LA-6582P Rev1.0 - No Power
  • DanFen
    • Apr 2017
    • 201
    • Malta
    Got this Acer laptop on the bench after water liquid spill.
    Schematics attached.
    I could immediately see corrosion on the board (please ignore the 1 cent coin ).
    That circuit is found on the schematics on Page 35. You can see the mosfet just where the corrosion is, marked as Q56.
    Also, the Q56 mosfet is having almost 5V on the middle legs on both sides (and according to the datasheet, those are the gates). Datasheet for Q56.
    Noob question 1: Does that make it "OK"? According to what I've researched, in order to properly test a mosfet is to actually take it out, since the measures can be affected by other components. Is this correct?
    The schematics also show another mosfet on the same circuit (marked as U25) and is on the other side of the board in the same exact area. Datasheet for U25 I got 5V on 2 legs (which are next to each other), however I cannot find a way to identify which legs are these.
    Noob question 2: Is there a way to identify the leg numbers without the help of a board view? I can notice a small little hole on one of the corners... what does that mean?
    Some more information:
    Battery connected: amber light.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: LA-6582P Rev1.0 - No Power
    https://cdn.badcaps-static.com/pdfs/...3a6ef6cd1d.pdf
    • onlyprinzp
      • Mar 2017
      • 14
      Answer to Noob question 1:
      Best way is to take the mosfet out. If you got a good heatgun (ex. heatgun station) you can take it out easy and "resolder" it back easy. If you take it out, take both middle pins on each side and put your multimeter on diod test mode, the readin should be between 0.100 and 0.500.
      To find out which side is positive and which side is negative there is a number on the chip even or odd ex. 8744 -> even and you put the positive lead I think on the 2 & 3 pins , and accordingly the negative on 6&7.
      If you want to keep it simple, just try it one way and the other, one reading will give you a result the other one wont give you a result.
      Answer to Noob question 2:
      -> Yes you can, the little dot on the chip indicates that the leg is leg No. 1
      Regarding your question for the board I currently cannot make any analysis sorry for that but I hope I could help you at least a little bit
      Cheers!
      Edit:
      I see that the mosfet Q56 is not a 8 leg mosfet, I would suggest looking on youtube how to test this one!
      • DanFen
        • Apr 2017
        • 201
        • Malta
        Thanks so much for the information, it surely helps a lot. You taught me a couple of new things in a single post!
        Yes I have a hot air station. I'll have a look later, maybe also wait for some other members to point out their view on this one.
        Danke von Malta!
        • diif
          • Feb 2014
          • 6978
          • England
          Small hole is usually pin 1. Check the data sheet to confirm.
          To identify the pins on U25 should be easy. One side on all four pins will have continuity or near 0 ohm resistance. They are pins 5,6,7,8.
          1, 2 and 3 are all the same again showing continuity. Leaving pin 4 on it's own.
          Do tests with the power off.
          • DanFen
            • Apr 2017
            • 201
            • Malta
            Also I am noticing that the CPU area is hot when power is plugged in... even though it's "off". As far as I'm concerned, it's not supposed to be hot when it's off and plugged in.
            I'll keep you informed about the outcome on the Mosfets.
            • onlyprinzp
              • Mar 2017
              • 14
              When it gets hot it usually means there is a shortage somewhere in the circuit.
              Best option I like to do is to first take out power adapter, then get some freez spray and spray it on the area which gets hot. When its still liquid like, blow slightly with your mouth it will get all white frozen. Plug in the ac adapter and look at the components which gets first melted. Usually this one is in shortage.
              Afterwards look what number the component has (ex. PQ102) and track it in the schematics. Another step is, if it is for example a coil that gets hot, desolder it and measure with a multimeter on each pin to ground, usually one side will be in shortage, but pay attention to the schematics.
              Cheers!
              • DanFen
                • Apr 2017
                • 201
                • Malta
                I haven't tested the mosfets yet, however I will try the freeze spray as that seems the easiest and probably the most effective (at least to my eyes).
                What is strange however, is that to me it seems that the CPU is getting hot. Hope it's not fried cause I left it plugged in for quite some time!! I will still give the spray freeze a shot.
                Do you guys use an actual spray freeze or just a compressed air can?
                • onlyprinzp
                  • Mar 2017
                  • 14
                  Check that with your CPU sounds really bad :/
                  I mainly use freeze spray, saw that videos on youtube about that aircan but I really dont bother cause you will just need 1 can for the future so the investment of about 10€ is not much.
                  Use freeze spray like this industrial ones:
                  http://www.ebay.co.uk/itm/FREEZE-SHO...8AAOSwTM5Y46c1
                  Dont use those injury medical freeze sprays, cause they could contain other substances that will stick to your motherboard. With these industrial / mechanical freeze sprays you are on a save side, especially if they have this small pipe its pretty nice to spray with it.
                  Cheers!
                  • onlyprinzp
                    • Mar 2017
                    • 14
                    One more hint, take out the CPU while you work on your motherboard, if there are parts getting hot fix those and if all seems ok, plug the CPU back in and see if it powers up correctly.
                    Cheers!
                    • DanFen
                      • Apr 2017
                      • 201
                      • Malta
                      I tried the "simplest" thing first... got the CPU out and got myself a can of freeze air. Sprayed on the area but couldn't see any particular component that lost the freeze faster than the others.
                      Could be I'm not too confident with the freeze spray yet, as sometimes it just disappeared very quickly, at times it just sat there for a long time. Could also be I didn't notice, since I don't have a microscope.
                      So now I'm trying to check all rails starting from the DC IN. Haven't checked the mosfets mentioned earlier yet.
                      • DanFen
                        • Apr 2017
                        • 201
                        • Malta
                        So I was going through the schematics and measuring voltage around the board (for hours now), and stumbled upon a High-Speed Step-Down Controller. I couldn't find much information about this, but it's model is: G5603RU1U
                        This particular IC is on page 42 of the schematics posted in my original post.
                        This is a screenshot:
                        Can someone please explain what it does and how I can test it out? Excuse me if I'm out of point or doing it incorrectly, but I went ahead and checked the pinouts and got these voltages:
                        1. 0V
                        2. 0V
                        3. 0V
                        4. 5V
                        5. 0V
                        6. 0V
                        7. 0V
                        8. 0V
                        9. 5V
                        10. 5V
                        11. 0V
                        12. 0V
                        13. 0V
                        14. 5V
                        15. 0V
                        Also when I connect the power switch, the power led blink randomly.
                        • mielta
                          • Apr 2015
                          • 368
                          Hi
                          First you must check U25 Pin1 where the hole is there must be 5v Present
                          when not check pin 5-8 this is the other side there also must 5v be present.
                          whwn on pin 5 is 5v and on pin1 not then you must check q56 on R935 +VSB
                          • DanFen
                            • Apr 2017
                            • 201
                            • Malta
                            Hi mielta,
                            U25:
                            Voltage on pin 1 is not present.
                            Voltage on pin 5 to 8 is present (5V).
                            So I've tested Q56 (dual n-channel). Got it out of the board to test it out properly. I never tested one, so it's the first time I'm doing it. Being it so small, made things more difficult, also my probes are kind of thick. This is how I tested in diode mode:
                            Drain to Source = around 830
                            Gate to Source / Drain = 0
                            Does it make it good?
                            Originally posted by mielta
                            Hi
                            • mielta
                              • Apr 2015
                              • 368
                              Originally posted by DanFen
                              Hi mielta,
                              U25:
                              when is it 0 than it has a short
                              it is dead
                              • DanFen
                                • Apr 2017
                                • 201
                                • Malta
                                Well, that's what it gave me outside the board. So - from Gate to Source and to Drain means not working. The information I was finding on the internet was confusing at times.
                                I'll try to find a replacement. Hope one of my donor boards has it.
                                Noob question: How do you manage to measure such small components? Any tips about this? It kept moving all the time!!
                                EDIT: None of my donor boards have that, thee closest I could find is THIS. THIS is what I have. But I don't think it can be used.
                                it is dead
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3610
                                  • slovakia
                                  ofcourse can. the replacemeent is 3times better
                                  • DanFen
                                    • Apr 2017
                                    • 201
                                    • Malta
                                    Thanks so much for that. Will try and give feedback.
                                    Do you think replacing the capacitors next to the mosfet is better? Or shall I attempt not to replace them at first?
                                    • DanFen
                                      • Apr 2017
                                      • 201
                                      • Malta
                                      Replaced Q56 but no luck. Still the same.
                                      Pin 1 on U25 is still 0V. Pins 5 to 8 are all 5V. So maybe something is wrong with the capacitors in between? The problem is they are not labelled on the board
                                      Checked the other rails which are basically of the same design... the 3VALW to 3VS and the 1.5V to 1.5VS and it's the same with them, obviously with the respective voltages. So I have a feeling that the 5V we're working on is fine. If this is the case, then the fault is on some other circuit?
                                      So if we go back to the symptoms, the power LED just turns on and off randomly for a split second. The area we worked on is where we've seen the water spill.
                                      • DanFen
                                        • Apr 2017
                                        • 201
                                        • Malta
                                        Did some further checks, and it seems that now the problem is on the 1.5V rail. It's just I can't seem to find out how to trace the prob.
                                        I ended up on the PU22 (mentioned above as: G5603RU1U), and it seems it has the 5V on the 5V inputs and outputs, but the 1.5V is missing. Replaced it but still the same.
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • Nooy
                                          VGA MOSfet permanently shorted and loss of MOSfet pad
                                          by Nooy
                                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                          02-14-2024, 02:26 AM
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
                                        • MicroSMD Lab
                                          by MicroSMD Lab
                                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                          01-10-2024, 06:36 AM
                                        • Scotchmist
                                          Asus GA502D keeps blowing mosfet
                                          by Scotchmist
                                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                          I have removed the mosfet and can run the laptop no problem
                                          The MOSFET is FDPC5018SG
                                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                          08-24-2024, 02:23 PM
