and 1.2V with my quick measurements. Battery is completely depleted, I believe this has disabled itself as my other battery also did. When DC is plugged in the GPU gets 45C and CPU VRM/Mosfets get to same temperature....
                    07-31-2022, 07:31 AM
                  • double_DD
                    How can I be sure that my EC chip is dead?
                    by double_DD
                    As the title suggests, how can I be sure that my EC chip is really dead?
                    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                    03-12-2025, 07:47 AM
