g6 usb problem
  • mazloum
    • Sep 2012
    • 499
    • Lebanon
    g6 usb problem
    hi
    this laptop has no usb working it is g6 (6050A2454801-MB-A01)
    the 5v is present, the usb is not working , even in dos or bios
  • hyditech
    • Jun 2012
    • 272
    • nigeria
    Re: g6 usb problem
    Try flash the bios
    • Djosla
      • Dec 2012
      • 246
      • Montenegro
      Re: g6 usb problem
      don`t bother...chipset needs replacement...
      • mrwab
        Banned
        • Jan 2014
        • 83
        • morocco
        Re: g6 usb problem
        check data + and data - is available or no
        • samanthban
          • Feb 2014
          • 253
          • Sri lanka
          Re: g6 usb problem
          if you don't get data signal better replacing pch
          sigpic
          • AquaMan Ua
            Problem with PANASONIC CF53 laptop after changing BIOS settings
            by AquaMan Ua
            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
            05-17-2025, 09:40 AM
          • traxformania
            TONGFANG "GM7TG7P" Bios Password Problem?
            by traxformania
            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
            I'm trying to reset my bios without success.
            I tried :
            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
            11-15-2023, 07:32 AM
          • trouble55
            NEC VersaPro PC-VRT42FBFR22B BIOS problem
            by trouble55
            Hi All,
            [Mother board model]
            V-VE212(U3E1)
            [Serial number]
            24000135PA
            [BIOS chip model]
            Macronix MX77L12850F
            I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
            I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
            I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
            09-19-2024, 01:24 AM
          • toti24
            (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
            by toti24
            dell precision m4600 laptop
            i7 2760qm
            8gb ram 750gb HDD
            intel hd 3000 integraded and nvidia quadro 2000m
            pleasea bear with me english isnt my language and ill try to be as clear as possible
            note i live in mexico in a very small town..
            thank you.
            laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
            the brick happened when i was installing win 10 using usb.
            used rufus and officia microsoft.iso
            it finished copying files from usb...
            03-06-2022, 08:39 PM
          • zPwN!
            ENOVA NE14I310 XU133t rev 1.3 working BIOS
            by zPwN!
            Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
            Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
            System SKU NE14I310
            BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
            Motherboard XU133T rev 1.3
            Serial Number IPNBI3X240SM2A01095
            Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
            RAM 8.00 GB
            NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
            01-03-2025, 01:03 AM
