iPhone 6 iCloud reset
  • Vc computers
    • Dec 2021
    • 8
    • Nigeria
    iPhone 6 iCloud reset?
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: iCloud reset
    If you mean unlocking then easiest way would be to buy an unlocked iPhone 6
    And the difficult way is.. Basically buying an unlocked iPhone 6 and transferring CPU, nand and some other components to locked phone.
    • petehall347
      • Jan 2015
      • 4442
      Re: iCloud reset
      its pretty difficult to unlock .. and even more so if you cant get root access .
      • Kush679
        MacBook Pro M1 Activate Mac
        by Kush679
        Sorry,I'm using my phone right now and couldn't find any search bar to search on the topic of macbooks.
        Few weeks back(mid may),I had bought a MacBook pro m1 A2338. It belonged to my friend's younger brother who was a graphic designer,he gave me this MacBook without any icloud account linked to it and I had so much work during that times that I only used it for storage while traveling for shoots (I'm a photographer). So long story short,his brother got involved in a bad accident and was in coma and then fairly recently they pulled out his life support. I mistakenly did an erase Mac and...
        06-20-2025, 09:43 AM
      • sheffieldyorky
        ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
        by sheffieldyorky
        Hey there people
        While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
        This is what I tried, but not in any order.
        Google
        YouTube
        BIOS
        Command Prompt (administrator privileges)
        On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
        10-25-2025, 02:22 AM
      • odie34
        Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
        by odie34
        I am a hobbyist (not a professional) so please be gentle...
        I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
        I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
        02-18-2024, 09:11 AM
      • ictc
        Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
        by ictc
        I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
        Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
        The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
        02-25-2025, 12:15 PM
      • kotel studios
        ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
        by kotel studios
        Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
        Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
        I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
        12-14-2024, 10:48 AM
