hp g62 white screen problem
  • hazim
    • Mar 2016
    • 62
    • egypt
    hi
    hp g62 white screen when adapter plugged in or on battery
    no power when i press on power button
    power button not responds
    on power suplay value 0.086
    i need your help
    thanks
  • hazim
    • Mar 2016
    • 62
    • egypt
    Re: hp g62 white screen problem
    pleas something happening
    when i disassembly laptop and plugged adapter white screen auto
    then i press power-
    laptop power up normal and entering windows
    when shut down i see bold line ( gray and black) goes up and down
    after that screen still white
    mb no: DAAX1JMB8C0
    what can i do
    thanks
    • ahmarzo
      Asus la-7322p white screen problem
      by ahmarzo
      My asus laptop motherboard la-7322p has white screen. Have tried new screen but same problem.lcd vdd is 1.8v when i removed the mosfet an short 3vs with lcdvdd white screen is solved but no data on screen...
      07-15-2022, 07:52 AM
    • domu
      Viewsonic VS16217 strange problem - white flickering screen on power up
      by domu
      As per subject, on power up display shows no image, but white
      flickering screen. Strangely, it only happen after power was lost
      when it was on. After power returns - white screen only, but if
      disconnect power for 12-24 hrs, and connect then again monitor
      works normally.
      Any clues how to go about it would be greatly appreciated.
      07-18-2023, 04:57 AM
    • mmccomputer
      problem with replacing lcd screen
      by mmccomputer
      I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
      otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
      If anyone has any information on the subject...
      12-15-2024, 03:44 PM
    • jimjoe123
      LCD TV Green/Pink screen problem
      by jimjoe123
      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
      Then each time...
      02-23-2020, 01:29 AM
    • EazyBone
      Sharp LC-65Q620U White Screen
      by EazyBone
      Another TV topic!!
      I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
      The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
      Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
      08-21-2024, 12:56 PM
