Dell m5110 power issue
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    I have done a lot of troubleshooting on this particular board but it is always getting me confused so I need help. The problem is that no power at all immediately you plug in the charger TPS51123 start to get hot. I have replaced it with a new one still same.
    this is some readings I did on the Tps51123 when charger is plugged in
    pin16 = vin=19.1v
    Pin8 = vreg3=0.983v
    pin17=vreg5=5.1v
    These pins also short to ground immediately charger is plugged in pin7=v02, pin24=v01, pin12=drvl2, and pin21=drvl1.
    I need help
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Re: Dell m5110 power issue
    I failed too, with this situation in dell 3521 .once charger is plugged in power button short to ground after some time that will disappear~
    sigpic
    • bluestone
      • Jun 2011
      • 343
      • Ghana
      I think there should be a way out
      • lukkil
        • Aug 2018
        • Polska
        did u solve the problem?
        cheers
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3609
          • slovakia
          find why is Vreg3 pulled low. maybe kbc is bad but u must find what pulling down 3D3V_AUX_S5. i see there are many things that could do it, like Q2703, Q2701 ...
          go one after another. if u cannot measure bad thing just go one by one and remove ics that could do that
          also that shorts on 3v and 5v sides must be rid off. check all 4 mosfets
          • Johndill
            Dell Inspiron 7567 LA-D993P odd charger issue
            by Johndill
            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
            Here are the tested scenarios:
            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
            2. With the laptop off, plug in charger (LED says on) & the front charging...
            11-16-2022, 10:55 PM
          • SuperJames
            Dell G3 17 3779 Weird power cycling and shutdown/restart issue
            by SuperJames
            This one's a weird one, and still unsolved despite it having gone back to Dell once.
            Specs
            i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
            Backstory
            I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
            10-23-2023, 04:09 PM
          • BTubbs200
            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
            by BTubbs200
            Dell Latitude 5420 P137G
            Board: LA-K491P REV A01
            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
            Board seems to have no shorts, all power rails are fine and show high resistance.
            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
            01-24-2025, 08:15 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Ven
            Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
            by Ven
            Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
            Issue Description:
            1. CPU Overheating to 100°C
              • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
              • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
              • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
              • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
              • Thermal
            02-12-2025, 03:57 PM
