MacBook Pro (17-inch Mid 2009) 820-2610 MLB Repair
  • iMic
    • Oct 2013
    • 40
    I've recently come across a MacBook Pro (17-inch Mid 2009) in almost pristine condition. The machine owes me nothing so far, but considering its condition, build quality and that incredible 17-inch screen I would like to see what can be done with it.
    It didn't power on. The machine did start for a while, but only if I disconnected some auxiliary components to reduce the current draw on the Logic Board. The LED on the front illuminates for a second, then the machine clicks off. Sometimes it will make it half way through boot and then suddenly shut off. In the rare occasion the machine does make it to the desktop, usually after five or six attempts, it will generally stay running without issue. After a while the machine stopped starting up entirely no matter what I tried.
    I tested the PM_SLP_S4_L line which is a common failure on these boards and found it was reading at 0.3v, much too low to start the system. I replaced the 330uF 2.5v Poly-Tant capacitor at position C7771 with a Poly-Film capacitor, and with some creative component placement, this resolved the problem. The rail now comes up to 1.1v and the machine powers on.
    However it doesn't complete POST. The front sleep LED comes on, the fans spin, the HDD receives power and that's about it. Removing the memory modules results in no change, no memory beeps. The board did work previously, albeit intermittently, which makes me think something went awry in the process of replacing the capacitor.
    I would like to probe around the board further and see what went wrong, but I wouldn't know where to start. I have seen some online sources offering schematics (SCHEMATIC,Folsten_MBP17) and board views for the 820-2610 series of boards, but I thought I would ask here first. This board has always been a great resource for hobbyist electronics repairers and if someone does have it, it saves me having to share my credit card details with some rather sketchy websites.
    Cheers in advance.
    ~ iMic.
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: MacBook Pro (17-inch Mid 2009) 820-2610 MLB Repair
    I think some people have had problems with BIOS that was corrupt that caused such issues.
    • polytek
      • Dec 2013
      • 496
      • TUNISIA
      it's a good job what are you doing, thanks for sharing your experience friend.
      • iMic
        • Oct 2013
        • 40
        Started the machine yesterday afternoon and she ticked over without a hitch.
        I have seen issues before where the alcohol cleaning solvent hadn't fully evaporated from the board causing some anomalies, so I wonder if that was the case here. Been running for about 9 hours stable now including an Apple Service Diagnostic EFI / OS stress test, so it now looks rather promising for this board.
        I have heard these machines can have some issues with the EFI ROM / BIOS. The chip in question is directly opposite the C7771 capacitor on the opposite side of the board, so sometimes heating the ROM chip can make the board appear to work again - in reality it's the heating of the adjacent capacitor that causes the board to start up.
        Still, something to keep in mind if I continue to have issues with it down the track.
        • iMic
          • Oct 2013
          • 40
          Eventually did manage to track down the necessary schematics and board view files for this model. I've attached them here in case we want to add them to the collective community archive of notebook schematics.
          • inflex
            • Aug 2012
            • 545
            Thanks for the BV files. Adding them to my collection. Have been working on modifying the OpenBoardView program on linux the last couple of days to add more features/usability.
            YouTube Repair Videos - https://www.youtube.com/user/19PLD73
            FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
            • 2andrewd
              • Mar 2012
              • 41
              • us
              https://www.youtube.com/user/rossmanngroup/videos
              This man is a genius when it comes to mbp mobo repair. Amazing channel! Definitely take a peek.
              • inflex
                • Aug 2012
                • 545
                What I really enjoy about his videos is the entertainment value as well. Sure, there's a few things on the technical/purity-side that aren't quite correct but really the guy is fantastic. I'm already subscribed from last week and I see he's just clocked over 150,000. It was only about 24 hours ago I watched the video doing the very repair that was done here (regarding the poor cap issue).
                • mmartell
                  • Oct 2013
                  • 3189
                  Just saw a vid of his about reballing and reflowing. Said reflowing is bullshit because it's the chip not the solder balls and explained if you heat it without melting the balls the chip will work again. Seems he forgot about thermal expansion.
                  • iMic
                    • Oct 2013
                    • 40
                    Only recently managed to compile OpenBoardView on OS X. Still needs some refinement on an OS X host but it already works a lot better than Landrex Test Link does. Looking forward to seeing what can be done with it as new features are added.
                    Currently working on sourcing schematics and board views for other boards as well. Starting to build a reasonable collection of them so if you're after any others, throw me a board number (820-****) and I'll see if I can track it down. Probably better to PM as I'll receive an email notification, don't always get to check the forums for new posts consistently otherwise.
                    • siroos_tz
                      • Feb 2014
                      • 120
                      • the UK
                      Thanks iMic for the BoardView and Schematic
                      • rediii
                        h???, spurrrn
                        • Mar 2018
                        • 490
                        • somewhere in europe
                        thanks man!
                        • Stephen
                          Meow Meow MEOW!
                          • Apr 2020
                          • 667
                          So responding to this thread since I am having the exact same issue you are having, it seems you have solved yours with waiting. The problem is my logic board is not posting. All the alchohol is evaporated and the Capacitor was replaced. I even replaced the EFi/ROM chip and still no avail. Reset the SMC and still no avail...the fans do turn on, sleep light turns on etc. The only thing is NO CHIME, and even the USB ports do not work, but yet there is 3.4 volts at all proper areas on the board for power. I am mind boggled when I looked at the schematic and just can't seem to pinpoint the issue. I have basic knowledge of this stuff but I can understand board view and the PDF files as well. So I can pin point the location of components if you can help me out here. Also side note, I believe my MacBook Is a 17" Early 2009. Let me know if you have any ideas!
                          sigpic
                          MEOWING IN THE IMPOSSIBLE UNIVERSE!
                          • envym
                            MacBook Pro 2018 with Activation Lock
                            by envym
                            Hi everyone!
                            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                            06-27-2025, 08:54 AM
                          • tobeend
                            Bypass mdm macbook m2 ventura
                            by tobeend
                            1. RESET MACOS WITH IPSW
                            a. Power off MacBook, press and hold the power button to enter Recovery
                            b. Open Disk Utility, remove Macintosh HD
                            c. Reboot, connect to the network to Activate Mac.
                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                            05-26-2023, 07:18 AM
                          • SarcasticOP
                            General question about MacBook power rails for repair.
                            by SarcasticOP
                            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                            • PPBUS_G3H (12.6V-12.8V)
                              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                            • PP3V42_G3H (3.42V)
                              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                            • PPVRTC_G3H (3.3V)
                              • This
                            12-12-2024, 05:50 PM
                          • NConstantinou
                            Macbook pro 13 mid 2009 ppbus_s0_lcdbklt_pwr Problem
                            by NConstantinou
                            Dear All
                            i have a board for Macbook pro 13" A1279 mid 2009 k24 2.26 with missing PPBUS_S0_LCDBKLT_PWR.
                            Q9806 which i beleive is the driver of it, pins 3&4 have 12.6v but pins 1,2,5,6
                            which are the outputs i have nothing.
                            checking Q9806 for short it seems ok.
                            i used my power supply and i appiled 1.5v to see if enable pin on U9701 will enable and it's ok(1.5V)
                            the output of Q9806 on schematic says 12.6v. can i get this voltage from somewhere!
                            thanks
                            01-04-2023, 09:31 AM
                            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-12-2024, 03:28 PM
