Samsung NP300E5C-S01PT No Backlight
  • sn4k3
    • Oct 2016
    • 68
    • Portugal
    Problem: No Backlight, image OK
    Description: A customer tried to install a lcd replacement, on connect LCD connector to motherboard he put connector in reverse order and also in normal order but with one column shift to the right. That result in no more backlight on PC.
    Things i have tried before dig in:
    - Connect in good order: No fix
    - Test with other good known LCD: No fix
    After research i find the datasheet from motherboard (Please see attachment).
    The datasheet have "Backlight On" schemantic:
    LCD3_BKLTON outputs 3.3V, Logic AND inputs are 3.3v
    I probe all LCD pins and they have correct voltages.
    In the end LCD have image, only doesn't have backlight...
    Should LCD3_BKLTON be 0V or 3.3V to trigger backlight?
    Last note: LCD is good, problem is on motherboard, i also tried to connect it shifting first pin col, and LCD backlight turns ON with PC OFF (Only conected to DC).
    I also tried connect shifting the first col of pins, Backlight turns ON even with PC OFF (Only connected to DC or Bat)
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: Samsung NP300E5C-S01PT No Backlight
    LCD3_BKLTON Should be 3.3V to trigger backlight.
    • mielta
      • Apr 2015
      • 368
      Hi
      You must check lcd3_vdden and lcd_vdd3v and also vdd_led
      • sn4k3
        • Oct 2016
        • 68
        • Portugal
        And it is, i write that on main post.
        Originally posted by mielta
        Hi
        vdd_led: 19V
        lcd_vdd3v: 3.3V
        lcd3_vdden not tested yet, but if LCD_VDD3V have correct voltage that doesn't means lcd3_vdden is working?
        • mielta
          • Apr 2015
          • 368
          Hi
          You must check this voltage at the LCD Direktly.
          i think you have a Problem with the LCD Cable.
          I Think the Voltages are all OK so that the LCD Must have brithness.
          • sn4k3
            • Oct 2016
            • 68
            • Portugal
            Hi
            Cable is good, i checked for continuity, aprox 0ohm in every pin from motherboard to flex end. I didn't test voltage at lcd but i can do that.
            Will post results latter
            • sn4k3
              • Oct 2016
              • 68
              • Portugal
              Hello again,
              Voltages are correct at LCD connector.
              Also as i said before if i shift connector 1 col to the right lcd will turn on the backlight, with PC off but connected to wall. see picture.
              Because is bad connected BL_ON will recieve 19v, but that doesn't make sense.
              Maybe BL require another line to work?
              UPDATE 1: I manage to get backlight on again! After discarding obvious backlight circuit, problem was with "LCD3_BRIT" It was 0V... i think that something related with brightness so i test inject voltage there
              First i tried to put 3.3V there, nothing happen, after i tried with 5V and for my surprise backlight is back!
              Now if i power off pc completly, discharge and start again LCD will have backlight again without any help/boost
              My question is: Is it possible that PC stored a value due bad connection to not let LCD gets brightness on and need this trick to reset?
                09-07-2024, 05:50 AM
              • C152Heavy
                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                by C152Heavy
                Summary for TL-DR readers:
                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                • Have read ALL applicable threads
                • C1818 and CP820 replaced as low hanging fruit
                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
              • KYBOSH
                Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                by KYBOSH
                I picked this one up today.
                Previous owner says no signs of life.
                TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                The TV model is QN65LS03BAFXZA - version: CB06
                The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                Will keep you all...
                04-05-2025, 08:32 PM
              • sansanpartida
                Samsung QE82Q70RAT no backlight
                by sansanpartida
                Hi everyone!
                Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                My issue: No backlight.
                Model: QE82Q70RAT
                Type No: QE82Q70RAT
                The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                So hopefully, I can fix this cheaper.
                05-22-2024, 06:56 AM
              • atkallu
                Samsung One Connect Box SOC1001N vs SOC1004N
                by atkallu
                I am asking have somebody information about Samsung one Connect boxes compatibility ?
                So, can I use SOC1001N box on the TV which have SOC1004N box, is it compatible ?
                SOC1001N box has been worked with Samsung QE55Q8 and the SOC1004N box has been used with Samsung QE55Q9.
                Boxes part numbers are the same: BN68-08730A-00.
                07-09-2025, 01:54 PM
