Icloud locked iPhone 6 plus
  • ricosavy
    • Jul 2012
    • 457
    • united states
    I was wondering his the a way to unlock iPhone that has Icloud lock.Was looking at phon lab teachable they claim the can teach u how to unlock any iphone.Brother bought phone that has Icloud lock told him it was basically a paper weight unless he just wants it for parts.my question is has any dealt with phon lab teachables website. Or can point in right direction to learn how to unlock iphone.thanks
    • 31015
    Re: Icloud locked iPhone 6 plus
    there are company's that can brute-force the apple servers - they arent cheap.
    look here:
    http://forum.gsmhosting.com/vbb/index.php
    • tibd
      • Oct 2014
      • 189
      • Sweden
      And a paper weight it will remain if you are not into hardware stuff by changing the NAND, and some other chips. Or at least using a NAND USB adapter to delete the setup file from NAND and re-flash it again through iTunes
      • ricosavy
        • Jul 2012
        • 457
        • united states
        When you update the phone would it icloud lock again.if all you did was delete the setup file or is it permanent fix.
          • 31015
          it's activated by a setting called "find my fone"
          • ricosavy
            • Jul 2012
            • 457
            • united states
            I would like to learn this also where I can get ic chips I need.
            • ricosavy
              • Jul 2012
              • 457
              • united states
              i saw a video where a guy removes a resistor or a cap dont recall which one it was.from a ipad and downloads wifi software and was able to restore the ipad and remove icloud.i wonder if it would work on iphone.
                • 31015
                no.
                the ipad trick works by killing 3g so it cant connect to apple over the fone.
                • ricosavy
                  • Jul 2012
                  • 457
                  • united states
                  Too bad it will not work iPhone I did try to get it unlocked but told me it was locked unlocking service but was told it was reported lost.but when I checked imei said it was not reported lost.That was not covered under 100 percent guarantee to unlock it or money back.I told them that is not what there website said so they refunded me my money.
                  • ricosavy
                    • Jul 2012
                    • 457
                    • united states
                    Looks like only true way is in hardware unlocking
                    • lolantana
                      • Jan 2017
                      • China
                      you can retrieve data by yourself. There are programs to do that. For example 
                      Ipad Manager Ipad Manager
                      I used it few times.
                      But there is a sad news. I'm not sure but most of these programs work with NTFS and FAT32 files systems. I recently tried to find something that would work with ext4 but I was unsuccessful. So, because OS X is using HFS+ file system there could be problem with software. But I can't believe that they don't exist.*
                      To sum up try to google "recovering HFS+ partition" or find program for recovering data that can work with HFS+ file system.
                      Good luck!
                      • crowntoy99
                        • Oct 2012
                        • 264
                        • india
                        helo
                        any new iCloud Remove Successfully....
                        • -=kratos=-
                          • May 2017
                          • 13
                          • Piphilippines
                          there two type of removing iphone's icloud
                          the first one is via server, but its too costly
                          second is via hardware but u need expensive machine to do that
                          • petehall347
                            • Jan 2015
                            • 4426
                            give it back to the owner ..or if its yours get in touch with apple and they should unlock it for you .i have heard of others doing this and all being good .
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              Apple highly likely will tell you to get lost. Should have got an Android...
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                              • techman1025
                                • Jun 2014
                                • 497
                                Here :https://www.youtube.com/watch?v=zACXc-p5Oyk
                                Techman1025
                                • crowntoy99
                                  • Oct 2012
                                  • 264
                                  • india
                                  Originally posted by techman1025
                                  bro
                                  is this real?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    Originally posted by crowntoy99
                                    bro
                                    is this real?
                                    well i wouldnt try it as it was posted on april fools day lol but i think some people did actually try it
