ch341a doesnt detect MX25L8005
  • kingchristo
    • May 2016
    • 20
    • Uk
    I have a ch341a with the soic8 clip and trying to flash the bios I have plugged in the clip with the red wire to the pin with the dimple and have put the other side of the soic clip into the ch341a top sockets away from the locking pin but it doesn't detect this is driving me mad bet its something simple I'm doing wrong.
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: ch341a doesnt detect MX25L8005
    If the programmer proved and was good before & supposing you perform auto detect the chip. Then its either wrong alignment of chip, defective chip or may be defective programmer (least probable). I have bunch of these programmers and they are real hard to brick. On the other the 25x chips goes bad easier. Bad alignment though or non touching legs (often) are the culprit.
      • 31256
      clip?
      are you trying to program a chip while still fitted to something?
      • kingchristo
        • May 2016
        • 20
        • Uk
        I have managed to flash it now but it hasn't fixed the problem with the notebook it still just boots up with no display and the moon light lit
        • intelg
          HP Elitedesk 800 G6 lost BIOS admin password
          by intelg
          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
          Here is the hardware identification specs:
          HP EliteDesk 800 G6 Desktop Mini PC
          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
          BIOS ver S21 Ver. 02.05.01 01/05/2021
          Born on date: 07/26/2021
          SN MXL11841GN
          SKU 3X8V9UCHABA
          UUID 8116E79EF6FFE94DB0B98A3188270C5C
          SYSTEM BOARD ID 8710
          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
          11-03-2023, 02:05 AM
        • md500
          [Question] Ch341a and 5v to 3.3v with logic converter
          by md500
          zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
          Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
          What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
          I can't buy the ch341a 1.6v that has...
          05-24-2024, 06:51 PM
        • Delicieuxz
          I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
          by Delicieuxz
          I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
          Here's an audio clip of the sound coming from my speakers:
          https://vocaroo.com/16HaryHwTx78
          I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
          11-15-2023, 09:50 PM
        • Jérémy Vanbaelinghem
          The CH341A doesn't read anything, but maybe that's because I'm a noob :D
          by Jérémy Vanbaelinghem
          I'm desperately trying to get my CH341A to work, but it seems that all my attempts have failed. Despite everything, I want to check that it works, the aim being to read at least one chip and “screenshot” the configuration for me to use as a reference.
          Here are the steps (software part):
          - I'm running Windows 11 Pro 64-bit (10.0 build 26100)
          - Drivers are installed (no error messages) and there are no problems in the Device Manager.
          - Set the language to English (to avoid the CH341A's basic software bug)
          - Does not work on AsProgrammer...
          05-05-2025, 02:30 AM
        • ChaosLegionnaire
          correct way to connect bare speaker wires into spring clip terminals?
          by ChaosLegionnaire
          i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
          however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
          i googled...
          10-27-2022, 06:19 AM
