[help]ASUS F553MA NO AUDIO!
  • phantomEVO
    • Mar 2013
    • 509
    hi guys, help me! super strange problem. Asus f553ma! no audio from speaker.
    if i insert an headphone, i still haven't audio! (and the headphone is not detected)
    strange thing is that all drivers are ok! i can see the led meter that works up and down when i listen to a song, youtube vlc etc
    i'm sure it's not a driver problem, because i've also format e reinstalled all operating system.
    audio codec is alc277
    i've tried to disconnect the speaker and insert only the headphone and viceversa. still no sound. motherboard model is x553ma rev 2
  • phantomEVO
    • Mar 2013
    • 509
    Re: [help]ASUS F553MA NO AUDIO!
    [edit]if i enter into the pc through teamviewer, i can hear the sound
    • diif
      • Feb 2014
      • 6978
      • England
      Which OS and which driver did you install ?
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        its audio connector, replace it (headphone con)
        Im Back... sort of...
        • phantomEVO
          • Mar 2013
          • 509
          i dont think so: the audio connector is soldered into a small board connected to the motherboard with a flat. i've tried the notebook also without this board but it is still the same
          • phantomEVO
            • Mar 2013
            • 509
            os is windows10. realtek audio driver from asus website
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              Normal, it's the other pc converting and reproducing the sound.
              • phantomEVO
                • Mar 2013
                • 509
                so what's could be the explanation?
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  when you have audio jack it short circuit a pin that returns signal to speakers
                  when headphones are plugged in it disconnects speekers and plays on headphones
                  sometimes connector is damaged so signal is never returned to internal speekers
                  best is to replace jack or find a pin and shotcircuit it to test
                  with jack removed audio does not play
                  find schematic and study audio jack port, its almost the same on every board
                  also look if audio chip is heating... if yes, replace it. sometimes thay plug big speekers in earphone jack and blow sound chip
                  • phantomEVO
                    • Mar 2013
                    • 509
                    using an hdmi, i can ear clearly sound for my tv!
                    it seems impossible to find schematics for this motherboard! please help me
                    • passete
                      Living=Sharing
                      • Jun 2015
                      • 487
                      • France
                      If hdmi s working, i would say that the problem is the digital to analog audio converter, replace it.
                      This should be the audio ic, maybe a realteck ?
                      • phantomEVO
                        • Mar 2013
                        • 509
                        alc277.....
                        • phantomEVO
                          • Mar 2013
                          • 509
                          ALC277 changed: same thing...
                          • phantomEVO
                            • Mar 2013
                            • 509
                            switched the small board with the jack connector, with a new one: still the same!
                            • samson7point1@yahoo.com
                              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                              by samson7point1@yahoo.com
                              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                              The player processes the audio signal using two different reference frequencies. The "R"...
                              04-30-2024, 11:22 AM
                            • bajdik
                              Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
                              by bajdik
                              I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
                              Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
                              I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
                              Unfortunately, I don’t have access to the schematic.
                              It seems to me that when I bend the board, something changes.
                              Could this...
                              08-13-2025, 07:26 AM
                            • ShadowAi
                              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                              by ShadowAi
                              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                              03-15-2024, 10:46 AM
                              ASUS X553MA-SX561B Notebook Specification for Upgrade or Repair
                              This specification for the ASUS X553MA-SX561B Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X553MA-SX561B boardview and X553MA-SX561B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                              09-06-2024, 06:20 AM
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
