Replaced NEC/Tokin capacitors now screen blank help please
  • globalmark
    • Jan 2017
    • 11
    Hi
    I have just replaced the NEC/Tokin capacitor in a Toshiba A300 as per instructions on this site and Internet and YouTube etc with the 4 replacement 330's (or whichever was correct)
    I am a beginner when comes to laptop repair done light stuff before and I am ok at soldering .
    All seems to have gone well no problems removed easily and soldered replacements on fine .no problems that I can think of .
    I just put the laptop back together and turned it on. The fan spins and sounds like turned on lights all on etc however now the screen is completely black (blank) - nothing , no flickers , no bios screen just black .
    I took apart again to see if left cable disconnected or didn't seat graphics card properly but all seems fine .
    Would this be caused by the capacitors ? Or is it lightly to be something else ?
    Any suggestions would be appriciated .
    Thanks Mark
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: Replaced NEC/Tokin capacitors now screen blank help please
    Can you put a Clear image of that capacitor installation. and check the voltage at that capacitor.
    • globalmark
      • Jan 2017
      • 11
      Hi
      Thanks for reply
      Photo taken of new capacitors . Have attached image .hopefully shows up .
      How would I test that voltage , I have a basic multimeter but where and how should I test ?
      As mentioned Laptop seems to power on ok just blank screen ? Would that be the capacitors or something else ?
      Thanks Mark
      • smali
        • Sep 2014
        • 287
        • Pakistan
        check the voltage on the capacitors how many voltage you have receiving? it should be roundabout 1 volts...if not receiving then check the capacitors on ohms range how many ohms showing? it should be above the 5 ohms if you are checking in circuit.. if showing 0 ohms may be one capacitor is short or soldering made a short circuit..
        • globalmark
          • Jan 2017
          • 11
          Hi
          Just check across the terminals on capacitors and get .999v and .998-.999 on each side so basically 1 volt (checking on + and - strips under two of the capacitors and same other two .
          • smali
            • Sep 2014
            • 287
            • Pakistan
            Originally posted by globalmark
            Hi
            its OK...have check on another processor or RAM etc?
            • globalmark
              • Jan 2017
              • 11
              I used this video to remove and replace
              https://m.youtube.com/watch?v=4W2AljjOUYQ
              And removed all chips/ things he suggested on video to stop damage to them the replaced - think main processor and graphics chip etc (not 100%) sure what they were but removed and replaced ok .
              I also replaced with all new heat sink compound - removed old with alcohol cleaned and dried then some new if that makes a difference .
              Could I have damaged graphics card (I was really gentle and careful) or incorrectly connected monitor again ?
              Is it lightly to be capacitors?
              • smali
                • Sep 2014
                • 287
                • Pakistan
                and also check voltage on al l( PL) coils with ground on multi meter specially near with RAM which must be 1.5 volts...
                • raajkumar
                  • Mar 2015
                  • 354
                  • Srilanka
                  Did you checked with external monitor, RAM and RTC Battery also. If it is not power off itself with Adaptor and battery, the problem not in that nec/Tokin cap. If everything ok, you try to flash correct bios.
                  • globalmark
                    • Jan 2017
                    • 11
                    Hi guys
                    Thanks for help so far - how and where exactly do I check other voltage on PL coils (what is PL coil and where is it and how to check ) and ram (have removed and replaced several times in different slot) but only have one ram chip ..
                    What and how to check RTC battery ?
                    How to flash bios when cannot see screen - no external monitor (only computer in house)
                    Laptop was working before changed capacitors just restarting itself if plugged into mains power on battery was fine .
                    Thanks guys appriciate the help just I have no idea what doing and girlfriends laptop so she not happy even though trying to fix for her ..
                    Mark
                    • jiroy
                      • Jun 2016
                      • 2416
                      • Lebanon
                      One good step right now , is to recheck on all the connectors for loose or bent connections , and it isn't bad to re-seat the CPU if you removed it , while checking for any bent pins by mistake .
                      Remain to ask , Are The 4 capacitors you used brand new or used ?
                      • petehall347
                        • Jan 2015
                        • 4442
                        • United Kingdom
                        Hi
                        Thanks for reply
                        Thanks Mark
                        those capacitors dont look correct to me . are they correct size ?
                        • smali
                          • Sep 2014
                          • 287
                          • Pakistan
                          also clean that area near with capacitor area with a spear toothbrush and alcohol or thinner etc as circul in image and also check PCB line near nec/tokin may be damage some one during nec/tokin remove..
                          • globalmark
                            • Jan 2017
                            • 11
                            Hi guys
                            Capacitors are brand new came in sealed plastic - from eBay from Portugal reputable seller . For that correct purpose so as far as I know correct size.
                            I have remover CPU (if that's square thing many pins on it) twice now but will try again , has no bent pins but very loose fit , when took out was very easy and to replace basically dropped in then twisted plastic screw half turn to lock in.
                            just cleaned area - where is PCB line to check ? - I removed old capacitor as per YouTube video and was very gentle and careful don't think I damaged surrounding area - soldering was fairly quick so don't think got to hot or anything , but don't know .
                            Closer photo attached .
                            Thanks again for help Mark
                            • lefos
                              • Nov 2013
                              • 321
                              • Greece
                              Try to unsolder the small battery (pink color-this is the RTC battery mentioned above),
                              leave the board ~1 minute without voltage and try again. Also measure its voltage please when you have it out.
                              • globalmark
                                • Jan 2017
                                • 11
                                Hi all
                                Ok just taken apart again - reseated everything making sure clean removed and replaced CPU no pins bent .. No change
                                Lefos - battery removed is 3.19v out of computer -
                                Do you mean try to start laptop without RTC battery or just leave out one minute , solder back the battery and retry ?
                                Thanks Mark
                                • globalmark
                                  • Jan 2017
                                  • 11
                                  Ok tried to restart without battery
                                  Also resolder back in after couple mins and no change .
                                  Thanks for suggestions ?
                                  Can the replacement capacitors cause this ?
                                  Am I lightly to have left something disconnected ?
                                  Looks like nothing happening with monitor at all ?
                                  • jiroy
                                    • Jun 2016
                                    • 2416
                                    • Lebanon
                                    Mark ; Did you try to use an external monitor ? , if not , try it .
                                    And seeing the circumstances , try pressing fn+f5 repeatedly with like 5 seconds intervals ..
                                    • globalmark
                                      • Jan 2017
                                      • 11
                                      Hi Jiroy
                                      Don't have external monitor - have LCD TVs , so tried s-video out of laptop (but think need do some settings in system to make work don't I ?) also tried the HDMI out to TV but nothing there ,
                                      TV does have a PC in VGA socket but I don't have a cable - is it worth buying a cheap cable to try it ? VGA to VGA laptop to TV would this show as external monitor ? .?
                                      Do I not have to change settings in operating system to make external display work ? Which cannot do when cannot see ?
                                      Tried the FN F5 key many times no change ..
                                      Thanks for help guys
                                      • raajkumar
                                        • Mar 2015
                                        • 354
                                        • Srilanka
                                        Hi Jiroy
                                        Hi this VGA to VGA cable will cost below 5AU$. If you don't know how to view in external display you just remove the lcd cable from the mainboard. and use VGA to VGA cable to Laptop and the LCD TV. and the same time you have to change tv source mode to VGA or PC.
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • Yehuda170
                                          ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                          by Yehuda170
                                          original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                          replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                          now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                          with original broken screen i can see in device manager touch screen in human interfaces
                                          but with the new screen it's not showing in device manager
                                          is it lenovo blocking it? is it driver missing?
                                          I²C is a headache
                                          07-14-2023, 01:29 AM
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
                                        • dicky96
                                          HP Elitebook Screen blank - backlights but no image
                                          by dicky96
                                          Hi guys
                                          I'm trying to fix this laptop screen
                                          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                          OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                          04-28-2021, 07:30 AM
