Hp15r don't boot
    Hp15r don't boot
    HP 15R problem
    Hi. hp ZS050 LA-A992P
    Flashed bios also
    problem is display coms fine . goes inside bios fine .
    doesn't boot to any media hardisk or usb... just hard disk led turns on and laptop turns off .. than on again
    Re: Hp15r don't boot
    replace YC1 and YC2 ( may be on your PCB) XTAL near on board CPU and post the result.
      Ok i will update again thanks
        i need hp 15-r100ne bios bin file
        problem is that is switching but suddenly off with in 20 sec
          Dear faisalali,
          i think it is not bios fault have you received 1.35 voltage ob RAM coil? check all voltage on coil?
            sir no voltage on RAM coil. ?
              smali !!
              Same condition. after changing both crystals.
              Hard disk led blinks 1-2times than shutting down than on again cycles.
                did you TURN OFF safe boot and TURN ON legacy or csm boot?
                Im Back... sort of...
                  hi guys am having some different problem. had this board la-a992p and la-a994p. both laptop have same problem. laptop power on for 4 to 5 second then it off. had reflashed the firmware but no success. any suggestion welcomed.
                  thanks.
                    try to change boot mod to legacy .
                      there is no display. so cant change to legacy mode.
                        thanks.
                        I had the same issue on LA-A994P. I removed LVDS Connector from motherboard. Now the laptop working for long, Harddisk also reading. I checked that cable, there is short on ( Camera line ) 3v line found. Now i ordered for new cable and waiting for that. Try to flash following file have Main + EC.
                          Hell every.
                          I have one problem
                          Hp la-a992p. Motherboard
                          Allworking fine external display also working fine
                          But internel display only back light on no image.
                          I change creen new one ad cabel also.
                          Plz gaide me.
                            Hi ,I have LA-A992P
                            Laptop working /booting fine with adaptor power only.
                            When connected with battery.
                            Board Turns on ,only backlight is on, no text or image.
                            Board has Graphic chip too.
                            Found coil PLV1 burnt /open due to short PCV4 short.
                            Replaced both but ,no improvement
                            Battery is also no charging.
                              Try with another known good battery first.
                                Already checked it ,just now solved,PQ101 was short.
                                  thanks.
                                  Hi
                                  same problem board starts and turns off after 4-5 seconds .
                                  no power at PLM2 1.3VOLT, PRM4 5R1 was open .
                                  now power present at PLM2 .
                                  now board starts ON&OFF .its self turns on &off power led on/off onoff...
                                  no power at PLZ2 .PLG1 nil power CPU stats heating slowly
                                  PLZ2 ref GND 5.1 Ohm/PLG1ref GND 2.7 Ohm suspect CPU not short
                                  PL002 1.02 VOLTS present
                                  Bios flashed
                                  still same,
                                  no replaced ISL95833B (PIZ1)
