Hp15r don't boot
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 350
    • India
    Hp15r don't boot
    HP 15R problem
    Hi. hp ZS050 LA-A992P
    Flashed bios also
    problem is display coms fine . goes inside bios fine .
    doesn't boot to any media hardisk or usb... just hard disk led turns on and laptop turns off .. than on again
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: Hp15r don't boot
    replace YC1 and YC2 ( may be on your PCB) XTAL near on board CPU and post the result.
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 350
      • India
      Ok i will update again thanks
      • faisalali
        • Mar 2016
        • 25
        • pakistan
        i need hp 15-r100ne bios bin file
        problem is that is switching but suddenly off with in 20 sec
        • smali
          • Sep 2014
          • 287
          • Pakistan
          Dear faisalali,
          i think it is not bios fault have you received 1.35 voltage ob RAM coil? check all voltage on coil?
          • faisalali
            • Mar 2016
            • 25
            • pakistan
            sir no voltage on RAM coil. ?
            • ravi_1617
              YY Solutions
              • Jan 2012
              • 350
              • India
              smali !!
              Same condition. after changing both crystals.
              Hard disk led blinks 1-2times than shutting down than on again cycles.
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                did you TURN OFF safe boot and TURN ON legacy or csm boot?
                Im Back... sort of...
                • abbas_govani
                  • Jul 2013
                  • 89
                  • India
                  hi guys am having some different problem. had this board la-a992p and la-a994p. both laptop have same problem. laptop power on for 4 to 5 second then it off. had reflashed the firmware but no success. any suggestion welcomed.
                  thanks.
                  • bilal1992
                    • May 2017
                    • 26
                    • algeria
                    try to change boot mod to legacy .
                    • abbas_govani
                      • Jul 2013
                      • 89
                      • India
                      there is no display. so cant change to legacy mode.
                      • raajkumar
                        • Mar 2015
                        • 354
                        • Srilanka
                        thanks.
                        I had the same issue on LA-A994P. I removed LVDS Connector from motherboard. Now the laptop working for long, Harddisk also reading. I checked that cable, there is short on ( Camera line ) 3v line found. Now i ordered for new cable and waiting for that. Try to flash following file have Main + EC.
                        • vishalcomputers
                          • Jan 2020
                          • india
                          Hell every.
                          I have one problem
                          Hp la-a992p. Motherboard
                          Allworking fine external display also working fine
                          But internel display only back light on no image.
                          I change creen new one ad cabel also.
                          Plz gaide me.
                          • ravi_1617
                            YY Solutions
                            • Jan 2012
                            • 350
                            • India
                            Hi ,I have LA-A992P
                            Laptop working /booting fine with adaptor power only.
                            When connected with battery.
                            Board Turns on ,only backlight is on, no text or image.
                            Board has Graphic chip too.
                            Found coil PLV1 burnt /open due to short PCV4 short.
                            Replaced both but ,no improvement
                            Battery is also no charging.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Try with another known good battery first.
                              • ravi_1617
                                YY Solutions
                                • Jan 2012
                                • 350
                                • India
                                Already checked it ,just now solved,PQ101 was short.
                                • ravi_1617
                                  YY Solutions
                                  • Jan 2012
                                  • 350
                                  • India
                                  thanks.
                                  Hi
                                  same problem board starts and turns off after 4-5 seconds .
                                  no power at PLM2 1.3VOLT, PRM4 5R1 was open .
                                  now power present at PLM2 .
                                  now board starts ON&OFF .its self turns on &off power led on/off onoff...
                                  no power at PLZ2 .PLG1 nil power CPU stats heating slowly
                                  PLZ2 ref GND 5.1 Ohm/PLG1ref GND 2.7 Ohm suspect CPU not short
                                  PL002 1.02 VOLTS present
                                  Bios flashed
                                  still same,
                                  no replaced ISL95833B (PIZ1)
                                  • privato89
                                    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                    by privato89
                                    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                    Let's begin:
                                    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                    03-26-2024, 06:37 AM
                                  • Luke Anders
                                    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                    by Luke Anders
                                    A few details about the laptop itself:
                                    Name: Lenovo Legion 5
                                    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                    BIOS Version: GKCN60WW
                                    EC Version: GKEC65WW
                                    Serial Number: PF39AQ7Z
                                    Board Model: NM-D562 Rev 3.0
                                    RAM: 16GB Installed, DDR4 (brand new)
                                    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                    I bought this laptop recently from eBay as a faulty device....
                                    10-12-2024, 05:13 AM
                                  • hinisa
                                    Xiaomi router freezes at boot after re-capping
                                    by hinisa
                                    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                    07-08-2023, 05:58 AM
                                  • NolesFan
                                    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                    by NolesFan
                                    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                    10-24-2024, 06:36 PM
                                  • praveenramavath
                                    Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                    by praveenramavath
                                    Hello All,
                                    I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                    https://www.hifivision.com/threads/m...-screen.98243/
                                    Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                    04-26-2025, 09:08 AM
