[help]ASUS F553MA NO AUDIO!
  • phantomEVO
    • Mar 2013
    • 488
    hi guys, help me! super strange problem. Asus f553ma! no audio from speaker.
    if i insert an headphone, i still haven't audio! (and the headphone is not detected)
    strange thing is that all drivers are ok! i can see the led meter that works up and down when i listen to a song, youtube vlc etc
    i'm sure it's not a driver problem, because i've also format e reinstalled all operating system.
    audio codec is alc277
    i've tried to disconnect the speaker and insert only the headphone and viceversa. still no sound. motherboard model is x553ma rev 2
  • phantomEVO
    • Mar 2013
    • 488
    Re: [help]ASUS F553MA NO AUDIO!
    [edit]if i enter into the pc through teamviewer, i can hear the sound
    • diif
      • Feb 2014
      • 6978
      • England
      Which OS and which driver did you install ?
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        its audio connector, replace it (headphone con)
        Im Back... sort of...
        • phantomEVO
          • Mar 2013
          • 488
          i dont think so: the audio connector is soldered into a small board connected to the motherboard with a flat. i've tried the notebook also without this board but it is still the same
          • phantomEVO
            • Mar 2013
            • 488
            os is windows10. realtek audio driver from asus website
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              Normal, it's the other pc converting and reproducing the sound.
              • phantomEVO
                • Mar 2013
                • 488
                so what's could be the explanation?
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  when you have audio jack it short circuit a pin that returns signal to speakers
                  when headphones are plugged in it disconnects speekers and plays on headphones
                  sometimes connector is damaged so signal is never returned to internal speekers
                  best is to replace jack or find a pin and shotcircuit it to test
                  with jack removed audio does not play
                  find schematic and study audio jack port, its almost the same on every board
                  also look if audio chip is heating... if yes, replace it. sometimes thay plug big speekers in earphone jack and blow sound chip
                  • phantomEVO
                    • Mar 2013
                    • 488
                    using an hdmi, i can ear clearly sound for my tv!
                    it seems impossible to find schematics for this motherboard! please help me
                    • passete
                      Living=Sharing
                      • Jun 2015
                      • 487
                      • France
                      If hdmi s working, i would say that the problem is the digital to analog audio converter, replace it.
                      This should be the audio ic, maybe a realteck ?
                      • phantomEVO
                        • Mar 2013
                        • 488
                        alc277.....
                        • phantomEVO
                          • Mar 2013
                          • 488
                          ALC277 changed: same thing...
                          • phantomEVO
                            • Mar 2013
                            • 488
                            switched the small board with the jack connector, with a new one: still the same!
