Fujitsu LI3910 DA0EF7MB6D1 fan spins, no image, pls help
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    hi ppl
    i need a bit of help to figure out this board
    its Fujitsu Amilo LI3910 with board DA0EF7MB6D1
    i had board which was shorted a played with it and burn it right, no help there but can be used as donor
    got me a new board for 7.5 euro but its not working, ofc
    laptop turns on, no image on screen, does not respond to caps lock or num lock
    tried another cpu, ram, vga out, nother screen.. nothing
    then i checked coils, all have voltage, 19v 5v 3.3v
    intel gm40 heats a bit but has heatsink but i suspect its ok
    tried to reflow a bit with low temp, all same...
    i flashed bios from another thread, no change, all same...
    since i have donor board with other problem (dead like rock) maybe you could guide me to fix this board or detect problem... please
    one more thing, in regular interval (5sec) i hear tik sound and fan spins a bit slower for like 1/4sec... like it rebooting :-/
    also, battery is charging
    Im Back... sort of...
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Fujitsu LI3910 DA0EF7MB6D1 fan spins, no image, pls help
    Did you get voltage on VCC_CORE?
    - Also check signal VR_PWRGD_CK410#, ECPWROK, PM_ICH_PWROK.
    - I didn't know where the pin to check signal for dramrst for DDRII. Mostly Power On Sequence only for DDRIII
    - Try to hear the tik sound at midnight, may be it will be a "clue".
    - If all voltages and signals are present, but No display. If so, then I think is the hardest things on laptop repair (for me ). May be related with SB and NB.
    - Wait for another suggestion from the expert
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      hello and thank you for response
      on PL12 = VCC_CORE without cpu 1.5v with cpu 1.1v when on
      on U7 0MC74VHC1G pin2 = ECPWROK is 3.3v
      on U7 0MC74VHC1G pin4 = PM_ICH_PWROK 3.3v
      on PU7 ISL6262A pin47 = VR_PWRGD_CK410# 0v
      should i replace isl? need to find spare...
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        ok changed known good ISL6262A from some dell board that was turning on and display image on vga but not display, so isl should be goood
        anywas after replacing its all the same, nothing changed, pin 47 still 0v so no VR_PWRGD_CK410#
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3577
          • slovakia
          CLK_EN# - Digital output for system clock. Goes active 13
          clks after Vcore is within 10% of Boot voltage.
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            As mentioned in “Theory of Operation” on page 16,
            CLK_EN# is logic level high at start-up until approximately
            43µs after the V CC -core is in regulation at the Boot level.
            Approximately 43µs after V CC -core are within regulation,
            CLK_EN# goes low, triggering an internal timer for the
            IMVP6_PWRGD signal. This timer allows IMVP-6_PWRGD
            to go high approximately 6.8ms after CLK_EN# goes low
            so this is fine...
            i think GL40 is dead cos i have 0v on C1 pin on cpu socket
            H_CPURST# should be 1v but for me its 0v
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
            • tuner2000i
              Philips 65PUS8518/12 distorted image after main board replacement
              by tuner2000i
              hello everyone,
              I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
              The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
              07-15-2025, 01:15 PM
            • huzo
              Dell 5590 no image on LCD,HDMI works ,the board works...
              by huzo
              The board is LA-F411P ,DELL 5590 ...
              The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
              02-16-2025, 03:08 PM
              FUJITSU ESPRIMO D556/E85+ ESPRIMO D i5-6500 Specification for Upgrade or Repair
              This specification for the FUJITSU ESPRIMO D556/E85+ can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO D556/E85+ boardview and ESPRIMO D556/E85+ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-12-2024, 03:30 PM
