ENOVA NE14I310 XU133t rev 1.3 working BIOS
  • zPwN!
    gordo kko
    • Dec 2024
    • 5
    • Argentina
    Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
    Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
    System SKU NE14I310
    BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
    Motherboard XU133T rev 1.3
    Serial Number IPNBI3X240SM2A01095
    Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
    RAM 8.00 GB
    NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS is working 100%. I tried with 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC and 15.0.41.2158_CON_LP_B_PRD_EXTR_74393372, but it didn“t work because of the different hardware setup, so I had to reconfigure it with Flash Image Tool. Now, it is 100% working, but if anyone has the original BIOS, please share it. Thanks.
  • SoporteNetFe
    • Aug 2021
    • 121
    • Argentina
    See this post
    https://www.badcaps.net/forum/troubl...xu133t-rev-1-3
    • TyMercer
      Can I flash a working BIOS from one computer to another of the same make, model, etc?
      by TyMercer
      Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
      11-13-2025, 09:39 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • joven016
      Lenovo Ideapad S145 need working bios HELP!!
      by joven016
      Problem is blinking power led only
      i don't know exactly if it's s145-15igm or s145-14igm
      have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
      Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
      Already tested some of posted bios here
      S145-14igm - success but invalid serial and not booting on OS
      S145-15igm - success with serial and some other info in bios but still not booting on OS
      already tried installing new windows but always booting on bios setup
      windows installer flash drive detected on...
      08-21-2025, 10:55 PM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • Sparklingx
      CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
      by Sparklingx
      So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
      So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
      now all...
      08-29-2024, 01:53 PM
